Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2020
Old 06-28-2020, 11:34 AM   #1
djoye
Member#: 50072
2017 STI
Default Killer B EWG dump tube length on EJ?
I'm having a difficult time finding a picture of the Killer B EWG dump tube installed on an EJ motor configuration. I'm trying to determine if the dump tube comes down at least as far as the bottom of the down pipe. I have a PTP lava blanket for the down pipe that I'd like to use, but I'm afraid it'll get damaged if the EWG dump tube is too short.
I'm Currently running a Grimmspeed UP+EWG and, while I could extend the skimpy Grimmspeed dump tube, I'm trying to convince myself to switch from a Tomei EL header to the pricier Killer B since I intend to keep the car for ~10 more years and I'm reading that the Tomei might not last that long since it's 304 stainless.
djoye is offline   Reply With Quote
Old 06-28-2020, 02:19 PM   #2
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I'll post a pic once I'm back in the office on Monday
KillerBMotorsport is offline   Reply With Quote
Old 06-28-2020, 03:05 PM   #3
djoye
Member#: 50072
2017 STI
Thanks!
Old 06-30-2020, 02:01 PM   #4
Hooverjc
Member#: 458285
also interested in this info. I already have the headers, just don't have them installed and looking to also either extend or add a muffler.
Hooverjc is offline   Reply With Quote
Old 07-01-2020, 04:19 PM   #5
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Super sorry it took so long. Swamped here!!
So I threw this together real quick. Was surprised myself that we have no pics of this anywhere. Our header and EWG up-pipe with an Invidia Catted downpipe. Our dump tube is longer than most by several inches, but it does have a weird shape where it tips forward a bit. We found this shape to work with most aftermarket downpipes (catted too) including the 4" ones that I think are no longer available.
Old 07-01-2020, 04:58 PM   #6
djoye
Member#: 50072
2017 STI
Thanks for the picture. Positioning looks good because it doesn't look like it can dump on the down pipe in any way, which is nice if the DP is wrapped.
Old 07-01-2020, 10:10 PM   #7
james-30
Member#: 430450
2019 STI
Lapis Blue
Killer b dump tube does not fit. I had to reuse my old Grimmspeed dump tube.
james-30 is offline   Reply With Quote
Old 07-01-2020, 11:24 PM   #8
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
What exactly does not fit about it?
kenliu84 is online now   Reply With Quote
Old 07-02-2020, 12:32 AM   #9
Haevn
Member#: 495950
2011 WRX
you should check out the BNM dump tube, i think that is something that you would like since the exit is down past the downpipe under the car.
https://imgur.com/TsmqeZh
https://imgur.com/V5dIwun
Haevn is online now   Reply With Quote
Old 07-02-2020, 10:20 AM   #10
djoye
Member#: 50072
2017 STI
Was it bumping into something? What waste gate did you try using with it? I think it's built for the Tial 38mm MV-S, so if the flange sizes for your WG don't match up to the Tial 38mm specs, that might be a problem.
