Welcome to the North American Subaru Impreza Owners Club Monday December 17, 2018
Old 05-20-2010, 06:49 PM   #1
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Default 09 WRX stock turbo 312 whp, 352 wtq
Event: dyno tuning
Ambient Temp: ~72
Elevation: ~700 feet above sea level
Weather: partly cloudy
Tires: street
Car: 2009 WRX
Tuner: Mike at Innovative Tuning
Dyno Info: Mustang AWD 500 SE (not monkeyed with to increase numbers)
Peak HP at RPM: 312
Peak Torque at RPM: 352
Baseline hp/tq for a stock on same dyno: ~200 whp for STI 2.5L
Target Boost: 24 psi tapering to 17 psi.
Target AFR: changes depending on RPM and load
Fuel: 93 unleaded plus methanol injection
Engine/Power Modifications: stock turbo, Perrin big top mount intercooler, 3" turbo back exhaust, Coolingmist meth kit, cold air intake.
Driveline Modifications: ACT street clutch.
Suspension Modifications: not relevent
I took a little timing out near peak torque to make it a bit safer in that knock prone area, but otherwise this is a very aggressive tune. Darrell has a lofty goal of an 11 second pass in his stock turbo WRX so I focused on the mid range and top end.
He ran a low 12 without meth on the pump gas tune I made. This is a good sized step up from that so we'll see what happens. I also enabled launch control to help with consistency on the launch. Go Darrell!
Innovative Tuning is offline   Reply With Quote
Old 05-20-2010, 06:57 PM   #2
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
can you post before and afters? i think the HP went up like 19 and 48TQ but the mid range is there larger increases from all the boost and meth?
and Darrell can list all your mods, i think theres a few missing
iirc the gains look good after all that and with the new clutch 11's could be had.
synolimit is offline   Reply With Quote
Old 05-20-2010, 07:33 PM   #3
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Yup I forgot he mentioned his clutch was slipping some at the track. That had to be hurting, but who knows how much.
Old 05-20-2010, 07:49 PM   #4
synolimit
Member#: 225225
11 WRX
thanks! thats some good lookin gains for just meth and some boost. i take it the 650cc handled all that ok? i woulda guessed he'd need 850's or 1000's. unless i take it meth doesnt work like E85?
Old 05-20-2010, 08:11 PM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Did you guys push the stock intercooler at all before this? Just curious if you got the endtanks to pop...
Old 05-20-2010, 08:43 PM   #6
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
The methanol is injected by an external system made by Coolingmist called their CMGS kit for WRX/STI so the meth isn't flowing through the stock fuel system. It is also controlled independently. Meth is being injected on the cold side end tank of the intercooler in this case.
I snapped a pictured after we performed the install. You can see the nozzle for the meth kit on the right side end tank on the intercooler with a clear hose coming off it.
No sir. He was aware of the issue and the cooling limitation of the stock intercooler so that was upgraded quickly.
09 wrx - stock turbo - 93octane - 290HP, 311TQ synolimit Proven Power Bragging 56 11-04-2010 06:21 PM
MSPT Tuned: 2008 WRX (93 Oct, Stock Turbo) - 254 whp / 343 wtq [Dyno Dynamics] WRX SEX Proven Power Bragging 18 05-26-2010 01:01 AM
09 wrx stock turbo 329whp mcganz121 Proven Power Bragging 90 05-02-2010 05:17 AM
09 WRX stock turbo 293 whp, 304 wtq Innovative Tuning Proven Power Bragging 20 03-14-2010 09:43 PM
STOCK TURBO 312 WHP 375 on dyno jet SeanCuttaz Proven Power Bragging 70 09-11-2006 11:38 AM
