Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2020
Old 06-17-2020, 11:17 PM   #1
iB00st
Member#: 407667
Default Cant align motor mounts to subframe
Hey guys Iím putting back my engine inside my Subaru. I canít align my motor mounts to subframe. Saw it was a common issue on the forum. I jacked up the back of the tranny, used pry bar, disconnected pitch stop but still no success.
Any advise? Thanks
iB00st is offline   Reply With Quote
Old 06-18-2020, 12:39 AM   #2
SlammedSix
Member#: 419926
I have never heard of this as a "Common Problem" As every motor install i have done never has an issue sitting in the subaframe.
2 questions:
Are these pictures with the motor mated to the transmission all the way? Looks as though the input shaft has not popped into the pilot bearing on the flywheel
If so, Are you sure you did not install the motor mounts on the wrong side? They are side specific
SlammedSix is offline   Reply With Quote
Old 06-18-2020, 01:59 AM   #3
viper_crazy
Member#: 298403
2008 WRX Premium
Spark Silver
Did you jack up the back of the tranny (drive shaft end) or the front (clutch end)?
If it's the back, set it back down and turn the trans mount nuts on a few turns and jack up the front.
viper_crazy is offline   Reply With Quote
Old 06-18-2020, 04:55 AM   #4
MortonCharbo
Member#: 487057
2002 WRX Wagon
2 questions:
Looks backwards to me. I've made that mistake more times than I'd like to admit.
MortonCharbo is offline   Reply With Quote
Old 06-30-2020, 02:27 AM   #5
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Bariga is offline   Reply With Quote
