Welcome to the North American Subaru Impreza Owners Club Thursday August 6, 2020
Old 07-15-2020, 12:19 PM   #251
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
@thejeffruhl 387hp/350tq
Forgot to post...
Installed:
Verus Block Off Plate
HKS Fine Tune VBelt
MachV 5mm Spacers (front only)
Forgive the filthy car
IMG_9523 by Jeff Ruhl, on Flickr
IMG_9515 by Jeff Ruhl, on Flickr
E32F50B0-DC14-4722-8512-DF7709F7B4FB by Jeff Ruhl, on Flickr
441A5E4D-CEF0-484F-8985-9C03E3E82294 by Jeff Ruhl, on Flickr
IMG_9514 by Jeff Ruhl, on Flickr
JeffrWRX is offline   Reply With Quote
Old 07-15-2020, 08:17 PM   #252
elanfam
Member#: 491111
2015 WRX Limited
Hi Jeff! I have been researching suspension setups and come to the conclusion that my next step could possibly the trophy cup coilovers. I found your Reddit and this thread in search of information on these coilovers and have read your build. Btw, I love it and gives me inspiration for mine. Anyways, as of now I am unsure if I should pair my swift springs with the gtworx Bilsteins or save the money and get the coilovers. My budget is in the range of these two options and I want a set up I donít really have to think of once I install them. So with your knowledge, what would handle the best for the money? Is it worth the difference From the struts to coils or not really? It is there another coilovers option instead?
elanfam is offline   Reply With Quote
Old 07-16-2020, 01:50 PM   #253
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Originally Posted by elanfam View Post
Hi Jeff! I have been researching suspension setups and come to the conclusion that my next step could possibly the trophy cup coilovers. I found your Reddit and this thread in search of information on these coilovers and have read your build. Btw, I love it and gives me inspiration for mine. Anyways, as of now I am unsure if I should pair my swift springs with the gtworx Bilsteins or save the money and get the coilovers. My budget is in the range of these two options and I want a set up I don’t really have to think of once I install them. So with your knowledge, what would handle the best for the money? Is it worth the difference From the struts to coils or not really? It is there another coilovers option instead?
Thanks...
Bilsteins + Swift is a great setup that you can install and forget about it. Trophy Cup, Tarmac 1's, RCE SS-1's etc are all really good entry level setups that are going to be a little more aggressive than the strut/spring setup and you get the ability to dial in the ride height a little more (while kind of setting it and forgetting it as well).
If height adjustment matters to you at all get the coilovers. If you just want a simple solid performing setup and ride height doesn't really matter I would go with the Bilsteins +Swifts.
On either setup I would definitely get lower LCAs for the rear and a good performance alignment running more camber in the front than the rear. Some sort of camber adjustment additions are good for the front too... camber bolts, camber plates, or Whiteline ComC Top hat (Last 2 also add Caster).
Hope that helps!
Old 07-16-2020, 02:22 PM   #254
De36
Member#: 475437
2018 WRX
+1 Great advice Jeff.
@elanfam it depends on your personal build goals. What will you be doing with the car? Daily? Showcar? Stance car? Trackdays? ect...
I track my WRX 2-3 times a month and I am running Bilsteins B8's, Eibach Prokit, Whitline Rollcenter/Bump kit, Perrin Rear 25mm Sway, & Front camber-bolts. This setup is more than enough for trackdays.
Coilovers require advance alignments & corner balancing to properly setup. Consider adding this to the cost. Best coilover advice (based on personal experience) is: don't cheap out.
De36 is offline   Reply With Quote
Old 07-16-2020, 05:50 PM   #255
elanfam
Member#: 491111
2015 WRX Limited
Thanks...
Hope that helps!
Thank you both! This information with talking to the guys at RCE/GTWorx has really helped in making my decision. I am now 99% sure I will be getting the GTWorx Bilsteins as I am just starting to modify my car and I simply want it to be a daily and a canyon monster. I want it to keep up with the bigger boys. Also, I am satisfied with the lowering of the swift springs. Track/AutoX are future endeavors but as of now are not any plans soon. So this good to hear your setup @De36 serves you very well. I was planning on a similar setup and pair the strut setup with a 24mm RSB. I'll look into the roll-center kit and front camber bolts.
Old 07-16-2020, 06:32 PM   #256
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Nice! I forgot to mention the roll center kit and how good it feels
Old 07-16-2020, 06:40 PM   #257
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
The roll center kit is a MUST if lowering your car anything more than .25"
Nice stance Jeff!
murrdogg24 is offline   Reply With Quote
Old 07-17-2020, 12:24 PM   #258
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Nice stance Jeff!
Thanks!
Agreed.
Old 07-22-2020, 10:04 AM   #259
jediwill89
Member#: 516318
2002 Legacy
wicked exhaust!
jediwill89 is offline   Reply With Quote
Old 07-22-2020, 02:36 PM   #260
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
2018 bumper conversion is here... packed and shipped extremely well. I am very impressed so far.
Old 07-24-2020, 01:03 AM   #261
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Sorted out a small issue with the Tarmac 3 coilovers. I couldnít get the ride height I wanted without having to run the perches lower than designed with the provided helpers. That meant that the main spring and helper were ďlooseĒ when the suspension was unloaded... ok to drive on for a bit but really not good or safe if I were to lift a wheel or unload the suspension the spring could come off the perch.
The solution I discovered was HyperCo helpers.... 4Ē tall and only ~.5Ē when fully compressed. Now I can run the perches anywhere on the shock body and not have loose springs. These Tarmac 3s are really for 08-14 STIs and so there maybe some travel and height differences between the chassis and RCE really wasnít sure why I was having the issue other than maybe i was trying to be a little lower than what they tested at on a VA and didnít realize they were at the threshold of lowering adjustment.
With all that said, problem solved, RCE gave me a thumbs up and Iím ready to get an alignment finally.
Hereís the different sets I tried.... RCE 20/60/80 (eibach I think), Swift 60-60-15, and Hyperco 4Ē 60mm.
(Iím still running Swift 60-60-15 helpers in the rear as they work great. Also, I was able to bring the perches up about 3/4Ē from the photo below due to the low stack height of the HyperCoís which was perfect while keeping same ride height as posted above.)
Old 07-24-2020, 01:22 AM   #262
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
When I was reading and comparing facts on various suspension bits, I came across hyperco, it was the first I ever heard of them. Seems they are great choice.
JDMJNKY is offline   Reply With Quote
Old 07-24-2020, 12:23 PM   #263
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Yes sir... I was trying to solve this stupid issue and stumbled upon them as well. I have seen them used on some higher end coilovers before but after looking into it more it seems they are super popular and trusted- Offroad/Nascar/IndyCar/Formula1/LeMans/etc... In fact, I found out that Swift is really not used in those professional arenas.
Maybe one day ill try a set of HyperCo springs and not just the helpers. They also have Hydraulic perches that eliminate lateral load which helps protect the shock and according to them "Enhancement of mechanical grip at the tire"... Pretty cool stuff: http://info.3dmmotorsport.com/hyperco-springs
Old 07-25-2020, 07:44 PM   #264
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
2018 front end installed
Need to pickup my 2018 STi lip from the dealer when it comes in and need to wash my car.
Paint seems to match really well. I was a little worried at first but my car is just so dirty itís throwing off my eye. Outside in the sun it looks great and matches very closely.
Iíll get more pics soon. It looks naked would a lip but overall so much better with fogs and signals deleted, STi fog covers, and FMIC visable now.
Old 07-25-2020, 08:58 PM   #265
CoronaWRX
Member#: 431618
2019 STI
CWP
Glad to hear the color matched, it looks great!
CoronaWRX is online now   Reply With Quote
Old 07-26-2020, 12:32 AM   #266
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Not sure on how I feel about the big mouth update, but to each their own lol.
https://youtu.be/RArjr-wrMiE
Now that I didn't see. Perches seem like a legit concept.
Old 07-27-2020, 12:56 PM   #267
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
I feel ya... I HATED the front end back in 2018. But with a lip, lowered, and with the STi fog covers it looks MEAN to me now and has grown on me immensely I also think its looks more modern vs the older 2015-2017 style.
I was going to sell my 2016 front end but I am going to hang on to everything now just in case I ever want to switch back.
Jeff
Old 08-01-2020, 12:43 AM   #268
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
2018 front lip came in and I got the Perrin Pitch Brace and Mount 😎
Old 08-01-2020, 09:58 AM   #269
milab21
Member#: 157833
2017 WRB STI
2007 WRB STI-sold
I haven’t researched this question at all but what did you use to get the blinker/turn signal in the headlights or did you not do that? I’ve been contemplating swapping to a 18+ front end myself and was curious what people do when they swap front ends
milab21 is offline   Reply With Quote
Old 08-01-2020, 10:22 AM   #270
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Originally Posted by milab21 View Post
I havenít researched this question at all but what did you use to get the blinker/turn signal in the headlights or did you not do that? Iíve been contemplating swapping to a 18+ front end myself and was curious what people do when they swap front ends
I retrofitted my halogen headlights- morimoto mini d2s etc and diode dynamics clight switchback for signals
Old 08-01-2020, 10:29 AM   #271
milab21
Member#: 157833
2017 WRB STI
2007 WRB STI-sold
Thanks for the info, much appreciated
Old 08-01-2020, 01:14 PM   #272
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Yes sir... also just had to install an LED Flasher relay to fix the hyper blinking from removing the lower signal bulbs. But all fixed now.
Old 08-01-2020, 01:50 PM   #273
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Jeff
I'm here for the ride man. I'll watch the vision unfold and cheer from my desktop.
Old 08-01-2020, 03:34 PM   #274
YungBoba
Member#: 450808
2017 WRX Premium
WR Blue Pearl
I love me some OEM lip. I miss when mine was that new. There are tons of brands that make lips in the exact same shape, but the little STi badge really makes it pop IMO. If I ever replace my lip completely, it will be with another OEM lip, just for that.
Let us know how you like the pitch stop brace/mount. I have the Group N trans mount and Whiteline crossmember bushings like you, but I've noticed some more sloppiness and jerking lately compared to when I first had it installed a year and a half ago. I'm thinking maybe some of the other OEM mounts are starting to deteriorate now, and am thinking of doing the pitch stop and motor mounts next.
YungBoba is offline   Reply With Quote
