Welcome to the North American Subaru Impreza Owners Club Saturday December 5, 2020
Old 07-31-2020, 05:06 PM   #26
GrpB
Member#: 101976
Originally Posted by mitch808 View Post
I'm looking at picking up a micro mark mini mill (Based on the Sieg x2) locally. I'm interested in the hobby of making some things, small things that come up; that are beyond a hacksaw, a dremel, and an angle grinder, with a slight application of a drill and wire wheel....
I know that youtube has alot of content, but to me there's almost too much. And there are alot of small things that you would see in person that don't even know to look for on youtube.
You can sort of kill two or three birds with one stone if you find a small fab shop locally that will let you take scraps but also just look around and ask questions, like 'how did you do that', or 'why did you do it using X instead of Y'. Also you will inevitably need someone to make something for you because you lack time/equipment/knowledge so that same fab shop could be your go to. For example, they might do lathe work but you can do the welding/milling. Stuff like that. As long as you're respectful of people's time and have a good attitude in 'their house' it's amazing where you can just walk into by asking if you can take a quick peek in the shop.
GrpB is offline   Reply With Quote
Old 08-02-2020, 01:24 AM   #27
mitch808
Member#: 10228
2002 Subaru WRX
Originally Posted by GrpB View Post
I have an older Novakon NM200 mill that always had some weirdness but nothing I couldn't deal with for home/personal use. But just before Covid really hit the Z axis went completely haywire, swapping stuff around it was clearly a board issue and Novakon isn't great for support. So I decided to redo the controls, going from Mach to Acorn, going to a bigger AC spindle motor/VFD and reconfiguring the cabinet at the same time.
Just got it up and running and I'm very pleased so far, haven't made any chips but everything seems to work just a little better. Electronic/wiring stuff isn't really my thing so it took me longer than someone that has a knack for it but the Acorn documentation is amazingly thorough. And the user interface is also worlds better than mach. I feel cheated not having known about it sooner.
Pics of before/after cabinet, the wire runs could be tidier but I was starting to get impatient.
That is a cool upgrade! Beyond a couple of upgrades from the little machine shop, i might do a motor and controller upgrade using a treadmill motor. Its a far cry from what you’ve been able to do
mitch808 is offline   Reply With Quote
