Welcome to the North American Subaru Impreza Owners Club Saturday December 15, 2018
Old 11-13-2012, 04:37 AM   #1
Bradrcr
Member#: 276382
2005 SaaBeeru
I'm working on a backseat tub for protecting my wagon and hauling. Since this requires the backseat to lay completely flat, the bottom of the backseat needs to be removed, and I wanted a fast, tool less option.
Tools needed:
Dremel with grinding stone
Grinding wheel for dremel or jigsaw
Vice or similar clamp
Needlenose or other small pliers
Drill with 1/8" bit
At Lowes or Home Depot pick up a pair of Cotterless 1/4 x 1 1/4" Hitch Pins and a pair of 5/8" D Rings:
Remove the 2 bolts holding the backseat down and insert one of the hitch pins in a hole, then pull it out until it catches. Mark with a sharpie just beyond the seat retaining bar:
Remove the loop and clamp or vice the pin, then score that sharpie point with the grinding stone to create a dip for the drill bit:
Drill into the pin, then cut off the pin about 1/4" down from the holes with the dremel or jigsaw. Score the cut end and the holes with the grinding stone:
Reusing the old loop won't work because it just sticks straight out when the pin is held tight. Open up one of the D Rings and then clamp it back down through the hole:
And here is how it looks installed, it is pressed all the way back, the D Ring holds against the seat metal quite well:
If you put anything of significant weight on the seat back, get a couple of body pillows for protection and resistance:
Bradrcr is offline   Reply With Quote
Old 11-13-2012, 07:38 AM   #2
tuzzio
Member#: 292532
05 STI
This is pretty cool.
tuzzio is offline   Reply With Quote
Old 11-13-2012, 11:55 AM   #3
T-37
Member#: 175624
0304 WRX WRX
SY WRB
Meh, the seat bottom is the easy part - it's just 2 bolts. The seat back is the bear, if anything.
Old 11-13-2012, 12:39 PM   #4
Bradrcr
Member#: 276382
2005 SaaBeeru
Fine, my next DIY will be a full track day quick release kit
Old 11-13-2012, 03:33 PM   #5
Zach Thomas
Member#: 278763
2004 WRX
My quick release (in a sedan) is leaving the bolts out PO stripped them out
Zach Thomas is offline   Reply With Quote
Old 11-13-2012, 03:46 PM   #6
Bradrcr
Member#: 276382
2005 SaaBeeru
If you're up for trying this with a 5/16" or 3/8" pin and drilling out if needed, post here if it works, i bet some guys with track days have the same issue. These pins are less than $2 apiece.
Old 11-13-2012, 03:53 PM   #7
Zach Thomas
Member#: 278763
2004 WRX
I might try it at some point, I have also considered something like this: http://www.cheapcycleparts.com/produ...Fal_Qgod0F0Avg
Kind of an expensive option though, you'd be amazed at how well the seat stays in place without being properly secured I really do need to do something though, empty holes bug me. What I'll like do is drill them to the next standard thread size and put stainless button head allen bolts in it or something.
Old 11-13-2012, 04:04 PM   #8
Leafy
Member#: 330625
2006 WRX
Do you have a measured length on this? There are significantly more lengths of these pins available from mcmaster than HDR. So its likely possible to have a no cutting required solution.
Old 11-13-2012, 04:49 PM   #9
Bradrcr
Member#: 276382
2005 SaaBeeru
I cut off about 3/8" from the 1 1/4" pin unfortunately, with different brands I bet the securing ball will be at different distances from the end. I'd say spend the $2 and measure one, a good enough online pic might be able to help you pin down the ball measurement.
Old 11-14-2012, 03:52 AM   #10
dinggoo
Member#: 295432
MBP
Im sure you could also find some wing bolts (like wing nuts but bolts ) and then you could put those in by hand and you wouldnt need any tools it would also stay threaded in.
dinggoo is offline   Reply With Quote
Old 11-14-2012, 12:25 PM   #11
05subysti
Member#: 268190
2005 STi
Lol wing bolts, that is very clever.
Old 11-14-2012, 01:44 PM   #12
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Too much work for 10 lbs.
Old 11-15-2012, 12:51 AM   #13
Justin V
Member#: 98747
07 WRX
I like this idea and want to do it with my rear strut bar.
Why didn't you just reuse the wire loop the pins originally came with? Its much prettier.
Justin V is offline   Reply With Quote
Old 11-15-2012, 01:08 AM   #14
Bradrcr
Member#: 276382
2005 SaaBeeru
I agree and planned to, but when the ball catches in the car, that loop stocks straight out, it's just too far. I'm hoping someone will see this thread and immediately think of a part that will work. I'm hoping to stop by Home Depot or Lowes and thumb through through their clips bin myself to see if I come across anything. I already know that a cotter pin with two points that can fit through the drill hole could be bent so the two points come through and then are bent opposite each other to brace the seat bar and the loop on the other side could be bent forward for a point to pull from. That's my best idea so far, just haven't been back to see if such a pin is readily available. If it worked right, you might even be able to slide that cotter pin around a washer like I've done.
Old 11-15-2012, 01:22 AM   #15
Leafy
Member#: 330625
2006 WRX
You could use a hair pin clip, you should find those in HDR right next to where you found the hitch pins.
Old 11-15-2012, 01:38 AM   #16
Bradrcr
Member#: 276382
2005 SaaBeeru
I think this is actually what I meant rather than a Cotter pin, for some reason I thought they had the same name.
Old 11-16-2012, 03:39 AM   #17
Bradrcr
Member#: 276382
2005 SaaBeeru
Ok, back to the HD, cotter pins were what I was looking for, but the D Rings were simpler, easier, and look WAY cleaner. Reedited the first post to instruct the use of these instead. If you've already made these, the D Rings are only 60 cents.
Old 11-15-2012, 01:26 AM   #18
kh15
Member#: 132400
2006 WRX
this is great! stripped mine out the first time I took my backseat out lol
kh15 is offline   Reply With Quote
