Welcome to the North American Subaru Impreza Owners Club Friday December 14, 2018
Old 09-18-2018, 09:24 AM   #1
fly_25
Member#: 467978
Default Deep/low aggressive vibration at certain speeds
Good morning all, my 2004 outback has a very aggressive vibration that can be felt in the seat at 80-90 km/h, not faster and not slower. It seems to get worse when I let off the gas within these speeds as the vehicle coasts. It's not engine related and I can't really feel anything in the gear shifter either (manual trans). Any ideas as to what could cause this? Also I swapped the wheels for a different set and still same problem
fly_25 is offline   Reply With Quote
Old 09-18-2018, 02:30 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Isolate the engine from the transmission. Get faster than the vibration speed, clutch in, and coast down through the vibration speed. See if anything changes. If not, it's definitely in the drivetrain. Given the observations, it's likely not the engine, this will confirm that.
One thing aside from wheel imbalance could be a driveshaft imbalance. You may have to get underneath, slowly rotate the driveshaft by hand (in neutral, rear wheels off the ground) and look for any sort of external balancing weight that's missing.
Look for any bushings in the drivetrain that are worn/missing. Rear diff, trans, and engine mounts are all I can think of at the moment.
Old 09-19-2018, 01:27 PM   #3
fly_25
Member#: 467978
It's definitely not engine related, I've had clutch in, out, coasting, nothing the engine does helps the vibration. Although the vibration is considerably worse when let off the gas and put the car under no load. I didn't notice any missing weights or anything unusual about the driveshaft, but what I did notice is that the driveshaft does not look like the stock driveshaft for this car. It's still a 2 piece with the carrier bearing but it just has a different design, maybe from another type of Subaru? Could the different driveshaft design cause the vibration?
Old 09-19-2018, 03:44 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Could it be?
Sure.
If it was fine before but sucks now, I will assume it was fine.
Maybe center carrier failed. In general, no decent way to fix that other than replace DS.
Stupid check, make sure DS hardware is snugged up.
Minimal play in DS (hard reach around exhaust, etc......).
Decide or check back.
A Subaru center bearing support is hard to do on your own. Really need to replace.
Yes, penny pincher hardcore may find a way, but........forget about it.
Old 11-11-2018, 09:49 PM   #5
fly_25
Member#: 467978
Bring this back, I was spending my time looking for a driveshaft and finally swapped out the driveshaft but the problem remains, same speeds, and vibration. So it was not the driveshaft that was the issue. Anyone ever experienced something like this?
Old 11-12-2018, 12:12 PM   #6
Broxh
Member#: 415302
2016 WRX
DMG
Have you changed your tires? Sounds like one could be slightly out of balance
Broxh is offline   Reply With Quote
Old 11-12-2018, 12:17 PM   #7
fly_25
Member#: 467978
Changed them out and still no change. I'm thinking maybe a rear CV joint? I don't feel any vibration in the steering wheel at all, only the seat and a low vibration sound
Old 11-12-2018, 11:39 PM   #8
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Could it be bad shocks?
I have seen cars with bad shocks the tires would bounce violently at highway speeds.
jasonwrx86 is offline   Reply With Quote
Old 11-13-2018, 12:20 AM   #9
fly_25
Member#: 467978
Could have been that if the vibration was at 100km/h and higher but it's only within 80-100 the car vibrates only when I let off the gas
