Welcome to the North American Subaru Impreza Owners Club Sunday June 13, 2021
Old 01-28-2020, 09:34 AM   #276
SubieSteveSTI
Member#: 511129
Very nice ride
SubieSteveSTI is offline   Reply With Quote
Old 02-04-2020, 07:14 PM   #277
Kochi_STi
Member#: 369411
2002 WRX STi Limited
Thanks.
So recently I've noticed the brakes getting a bit spongy. A bit too early to do pads I thought. During the last service, I checked out the brakes while doing the tire rotation and the pads were fine, but the 18 year old rubber lines looked to be the culprit. So I put in an order for Project ***956; stainless lines. They should be by the end of the month. But the fluid and bleeder tool will here this evening.
The wife couldn't complain about car parts because it's safety related, so I figured while I have her good graces I'll sneak in a bit of an upgrade and replace the brake fluid.
Kochi_STi is offline   Reply With Quote
Old 02-07-2020, 06:25 PM   #278
Kochi_STi
Member#: 369411
The brake lines arrived much earlier than expected
Going to see if I can make time tomorrow to throw them on.
Untitled by Lino Palatino, on Flickr
Old 02-09-2020, 06:41 PM   #279
Kochi_STi
Member#: 369411
Yesterday I swapped out the old rubber brake hoses for the shiny new Project ***956; ones and replaced the old fluid while I was in there.
The pedal felt great on the drive to work this morning, so I guess I was able to get all the air out of system. It was my first time using a pneumatic brake bleeder, so I wasn't sure. But using one of those is the way to go.
Old 04-10-2020, 06:50 AM   #280
Kochi_STi
Member#: 369411
The next project came in today.
Saito Rollcage finished it much quicker than I expected.
Old 04-11-2020, 05:37 AM   #281
Kochi_STi
Member#: 369411
Had a chance to remove some trim and shave the b pillar trim to make room for the brace connecting the main hoop to the b pillar. Had to shave off about 7cm.
If the weather cooperates, I should be able to have everything installed by Thursday.
Old 04-15-2020, 12:42 PM   #282
Kochi_STi
Member#: 369411
Iíve been stuck into it for the past two days. Everything gets finished up tomorrow.
A spreader bar I made up to help fit things more easily.
About a meter or so of padding left over.
Old 04-15-2020, 01:14 PM   #283
AbrahamOller
Member#: 513748
Originally Posted by Kochi_STi View Post
I've been posting now and again in the bugeye thread and the Okinawa thread, so some you might've seen my ride already. But I figure it's time to start up my own thread. Right now it's pretty stock and in great shape. Getting coilovers in a few months. Thinking about going Cusco, but we'll see if the local tuner has any recommendations. Not planning too much for exterior mods, but I'm going to focus on handling and exhaust first.
nice pictures
AbrahamOller is offline   Reply With Quote
Old 04-16-2020, 04:27 PM   #284
Kochi_STi
Member#: 369411
Yesterdayís progress was pretty good.
This last bar was a pita to get in, but I got it using a ratchet strap and flathead screwdriver to pry it in place.
Extremely happy with the a pillar fitment.
Old 04-17-2020, 07:23 AM   #285
Kochi_STi
Member#: 369411
On the home stretch. Just going to neaten up the wiring for the gauges I put in while Iím in here.
Had to cut into the air duct for the driverís vent.
Stuffed in this flexible hose so I donít lose the ventís functionality.
That was all I had time for today before the rain came.
Old 04-18-2020, 06:04 AM   #286
Kochi_STi
Member#: 369411
Finished
Old 06-25-2020, 08:01 PM   #287
Kochi_STi
Member#: 369411
Had time to put on this Cusco brake master cylinder stopper, a nice little Father's Day present.
Old 07-30-2020, 07:42 PM   #288
Kochi_STi
Member#: 369411
Made an order with Do-Luck and got a carbon trunk on the way.
Hopefully next year I'll complete the set with the bumpers and skirts.
Old 07-31-2020, 07:23 AM   #289
Smurftastic
Member#: 243697
2002 TOPSCOOB031
HighwaystarGarage
How much of a difference does a Cusco brake master cylinder stopper make?
Smurftastic is offline   Reply With Quote
Old 07-31-2020, 09:00 PM   #290
Kochi_STi
Member#: 369411
Iíve noticed a difference under hard braking, not so much during normal driving. The pedal doesnít have any give to it like it used to. Honestly, if youíre not doing autocross or tracking the car, I wouldnít really bother with it.
Old 08-14-2020, 04:33 AM   #291
Kochi_STi
Member#: 369411
Finally got my floor bars back and incorporated into the cage.
Old 08-14-2020, 04:46 AM   #292
nikau
Member#: 516603
2000 MY00 GC8 WRX
Curious to know how the bars behind the front seats work - is the transmission tunnel reinforced where they attach to it?
nikau is offline   Reply With Quote
Old 08-15-2020, 02:06 AM   #293
Kochi_STi
Member#: 369411
Default Bugeye STi Limited in the Land of the Samurai
The tunnel itself isnít reinforced. If you look closely, the gold mounting plate is bolted to a black u-shaped bracket which sits over the tunnel and connects both sides and I guess would act like a reinforcement. The u-shaped bracket does bolt onto the tunnel, though you do need to drill two holes through to mount it.
Edit: thereís a good picture on page 9 (on my phone anyway) showing what it looks like.
Old 08-15-2020, 02:12 AM   #294
Kochi_STi
Member#: 369411
Here
Old 09-13-2020, 12:37 AM   #295
Kochi_STi
Member#: 369411
It was a Do-Luck kind of morning.
Still needs some tweaking.
Old 09-14-2020, 07:06 PM   #296
Kochi_STi
Member#: 369411
Thatís a bit closer.
Next Iíll remake the rod that connects the key and latch. Iíd rather make one that clears the trunk lid than cut it.
Old 09-14-2020, 11:08 PM   #297
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
I don't get jealous often, but that roll cage I am jealous of! What do they run, if you don't mind me being nosey?
JDMJNKY is offline   Reply With Quote
Old 09-15-2020, 01:55 AM   #298
Kochi_STi
Member#: 369411
This one was less than $900 shipped with padding and the mounting kit.
I opted for a rear roof bar, pillar braces (bolt into the front seatbelt adjuster). They also do the around-dash type, but I don't like how that looks.
Saito Rollcage had more options, but I figured any more bars would be a nuisance on a daily driver.
Old 09-18-2020, 03:58 AM   #299
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
That one is perfect IMO.
Old 09-18-2020, 07:07 PM   #300
Kochi_STi
Member#: 369411
Thanks. After living with it for about 6 months, I think so to. The only thing to do is make up a couple of brackets to fit the sun visors to the cage and it really will be perfect for my needs.
