Welcome to the North American Subaru Impreza Owners Club Monday July 13, 2020
Old 06-29-2020, 09:27 AM   #1
jeff6666p
Member#: 400078
1998 2.5rs06wrx swap
black
Default knock correction
I was trying to check my fuel tank pressure using my scan tool and noticed my knock correction goes up anytime I touch the throttle. I put my accessport back on the car and I don't see any feedback knock or fine knock and mmy dam stays at 1. Is the knock correction in the scan tool part of the map?
jeff6666p is offline   Reply With Quote
Old 06-29-2020, 09:36 AM   #2
Stretch18
Member#: 239822
2010 WRX
pandiculation
Possibly a learned correction. Your AP should be able to show FBKL which might be the missing variable.
Stretch18 is offline   Reply With Quote
Old 06-29-2020, 09:39 AM   #3
jeff6666p
Member#: 400078
black
The acessport shows nothing. When I say every time I touch the throttle I mean every time. The scan tool showed under light throttle 3.5 degres of knock correction and under a light pull 4.5 degrees. just a light touch showed 1 degree. I don't understand why nothing shows on the acessport.
Old 06-30-2020, 02:00 PM   #4
jeff6666p
Member#: 400078
black
Is this something I have to be worried about?
Old 06-30-2020, 05:46 PM   #5
jeff6666p
Member#: 400078
black
Found my answer here. I had a Positive value so it was advancing timing according to this.
https://forums.nasioc.com/forums/sho....php?t=1008930
