Welcome to the North American Subaru Impreza Owners Club Wednesday December 12, 2018
Old 05-18-2018, 04:01 PM   #1
pcampbell
Member#: 437670
2005 2.5 SC OB
Default Bung for wiper reservoir?
Hi,
Just purchased a snow kit and I want to tap into my stock wiper reservoir because I have no room for the one provided.
Should I find a bung which is the same size as the bung in their reservoir (not sure of the size off hand) or just tap something smaller , closer to the size of the line which is 1/4"?
pcampbell is offline   Reply With Quote
Old 05-26-2018, 03:31 PM   #2
pcampbell
Member#: 437670
2005 2.5 SC OB
Just realized the obvious. Canít install a bung in factory reservoir. No way to get your hand inside to install it. Duh.
Old 06-10-2018, 04:09 PM   #3
pcampbell
Member#: 437670
2005 2.5 SC OB
I figured where to put the tank
Old 06-11-2018, 02:56 PM   #4
pcampbell
Member#: 437670
2005 2.5 SC OB
Made one mistake. I trimmed off all of the tabs on the back side of the tank. I should have trimmed the bottom 2 off and bent the last one 90 degrees so I could screw into the firewall. Might be able to 45 degree a screw in there still.
Old 09-19-2018, 08:58 PM   #5
PDXREALTOR
Member#: 468393
2017 STI
Use some of the E6000 they sent you and attache a right angle bracket on the firewall side.
The E6000 will not let loose.
You shouldn't need a bung in the reservoir. Tap it, and use the E6000. Useful info should you ever decide to relocate to the wiper area.
ETA - wow- this section moves slow. I see Im about 3 months too late.
What is it with the lack of meth users? I couldn't stand having a turbo car and being stuck to pump gas. I'd sell it.
PDXREALTOR is offline   Reply With Quote
Old 09-19-2018, 09:50 PM   #6
pcampbell
Member#: 437670
2005 2.5 SC OB
Oh you know what I did basically just that. I took a small 90 bracket and wedged it between firewall and tank - not even attached to the tank in any way but the tank wants to push up against it. . On the other side itís just bolted through existing holes in area of shock tower with spacers. Itís very solid.
Old 09-20-2018, 12:08 PM   #7
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
You can fit a hex head bulkhead fitting into the stock reservoir.
File Type: jpg SMC Alcohol Injection Kit Subaru WRX.jpg (149.8 KB, 7 views)
