Welcome to the North American Subaru Impreza Owners Club Thursday August 6, 2020
Old 05-25-2020, 09:58 PM   #176
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
That I understand, I guess you do sleep then.
D-Rodman is offline   Reply With Quote
Old 05-26-2020, 10:29 AM   #177
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Hahaha Yes, sir, I do.
JDMJNKY is offline   Reply With Quote
Old 06-07-2020, 01:19 AM   #178
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Looky here, still have popped the crank pulley or center timing cover off but It seems the timing may have jumped.
let's hope I'm really lucky
Old 06-08-2020, 01:00 AM   #179
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Hopefully there is no damage to the valves.
Old 06-08-2020, 09:35 AM   #180
WhiteZombie
Member#: 338863
PSM 05 WRX WGN 5MT
95 Caprice 6spd Track Rat
Was it all fresh timing equipment?
I've gotten lucky before with timing failures and only been off a few degrees with no valve contact......
WhiteZombie is offline   Reply With Quote
Old 06-09-2020, 11:45 PM   #181
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
I hope so, I had just moved off from a light when the car started going haywire in the running department.
Yes sir, all brand new. I'd never reuse a timing component unless I knew the day and date it was installed. They are all GMB parts as well.
I'm hoping there was no valve contact, but hey it is what it is. I was thinking of just building a fresh new EJ20 with a spare motor I've purchased from a buddy that needed HG's.
Just ordered a crank pulley tool today so we will see if the tensioner blew up soon enough.
Old 07-02-2020, 10:17 AM   #182
cknowlen
Member#: 189077
2011 STI limited
Any more updates as of late? Decide to drop the other motor in yet?
cknowlen is offline   Reply With Quote
Old 07-03-2020, 10:21 PM   #183
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
I have decided to build engine B for this car as well. I'm being driven insane. It will be a freshly assembled EJ20. The crank pulley won't come off and I've tried my darnedest. Logic, my free time is not so free right now, making my window of opportunity tight. If the motor has to come out, may as well drop another in. As for the engine coming out, it will be leak tested and if everything is alright a new belt and OEM tensioner will be installed and the engine included with the sale.
....which leads to these updates. Used USDM EJ20 I received in a trade for JDM fenders.
teardown
nooice.....owner claimed the engine had bad head gaskets. Didn't bother me one bit as the engine will be bored .020 over.
Cut wire shot processed factory rods, AKA shot peened. Come Monday I plan to let Bob at GE handle the machining.
  • Bore Hone
  • Line bore & hone
  • Re-seizing Rods
  • Balance rotating assembly
lastly, some fresh hardware.
Old 07-04-2020, 01:14 AM   #184
Matthew_02WRX
Member#: 507953
2002 Impreza WRX
Platinum Silver Metallic
Amazing project dude. I saw your pics with the wiring and I whenever something involves a lot of wiring, I get so flustered haahahaha . Nice find though, these cars are so hard to find at pick n pulls
Matthew_02WRX is offline   Reply With Quote
Old 07-04-2020, 12:59 PM   #185
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
You're not alone LOL. Thank you Matthew.
Old 07-09-2020, 01:23 AM   #186
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Crank for the EJ hot tank and polished, but I fear I may have put the cart before the horse as I plan to balance the bottom end.
I've also been working on the cylinder heads, focusing on radiuses as much as I can. I started with the most challenging cylinders first. Far from complete, just sharing where I'm at.
Old 07-11-2020, 08:06 PM   #187
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
short block is officially at GE.
Old 07-15-2020, 12:52 AM   #188
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
nothing fancy just some porting updates. I do not know why I'm obsessed with porting cylinder heads, it just is what it is.
Exhaust sides are almost done, but I'll need to get some more finishing bits. then I'll look into some chamber coatings.
and because I was missing the finishing bits, I started the intake side today.
Old 07-15-2020, 03:26 AM   #189
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
Nice work, wishing I had time/funds to do all the modding you're doing...I would do a bugeye with a jdm swap
murrdogg24 is offline   Reply With Quote
Old 07-15-2020, 07:45 AM   #190
cknowlen
Member#: 189077
2011 STI limited
wait a second here....don't you have a 2020 STI that you are already throwing a fair amount of parts at? Seems like you got the funds my friend.
Old 07-15-2020, 03:01 PM   #191
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
Not enough funds to have 2 projects at the same time
Old 07-15-2020, 03:26 PM   #192
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Thanks Murrdogg. I’m running short on both ��. Perks are, my skills allow me to do quite a bit of my own work. But, Now that the kids surely aren’t going back to school I’ll be shortening my work days 2-4hrs while having to come up with a curriculum.
Lies 2020 keep as driver, find a bugeye to mod.
Old 07-16-2020, 10:46 AM   #193
jvh22a
Member#: 34368
Can you show what you used for porting?
jvh22a is online now   Reply With Quote
Old 07-16-2020, 04:21 PM   #194
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Nothing special. This guy and finish with the sand paper rolls.
Old 07-22-2020, 10:01 AM   #195
jediwill89
Member#: 516318
2002 Legacy
Very nice build man
jediwill89 is offline   Reply With Quote
Old 07-30-2020, 02:01 AM   #196
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Thanks Will.
Made some progress on the heads this week, I'd like to haver them finished up and off to the machine shop by monday.
random snap of the seats as I start the bowls. This set of heads were horrible from the factory compared to the others I did for myself.
almost done.
