Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 02-14-2010, 04:57 PM   #1
mcganz121
Member#: 138569
2017 A4 Quattro
Default 09 wrx stock turbo 329whp
Event: Dyno Pull
Ambient Temp: 75 degrees Fahrenheit
Elevation: 15-45 Feet Above Sea Level
Weather: Sunny
Tires: Azenis 615
Tuner: Jon @ HB Speed
Dyno Info: Dynomite
Peak HP at RPM: 329 @ 6.2k SAE Correction
Peak Torque at RPM: 334 @ 4.5K SAE Correction
Baseline hp/tq for a stock on same dyno: 245whp
Target Boost: 18-19 PSI
Target AFR: ???
Fuel: Pump 91 Octane
Engine/Power Modifications:
Catless tbe
Perrin tmic
Walbro 255
Pnp header by wrxsubiemod
Harman cai
I know this is similar to a dynojet so the numbers are pretty high, but I was pretty amazed at the gain from so few mods. The car feels great compared to my old setup.... Ill post it below in comparison. The old setup was a catted dp, spt cb, and harman cai.
Future plans: inlet, injectors, ebcs, and maybe ewg (next year)
New:
Old:
mcganz121 is offline   Reply With Quote
Old 02-14-2010, 05:05 PM   #2
jordanretro1223
Member#: 143039
2007 STI
Impressive. Have fun man!
jordanretro1223 is offline   Reply With Quote
Old 02-14-2010, 05:18 PM   #3
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Nice.
godforbid67 is offline   Reply With Quote
Old 02-14-2010, 05:38 PM   #4
LVBugEyed
Member#: 186870
2010 WRX
how much boost would you need to be able to hit these numbers with a turbo inlet / fmic / ewg? All other supporting mods to ofcourse
LVBugEyed is offline   Reply With Quote
Old 02-14-2010, 05:41 PM   #5
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
Extraordinary...
What was the delta WHP from stock to current? Absolute WHP # are worthless w/o baseline # to compare
REDrum is offline   Reply With Quote
Old 02-14-2010, 05:46 PM   #6
mcganz121
Member#: 138569
2017 A4 Quattro
Not sure what the baseline is for an 09 wrx... Stock sti puts down 221/257 from what I have seen on a previous hb speed dyno chart.
Old 02-14-2010, 07:17 PM   #7
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
I call 'bull'. Not on stock fuel(ing). Or likewise, not on a *safe* tune. Whats your IDC???
My car also feels great compared to stock, so seat of the pants dyno's don't mean anything. Whats the car trap at? Any data logs to share?
scramjett is offline   Reply With Quote
Old 02-14-2010, 07:28 PM   #8
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Likewise. 330 whp on 91 octane with a VF52? What did it make before correction?
Byzantium is offline   Reply With Quote
Old 02-14-2010, 07:50 PM   #9
mcganz121
Member#: 138569
2017 A4 Quattro
Sorry guys dont have any other info. This is my fourth tune by hb speed and this nor my 06 ever had any problems.
Heading out to v-day dinner...
-Michael
Old 02-15-2010, 09:24 AM   #10
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
My dyno experience data points are all from Dyno Dynamics units and generaly stock engines/drivelines fall into the baseline standards (varriation +/- 5%):
2.0L WRX 02 to 05 = 160whp
2.5L WRX 06 to 08 = 185whp
2.5L STi 04 to 07 = 225whp
(Mustang dynos tend to read +15whp more than dyno dynamics)
Thus if Mcganz's WRX put down ~225 as a baseline (which means the dyno is waaay off), yes he could have pulled 325whp which means his mods gained ~100whp. But not 150whp w/o some combination cams/race gas/water-meth. Those turbos/heads just dont move that much air.
Old 02-15-2010, 01:32 PM   #11
fourmicah
Member#: 128760
2017 STI
^^^ I hate to jump in on most of these conversations, but I have to agree. I know a dyno is a tuning tool, but these numbers seem way too high without some kind of modification to the turbo, E85, meth, or some sort of race gas.
fourmicah is offline   Reply With Quote
Old 02-15-2010, 02:29 PM   #12
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
Tq curve and gain don't look right for E85 plus he'd need near 800cc injectors too, man that stuff is inefficient.
I'm not claiming/calling BS, but rather would like to figure out what caused such high dyno numbers. While we all tend to be skeptical about dyno numbers here, the tuner may be on to somthing new, the dyno is could be off, FHI changed somthing, or a combo plate of the above....
BTW....are the graphs in post #1 above actual whp or "corrected" chp?
Old 02-15-2010, 03:22 PM   #13
mcganz121
Member#: 138569
2017 A4 Quattro
its wheel not crank.... My tune is similar to Redzfit..
Look here
http://forums.nasioc.com/forums/show....php?t=1887005
Old 02-15-2010, 03:25 PM   #14
redzfit
Member#: 191518
2009 STI Hatch
Mcganz Congrats! Your car is making more power than mine with less mods. You can really see the difference in tq from the tmic and the fmic. You are making almost 60 wtq more than I am at 3k.
Hope your v-day dinner was good
redzfit is offline   Reply With Quote
Old 02-15-2010, 03:50 PM   #15
fourmicah
Member#: 128760
2017 STI
I agree completely, I spaced the injector size for E85, but your right. Either this guy is the Albert Einstein of tuning or something else is going on.
Old 02-15-2010, 03:57 PM   #16
fourmicah
Member#: 128760
2017 STI
Hey mcganz121, I don't mean to knock your set up, it looks sweet. The only thing that doesn't make sense to many of us is how the tuning was able to perform this kind of power on 91 Octane. I deal with the same crappy gas here is Utah which is why I would almost rather run E85, Hopefully your tuner will chime in on the set up/tune/correction factor used.
Old 02-15-2010, 04:00 PM   #17
mcganz121
Member#: 138569
2017 A4 Quattro
Yea no worries...
Maybe Jon will chime in.
Old 02-15-2010, 04:06 PM   #18
25rsti
Member#: 166324
Seems almost too good to be true. Though I/we need to remember dynos are only tools to be used and not get wrapped around the #'s. We all know stock STis (04-07) with the same mods barely see 300whp @ those boost levels. Anyways, you must be loving the way it turned out for you, with that amount of torque at 3k rpms must be amazing. Two thumbs up
25rsti is offline   Reply With Quote
Old 02-15-2010, 04:09 PM   #19
[D.I.]WRX
Member#: 116314
That's some awesome results. Them vf52's on the new WRx's are insane power makers. I'm jealous How does it compare to your 06 Wrx with a vf39?
[D.I.]WRX is offline   Reply With Quote
Old 02-15-2010, 07:25 PM   #20
fourmicah
Member#: 128760
2017 STI
This I understand, but when the numbers are this far north of the norm, questions need to be asked because it seems as though the correction factors are messed with to make it appear that the car is faster than it really is. Then you have a 330 WHP car that won't trap 99 MPH. Not saying this is that car, but it has been done.
Old 02-15-2010, 08:21 PM   #21
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
Those numbers really remind me of P&L started selling/tuning VF48's and they were making north of 320whp and touting it as good as an 18G.
As someone who has a VF48 (which is the same as a VF52 but for the flange), and having injectors, intake, full TBE, a FMIC..... My car doesn't make 18G power and I can tell you that being tuned on 93 octane, as I am tuned, +320whp ain't happening. Its a fun ride, but +320 is a bit much to expect from the tiny but capable vf48/52. And 300whp at redline...... No way! What is this, a 68hta?
Ah hell, we're all on the same Subie fan club at the end of the day! Ciao!
Old 02-15-2010, 09:29 PM   #22
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
wow mcangz and Redfitz your tuner in nuts!! my tuner deams 90% IDC to be safe. for me at 290hp and 311TQ thats only 17psi with catted TBE, CAI, UP, LWP, 255 pump and 3-port EBCS. theres no way you two are safe running 19-20psi!! forget the hp numbers, you guys have headers which ive heard can make a lot of power and torque so i cant comment. we tryed 18psi but the intercooler was to hot up top so we had to back off but we were hitting 225TQ around 3k ish. so your TQ seems right for 19-20psi. but again you guys have to be at 100-110% IDC=not good!
synolimit is offline   Reply With Quote
Old 02-15-2010, 09:32 PM   #23
Byzantium
Member#: 207826
85k 2002 WRX
PnPing headers are not done for power. It's done to decrease spool time. If he is making power from it, it's nothing to take notice of.
Old 02-15-2010, 09:37 PM   #24
synolimit
Member#: 225225
11 WRX
also has anyone else noticed the 7300rpm!!! funny how mine hits fuel cut 6500rpm
Old 02-15-2010, 09:38 PM   #25
synolimit
Member#: 225225
11 WRX
its still a some what rated 5-15hp and tq
FS:(CO) Stock 08-09 WRX TD04 Turbo HKSpowerWRX Engine/Power/Exhaust 7 04-04-2011 11:32 AM
09 wrx - stock turbo - 93octane - 290HP, 311TQ synolimit Proven Power Bragging 56 11-04-2010 06:21 PM
09 WRX stock turbo 312 whp, 352 wtq Innovative Tuning Proven Power Bragging 5 05-20-2010 08:43 PM
09 WRX stock turbo 293 whp, 304 wtq Innovative Tuning Proven Power Bragging 20 03-14-2010 09:43 PM
WTB: 06-09 wrx stock TD04 turbo eddie8890 Private 'Wanted' Classifieds 4 05-03-2009 10:17 PM
