Welcome to the North American Subaru Impreza Owners Club Sunday January 20, 2019
Old 10-21-2007, 01:13 AM   #1
NOMAD2023
Member#: 131276
2002 Impreza WRX
Question AAAAAHHHH!!!! Putting in Uppipe... Please Help!!!
Ok... So I have a 02 WRX. I have everything off that should... Took off IC... Than the Downpipe... And Manifold from underneath... I tried jacking the engine up after removing the engine mount... Oh, and of course I removed everything from the Uppipe... But I can't get the pipe to come out... It gets caught up on the turbo mount and the flanges on the uppipe won't let me pull it from underneath... I have taken everything apart and only need to get the Uppipe out to put in the new one and then put everything back together... I would hate to keep the old one in, just for the simple fact that everything is already apart... If anyone has any suggestions please help... I'm frustrated outta my mind... I would hate to keep the old one in just simply because i've but all the effort in to this point... Oh and i've considered the option of removing the turbo... And if it comes to that, than I will go through with it...
NOMAD2023 is offline   Reply With Quote
Old 10-21-2007, 01:16 AM   #2
slvrwrx03
Member#: 155183
there should be no need to take the turbo off did you unbolt the motor mounts before you jacked the engine up if you did you should have more then enough clearance to get the up pipe out when you unbolt the motor mount it creates the needed gap between the sub frame to drop the up pipe but if you dont un bolt the motor mount jacking up the engine wont do anything.
slvrwrx03 is offline   Reply With Quote
Old 10-21-2007, 01:18 AM   #3
NOMAD2023
Member#: 131276
2002 Impreza WRX
I did undo the motor mount... Is there another one that i'm missing...? The one I took out was the single bolt in the middle of the car, right behind the IC... I tried jacking the car up by the oil pan, exactly like the instructions suggested... Is there another spot I should try to jack it up from...?
Old 10-21-2007, 01:22 AM   #4
wrxracer519
Member#: 149890
09 Forester
Green
get a sawzall and cut the stocker in half, youll be done in 3 minutes. not the best way but the least frustrating
wrxracer519 is offline   Reply With Quote
Old 10-21-2007, 02:17 AM   #5
mikeyc
Member#: 32338
03 WRX Wagon
You know about the 2 mounts underneath the engine, right? That's what people are talking about. The one you undid behind the IC is a pitch mount. What instructions are you following? They should have gone over that...
mikeyc is offline   Reply With Quote
Old 10-21-2007, 03:54 AM   #6
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
^^^yeah dude if you look at the passenger side sub frame brace you will see a 17mm I think nut for one of the motor mounts. Remove that and jack up the motor acouple inch's and it should slide right out. Like Mikey said the one you took out is the pitch mount.
B00st3dWRX is offline   Reply With Quote
Old 10-21-2007, 10:12 AM   #7
NOMAD2023
Member#: 131276
2002 Impreza WRX
Nope... Didn't get the memo on the other two... The instructions I have are really well detailed... Except for that one part of information... So underneath the car there are another 2 bolts, passenger side right...? I'll go have a look... Thanks...
Old 10-21-2007, 10:34 AM   #8
Sausage
Member#: 104998
2007 vf39 SuperWagon
I haz teh bed gramers
when you jack the motor up, take off the bolt for the mount and loosen the others. THen put a sturdy piece of wood under the oil pan and start cranking slowly
Sausage is offline   Reply With Quote
Old 10-21-2007, 12:21 PM   #9
NOMAD2023
Member#: 131276
2002 Impreza WRX
I haven't had a chance to look under the car yet... But where exactly are the mounts located... I'm assuming the the bolts connected to the black metal attached to both sides of the car... I just want to make sure I have the right ones to loosen...
Old 10-21-2007, 12:52 PM   #10
Gfunk720
Member#: 42549
E92 M3 M\\\
2017 Outback Limited
Did you remove the sensor from the uppipe?
I remember mine getting caught up and preventing me from pulling it out. You shouldn't necessarily have to jack the engine up, but it will give you some more clearance. I remember mine required some combination of rotating and pulling
Gfunk720 is offline   Reply With Quote
Old 10-21-2007, 04:29 PM   #11
sharkmonkey
Member#: 118566
2005 WRX
It isn't a bolt that you have to loosen for the motor mount, it is a nut. It will come right out if you get that loose and jack up that side of the engine.
sharkmonkey is offline   Reply With Quote
Old 10-21-2007, 04:46 PM   #12
NOMAD2023
Member#: 131276
2002 Impreza WRX
No, I haven't removed the O2 senor yet... I thought about it, but the sensor socket i'm using won't fit around it because of the metal steam from it... I'm going to find the nut to raise the motor up, since now i've found that the only one i removed wasn't enough or even the right one... The other crappy part is getting to the 02 sensor to even remove it while its still in the car... How did you do it...? But thanks for everyone's suggestions... I'll let you know how it turns out...
Old 10-21-2007, 04:48 PM   #13
teiva-boy
Member#: 22825
Remove passenger side engine mount nut
Don't recall if the engine pitch mount had to be undone.. But do it just in case.
But jack up the engine, and with the uppipe completely unbolted...
rotate the uppipe 180, and pull it backwards and down towards the downpipe area.
Make sure you have the EGT and A/F sensor removed as well.
It's the rotation and removal from the rear that is important... If you don't remove the sensors, it wont rotate and come out.
teiva-boy is offline   Reply With Quote
Old 10-21-2007, 07:00 PM   #14
WRXislander
Member#: 50064
'12 WRX
(WRX#8, Subi#12)
pitch mount definitely doesn't have to be undone.
WRXislander is offline   Reply With Quote
Old 10-21-2007, 07:41 PM   #15
Gfunk720
Member#: 42549
E92 M3 M\\\
Since I never planned on putting the stocker back, I just cut it with some snips. Sure was easier than removing the sensor!
I fell your pain man, I pulled my up-pipe today cause I had my turbo out. Its an STI U/p and the heatshield was rattling like crazy. Only got half way through pulling the injectors and turbo because it took me like 3 hours to get the uppipe out and cut the stupid heat sheilding off. I hate this piece of the car more than any other I think
Old 10-22-2007, 04:04 AM   #16
WRB04
Member#: 153304
you can rent the o2 sensor socket form autozone and i didn't even unbolt the motor mounts on my buddys 05. we place a small piece of wood next to the oil pan directly on the block and lifted it slightly. turned the up pipe and it slide right out of the bottom. But it sure is easier putting everything back than it is take everything apart.
WRB04 is offline   Reply With Quote
Old 10-22-2007, 06:54 AM   #17
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
PWN3D up pipe removal
tools needed,
14mm 3/8 socket
12mm 3/8 socket
ratchet
14mm fuel wrench looks like open end.
flathead screw driver
pb blaster
10mm wrench & socket
car ramps
hydraulic floor jack
2x4 ~ 1' length
disconnect battery
after you remove the tmic & plastic under tray.
pb blast the heat sheild bolts around down pipe
remove heat shield 6 10mm bolts
pb blast down pipe bolts & nuts
2 bolts w nuts & 3 nuts at down pipe
pb blast the up pipe nuts
3 nuts
clamp off water lines
loosen and push oil line away abit
disconnect inlet hose
remove turbo
remove egt probe
you should not have to remove passenger side exhaust manifold
remove motor mount nut from bottom of front cross member
loosen pitch mount
place 2x4 on floor jack..
raise driverside about 4"
lift and rotate the up pipe toward the fire wall
that should do..
time require to complete, (if it is your first time ~ 3 hours)
my best time was 45 minutes..
good luck
Old 10-22-2007, 11:52 AM   #18
sharkmonkey
Member#: 118566
2005 WRX
22mm box end wrench and patience. It can be done.
need uppipe please help boostinwrixxer Newbies & FAQs 3 05-02-2008 10:44 PM
about to put in some parts, help! gi2005 AccessPort 3 11-05-2007 07:00 PM
Where to put jack stands??? Please help now. FearTheTurtle Service & Maintenance 2 06-17-2007 10:58 PM
Putting in uppipe... timman_24 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-29-2004 04:39 PM
If you have had a vishnu uppipe please help! Wheels Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-02-2002 07:33 PM
