Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2020
Old 06-19-2020, 06:00 PM   #1
benflynn
Member#: 515308
Default Dead ecu after welding on header
2005 Forester XT MT
I had a muffler shop cutting out flex pipes on my header. When I get the car back it has a p0032 code after clearing and even if o2 is unplugged. So how do I figure out if itís the sensor or ecu. I lean towards ecu, Iíll go into romraider and check the o2 data, try a reflash and delete the p0032 so I at least get my boost control back. Iím running openloop all the time showing 13.4:1 off boost, so no danger as of yet.
benflynn is offline   Reply With Quote
Old 06-19-2020, 06:30 PM   #2
Aristocrat Autosport
NASIOC Storefront Vendor
Member#: 384404
MANY WRX, STI, 997TT
wrb
is the car able to start/run at all?
Aristocrat Autosport is offline   Reply With Quote
Old 06-19-2020, 07:21 PM   #3
Bansheeboy11
Member#: 182415
1999 RS
Its not the ECU, they probably damaged the sensor or the wiring for the sensor. Ive done weld repairs on multiple dozens of cars and have never ever had a single electrical issue with one.
Bansheeboy11 is offline   Reply With Quote
Old 06-19-2020, 07:41 PM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
uhh so you are going to turn off the monitor so you can get boost control back? kinda dangerous dont you think?
subaru_gc8 is offline   Reply With Quote
Old 06-19-2020, 08:43 PM   #5
supermarkus
Member#: 6971
2008 WRX STi
SSM
my money would be on the o2 sensor.
supermarkus is offline   Reply With Quote
Old 06-19-2020, 08:53 PM   #6
benflynn
Member#: 515308
Iíll start with o2, nothing wrong with a fresh o2 sensor either way. The cell is on but it hasnít disabled the boost controller. In boost is the only place itís acting normal. Only thing itís doing is running a point rich where it would normally be in CL.
Old 06-20-2020, 11:37 PM   #7
flatlinerally
Member#: 515773
did you have a proper ground when you were welding?
flatlinerally is offline   Reply With Quote
Old 06-21-2020, 12:11 AM   #8
benflynn
Member#: 515308
Muffler shop welded it
Old 06-25-2020, 02:23 PM   #9
benflynn
Member#: 515308
New sensor came in, no change. I have a legacy ecu enroute Iím pretty sure I can drop my rom onto
