10-25-2003, 03:24 PM | #1 |
Member#: 6363
Vehicle: 10 Sec. Club Element - Crawford |
Intake manifold with larger plenum?
Anyone knows if there is any difference in plenum size between US WRX, JDM WRX, JDM STI, Type RA and Type RA Spec C?
I am looking for an intake manifold with the largest plenum available. Will appreciate any help.
10-29-2003, 02:25 PM | #2 |
Member#: 821
Whats your thinking behind a larger plenum? I want the smallest one due to off throttle response. A larger volume will take longer to "empty" between shifts keeping your rpms higher thus beating on your transmission between shifts. Even with 9.5 opund flywheel, my 2.5 (still NA) takes a little less than a second to loose RPM if I hold a steady 3-4000 RPM in neutral and let off the accelerator.
While you may have a larger volume that keeps its pressure longer between shifts, it also takes longer to pressurize, so the gain is a wash. Depending which heads you have, the RS manifold will have the largest plenum, but may not fit the heads. Newer RS heads and US WRX heads (probably new body style rest of the world WRX as well) will interchange manifolds. 98 RS and older JDM/EURO/Aussi WRX/STi (old body style cars) will swap over too. Greg |
10-29-2003, 02:50 PM | #3 |
Member#: 6363
PMd You
JDM v7 Intake Manifold with TGV-less housing aka COMPLETE | quadzilla | Private 'For Sale' Classifieds | 17 | 07-25-2006 10:07 PM |
JDM intake manifold with no TGV's | jetfan8178 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 20 | 05-25-2006 07:26 AM |
wtb: jdm ver. 7 intake manifold WITH risers and ecu | legacy2003 | Private 'Wanted' Classifieds | 2 | 02-22-2006 02:41 PM |
FS:2000 2.5RS Intake Manifold with Vishnu Rails, SS Lines/Aeroquip Fittings | latinskllz | Private 'For Sale' Classifieds | 0 | 10-27-2004 10:52 AM |
wrapping intake manifold with header wrap? | Jejunum | Normally Aspirated Powertrain | 8 | 07-13-2004 03:20 PM |
