Welcome to the North American Subaru Impreza Owners Club Saturday December 15, 2018
Old 06-09-2018, 02:23 PM   #3451
3xsubarusvx
Member#: 487002
I need help with the 2 ecu wiring method 😪
3xsubarusvx is offline   Reply With Quote
Old 06-09-2018, 02:24 PM   #3452
3xsubarusvx
Member#: 487002
I need help with wiring soooo bad..
Old 06-09-2018, 10:32 PM   #3453
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
give iWire a call. they can set you up.
Titter is offline   Reply With Quote
Old 06-10-2018, 02:53 AM   #3454
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
You might have more success if you explain what 2 ECUs you're working with and what you're trying to do with them.
Old 07-03-2018, 09:59 PM   #3455
vicious_fishes
Member#: 158864
2003 SOHC destroker
Completely out of the blue I know, but I've had to do a head gasket this week so I've ordered a pull scale & will weigh the engine so we know how heavy it is once & for all.
Old 07-10-2018, 10:22 PM   #3456
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
^^^ And then ... ???
Old 07-13-2018, 04:17 AM   #3457
vicious_fishes
Member#: 158864
2003 SOHC destroker
And then the ebay seller is useless and it's a week overdue and still not here and I've had to install the engine in the meantime.
It'll be going back. >
Old 09-03-2018, 10:34 PM   #3458
Kito818
Member#: 480045
2009 2.5 Impreza>3.0
Dark grey/light black?
Hello everyone, I'm about to order my ez30 and trans, 2 more weeks, but I'm still trying to find an ECU I can use and keep OBDII for vehicle inspection. I was hoping I could repin the ECU in my car, until I saw how much of a joke that was since my ECU doesn't have pins for 6 injectors and coils, so I'm left with trying to track down something I can merge in. I have an 09 2.5i base model Impreza, I know an STI/WRX set up would be easier, but I also know what I'm trying to do isn't impossible. I'm trying to keep this a sleeper build. I don't want a bunch of lights on the dash and I will still have to go through vehicle emissions(OBD II check up).
I thought I would just go look for an ez30D(R) ECU, and repining it for the BCU in my car, but I can't seem to find the right ECU for sale anywhere. I'm feel like I'm close to the end of laying this build out on paper, but this is a big hurdle and I need some help.
Kito818 is offline   Reply With Quote
Old 09-04-2018, 07:09 PM   #3459
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
I just used this search - (tribeca, b9, outback) (ecu, ecm, pcm, computer) (3.0, 3.6, h6, ez30, ez30d, ez30r) - on Ebay Motors and found a bunch of them.
With that said, I think what you'd be looking to do would be very difficult. After all of these years I'm pretty sure I've still only seen 1 person successfully run a 2nd gen EZ30D(R) with a factory ECU, and they had to jump through hoops to make it happen.
Old 09-04-2018, 08:44 PM   #3460
Kito818
Member#: 480045
Are they someone on here that I could correspond with? I can handle everything but the lower end assembly of the motor, I dont have the right tools to properly measure all of that, or the experience to do it right, so I'm paying someone for that part, however, the wiring, upper assembly, fab work, and tinkering to make things just right, I can do all of that. I'm planning on going to Cobb for tuning down the road, but the ECU to BCU part is important for what I want so it's the hurdle you might have just helped with, thank you. Do tell me if there is a way to contact the other person.
Old 09-05-2018, 09:04 PM   #3461
Kito818
Member#: 480045
I've been thinking about this all day, but is there another way? Is there another way to stay OBDII and keep the lights off the dash in my car? Is there a standalone ECU I could use that supports an OBDII port for local emissions testing, that wouldn't freak the car out and turn my dashboard into a christmas tree?
Old 09-05-2018, 09:41 PM   #3462
RedMonkey999
Member#: 191476
2005 2.5RS
I believe the Link G4+ Xtreme supports OBDII through the CAN bus.
http://www.nzefi.com/product/link-g4...rade-features/
RedMonkey999 is offline   Reply With Quote
Old 09-05-2018, 09:44 PM   #3463
Kito818
Member#: 480045
Awesome, thank you! I'll be looking into this!
Old 09-06-2018, 09:59 PM   #3464
Kito818
Member#: 480045
https://www.ebay.com/itm/OBD-II-ECU-...cAAOSwus9bc52G
Very seriously considering this option to deal with the OBDII inspection for emission testing, thoughts on this?
This is the manual for the simulator and if I understand it correctly I could wire this to the OBDII port for inspections. Legal, no, but is it possible/would it work?
Old 09-11-2018, 10:11 PM   #3465
omiotek
Member#: 272090
2006 Subaru Forester
SGM
Originally Posted by jvangelder View Post
Started to make some headway. I decided I dont want to use the welded mounts and will make my own. My plan was to make an adapter to use an existing mount so I didnt have to re-invent the wheel twice. In my search for some reference photos I found that someone with a FF 818 did the same with his design adapting the group N mount, which will accept any other OEM style engine mount and he agreed to share his design with me.
This is where I am at now, The base's are over 2.5lbs each and the solid ej style mount is a lb which is heavier than I want, however I will verify the fitment before I spend time taking out weight.
Any news on these
omiotek is offline   Reply With Quote
Old 09-14-2018, 05:32 PM   #3466
jvangelder
Member#: 358395
05 STI
White with Rubber marks
Life got in the way, ive spent all spring / summer preping my house to sell. We move the 28th at which point I will have shop space at home which will make the long list of parts i need much easier to get to. Last event for the car is Oct 14th at which point the 257 will come out and ill be machining or fitting the mounts
jvangelder is offline   Reply With Quote
Old 09-16-2018, 03:20 PM   #3467
Kito818
Member#: 480045
I hope this works if the picture doesn't.
Old 09-16-2018, 10:30 PM   #3468
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Link works, embedded pic doesn't. 3D printed, I assume? That's pretty cool!
Old 09-17-2018, 12:48 AM   #3469
Kito818
Member#: 480045
I just revived a dormant Forceforge Creator Pro at work so I could learn 3D modeling and printing, that was the third attempt at a design. Tomorrow night I'll be reprinting it with the black base and red characters, dual media printer, once I can make that work I'll refine that to a badge that fits the trunk. I think I'm going to have to wait another two weeks to order my engine, we'll find out on friday though, so can't mount the badge yet anyway. I was curious what you guys thought, I like sleepers, but it wouldn't be horrible to have a proper badge for the car when it's done.
Old 09-18-2018, 03:04 AM   #3470
Kito818
Member#: 480045
Version 2, in two colors
Old 09-18-2018, 11:51 PM   #3471
omiotek
Member#: 272090
SGM
I can 3d print or machine these if it helps
Old 09-19-2018, 12:01 AM   #3472
Kito818
Member#: 480045
I dont have the machinery to make my own mount adapters for my install, would you mind if I hit you up when I get to that point?
Old 09-21-2018, 08:43 PM   #3473
jvangelder
Member#: 358395
05 STI
I appreciate the offer to have them printed but I have access to a 3d printer myself. I'm just holding off until I have the engine in so I can test the fitment. The model needs work any ways, i haven't touched it sense the pictures previously posted, and its pretty obvious it needs some work
Old 10-04-2018, 10:09 PM   #3474
omiotek
Member#: 272090
SGM
anytime. thats what i am here for .
Old 10-04-2018, 10:09 PM   #3475
omiotek
Member#: 272090
SGM
i have an engine
Vag-Com cable resource thread cooleys04 Open Source Reflashes 283 04-03-2018 02:04 PM
The Impreza @$$ Thread - The Beautiful Impreza Backside! PICS! Upscale_Automotive Member's Car Gallery 8 10-03-2007 05:56 AM
The 2008 Impreza Photoshop thread...post them here adizon Member's Car Gallery 307 09-20-2007 12:36 AM
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) wrxpeed News & Rumors 938 05-17-2005 12:11 AM
Photo - Anders "loving on" the H6 Impreza Fred South East Region Forum 8 02-23-2004 06:04 PM
