Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2020
Old 06-18-2020, 06:30 AM   #1
AVANTI R5
Member#: 73805
Default New electric turbocharger will take AMG Performance To The Next Level
he Mercedes-AMG ONE hypercar and its Formula 1-derived V6 may have been delayed to 2021, but Daimler’s performance car brand has detailed a new electric turbocharger that it says was derived straight from F1 – and it will soon be available in a showroom near you.
We’ve seen electric turbo tech before – in the epic ‘world-first’ triple-turbo diesel 4.0-litre V8 powertrain of the Audi SQ7, which incorporates a motor-driven turbo that spins up to 70,000rpm to fill the torque gaps left behind by its pair of conventional exhaust-gas turbochargers.
But unlike Audi’s e-turbo and the 48-volt electric compressor technology found in a range of inline-six Mercedes-AMGs including ‘53’ models, the new AMG e-turbo continues to be driven primarily by exhaust gases.
Therefore AMG says it’s closer in execution to the ‘MGU-H’ system seen in F1 – and the Mercedes-AMG ONE.
In this case, a slim electric motor measuring just 40mm helps drive a conventional exhaust turbo directly, and is said to deliver quicker throttle response and eliminate turbo lag, thereby enhancing driving feel and dynamics.
The tiny electric motor is fitted directly onto the charger shaft between the turbine wheel on the exhaust side and the compressor wheel on the fresh air side.
The result, AMG says, is that the combustion engine responds more immediately to accelerator pedal inputs, and also boosts outright acceleration from a standing start because more torque is produced at low engine speeds.
Even when the driver takes their foot off the accelerator or applies the brakes, Merc says its new electric turbo maintains boost pressure at all times, guaranteeing continuous response at all engine speeds.
Thus AMG claims it resolves the “conflicting goals between a small, fast-reacting turbocharger which achieves relatively low peak performance and a large turbocharger with a high peak performance”.
Capable of spinning at speeds of up to 170,000rpm, enabling a “very high rate of air flow”, the new turbocharger, electric motor and power controller are all connected to the combustion engine’s cooling system to maintain optimum operating temperatures.
Developed with Garrett and now in the final stages of production, the new AMG e-turbo also requires 48-volt electrical power, meaning it could form part of the first mild-hybrid system expected to be applied to AMG’s 4.0-litre twin-turbo V8.
The next model due to be released with that engine is the facelifted Mercedes-AMG E 63, making it the most likely candidate to debut the new technology, although it could also be applied to the upcoming AMG GT R Black Series.
Outgoing Mercedes-AMG boss Tobias Moers says the new e-turbo technology, marks AMG’s next step in electrification – which will include the 450kW Mercedes-AMG EQS electric limo.
“We have clearly defined our goals for an electrified future. In order to reach them, we are relying on discrete and highly innovative components as well as assemblies. With this move we are strategically supplementing our modular technology and tailoring it to our performance requirements,” he said.
“In a first step this includes the electrified turbocharger – an example of the transfer of Formula 1 technology to the road, something with which will take turbocharged combustion engines to a previously unattainable level of agility.”
Old 06-18-2020, 06:39 AM   #2
SubaDuba420
Member#: 102793
2016 WRX
Ugly Sedan
Very cool tech, but that's gonna be HELLA expensive to replace at 100k miles
SubaDuba420 is offline   Reply With Quote
Old 06-18-2020, 07:48 AM   #3
vapore0n
Member#: 21356
2017 Subaru Corolla
STI Limited SE-R Type (R)
I'm also sure that the car will go into limp mode and die in the middle of the road if the electric motor stops working.
Tech like this should be made more reliable. Electric motor dies, then it continues to work as a regular turbo. No limp mode, but warning of needing repairs.
vapore0n is online now   Reply With Quote
Old 06-18-2020, 08:52 AM   #4
winsor
Member#: 398222
2014 wrx
60,001 Miles
winsor is offline   Reply With Quote
Old 06-18-2020, 08:58 AM   #5
Sid03SVT
Member#: 183032
RWD Camry
Pull me over red
Originally Posted by winsor View Post
60,001 Miles
I think you meant 48 months and 1 day or 50,001 miles, whichever comes first ;-)
Sid03SVT is online now   Reply With Quote
Old 06-18-2020, 09:44 AM   #6
JP Chestnut
Member#: 504432
This seems like a total no brainer. For that reason, I assume it was a technically difficult problem to solve. I’ll wait a model generation before getting on the hype train.
JP Chestnut is offline   Reply With Quote
Old 06-18-2020, 02:03 PM   #7
White out
Member#: 46277
** LP640
575M DMC-12
Super cool. Would love to have boost at all times with a turbo that makes power in the upper powerband.
White out is offline   Reply With Quote
Old 06-18-2020, 03:24 PM   #8
heavyD
Member#: 194216
2020 X3M Competition
This looks like cool technology that's going to boost the performance of smaller displacement engines but it's kind of sad that this may replace AMG V8 engines. They already get 400+ out of their 2.0L engine but as quick as they are nobody gets out a an AMG CLA45 with the same smile on their face as they do getting out of a vehicle with the 4.0L Bi-turbo V8.
heavyD is offline   Reply With Quote
Old 06-18-2020, 06:51 PM   #9
neg_matnik
Member#: 132389
2006 WRX Wagon SGM
2003 SV1000S, 2014 DL650
The electric motor in the CHRA only *supplements* the hot-side turbine wheel; it's not replacing it.
In essence, it's a turbo that is simply assisted by an electric motor.
In theory, if the electric motor stops working the turbo should still functions as the turbine wheel will still power the compressor wheel regardless.
At least, one would hope so .
neg_matnik is offline   Reply With Quote
Old 06-18-2020, 06:56 PM   #10
neg_matnik
Member#: 132389
2006 WRX Wagon SGM
I think it's going to also boost performance of the larger engines.
They'll be able to fit larger turbos to the V8s, greatly improving exhaust flow, efficiency and power without having to worry about lag.
Old 06-18-2020, 07:56 PM   #11
JP Chestnut
Member#: 504432
Assuming it works as designed, it's simply going to keep the turbo in it's optimal efficiency range at all times regardless of what you're doing. Sometimes that's going to be due to exhaust, sometimes the e-motor. This might be the peak of ICE technology.
Old 06-18-2020, 08:03 PM   #12
Sid03SVT
Member#: 183032
RWD Camry
Pull me over red
electronic anti-lag
Old 06-18-2020, 09:16 PM   #13
lil'redwagon
Member#: 10854
'02 WRX; '08 OBXT;
'08 G37 (S/C'd); '09 XF
About damn time!
lil'redwagon is offline   Reply With Quote
Old 06-19-2020, 12:57 PM   #14
heavyD
Member#: 194216
I'm pretty sure that the 4-cylinder with this tech is going to be used to replace the V8's in a lot of models including the AMG C63.
Old 06-20-2020, 07:30 AM   #15
Scooby-Doode
Member#: 28976
2016 Step 2 Push
Buggy GT
Cool, then let's wait and see if MB and other German manufacturers cut their pricing by 1/3.
