Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Old 10-21-2007, 08:33 PM   #1
KarmaWagon
Member#: 137945
2002 WRX ShgnWgn
Default System too lean, Cylinder 4 misfire and knocking sound...
I was driving out in the desert this morning and after about a half hour the check engine light went on. The codes were for a system too lean, and cylinder 4 misfire...and there's a knocking sound now from the bay...the car's driving just a little underpar...nothing extreme ...any ideas what the knocking sound may be and if its being caused by the misfire or lean? safe to drive?
KarmaWagon is offline   Reply With Quote
Old 10-21-2007, 08:36 PM   #2
MasterKwan
Member#: 98961
Hmm, off the top of my head I suspect you need a motor. Does the knock change directly with RPM? What kind of oil do you use and have you checked it recently?
It could also be timing belt tensioners but, engine knocks seems more common.
MasterKwan is offline   Reply With Quote
Old 10-21-2007, 10:05 PM   #3
KarmaWagon
Member#: 137945
2002 WRX ShgnWgn
yea...the knock follows the rpms...oil's up to date...engine knock means what? spun a rod bearing?
Old 10-21-2007, 10:09 PM   #4
MasterKwan
Member#: 98961
If you're sure it's not an exhaust leak then rod bearing would be my first guess. Not uncommon on 02's that are running 5w30 oil too. For desert use, the manual suggests a thicker oil (assuming it's really hot) like a 10w40.
"Oil Up to date" doesn't tell me you pulled out the dipstick and checked the level.
Old 10-22-2007, 12:14 AM   #5
02'subie dude
Member#: 131070
2002 Impreza WRX
Very dusty in the desert, check your air filter and maf. The maf resistor is transparent if you cant see it you need to clean it. Fixed my problem.
02'subie dude is offline   Reply With Quote
Old 10-22-2007, 07:00 AM   #6
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
check your plugs
compression test
and put a long screw driver to the intake runner
above the knocking cylinder and place your ear to
the screw driver...if you spun a rod bearing you will
hear it..as you already do..
Old 10-22-2007, 08:47 AM   #7
sandman1011
Member#: 88476
I had a similar problem, but instead of spinning a bearing, I scored a head when a bucket shattered. It gave much of the same indications (ran fine, rpm dependent). Good stuff, but just to add, change your oil. If there's metal flakes, it'll tell you what you need to know....
sandman1011 is offline   Reply With Quote
CEL - P0171 System too lean LTSmash Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 08-24-2011 06:43 PM
cylinder 4 misfire continues to baffle me, tuners and experts? KurtP Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 06-04-2010 11:51 AM
Cylinder 4 Misfire? knock on dyno... Sp00L Service & Maintenance 6 01-19-2009 11:52 PM
CEL- system too lean? Elite421 Service & Maintenance 2 03-26-2004 09:23 PM
System Too Lean Revisted: P0171 CEL Hank3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-11-2002 01:05 AM
