Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 05-21-2018, 11:22 PM   #1
mjm4jc
Member#: 241731
1997 Impreza Sedan
Turquoise
Default exhaust system help
Hello everyone,
Looking at an 09 Impreza sedan for my daughter. The lady that is selling it said that her son removed the resonator. I only see one catalytic converter on the car........the one that's built in to the manifold. There is a bulge in the middle pipe, but it doesn't look like a converter. I also do not see a bung in the pipe for an O2 sensor in that middle pipe. Wondering if he removed the cat and resonator? Can anyone help?
Thanks!!
mjm4jc is offline   Reply With Quote
Old 05-22-2018, 12:53 AM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
I believe that basic design is similar to the older ones.
The CAT's are forward of the spring loaded donut joint sorta under the front edge of the passengers seat.
After that joint, there is the midpipe with resonator, then the axle back.
Old 05-22-2018, 10:49 AM   #3
mjm4jc
Member#: 241731
1997 Impreza Sedan
Turquoise
So you're saying for sure that there should be 2 cats? The entire system should have 2 cats and a resonator?? That's pretty much what I've been reading and also what the diagrams are showing. Can anyone else confirm??
Old 05-22-2018, 02:30 PM   #4
GEE-OTTO
Member#: 201277
2008 08 QSM 5MT LGT
QSM
On that model Impreza the main converter is the one you saw integrated into the manifold it houses the AFR and O2 sensor (one sensor pre and post cat or the first bulge) the secondary cat isn't monitored by a sensor but rather it is a secondary converter that help further clean up exhaust gases once it hits 900F. The resonator is the big flat bulge in the center pipe.
So both sensors are right up front and you can see both by opening the hood and looking down in front of the passenger side timing cover, the harness for both connections is mounted there.
GEE-OTTO is offline   Reply With Quote
Old 05-22-2018, 03:28 PM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Cool
Thanks, I don't deal with newer Subaru much.
In general, I think I had it covered, but you provided much better info.
Thanks again.
Old 05-22-2018, 04:40 PM   #6
mjm4jc
Member#: 241731
1997 Impreza Sedan
Turquoise
Thanks everone. Gee-otto.....that was a big help. I went out and looked and saw both O2 sensors on the manifold cat. From what else I see, it appears that the resonator has been removed. Please see pics to confirm that the middle pipe has a secondary cat.
Thanks!
Old 05-22-2018, 04:58 PM   #7
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Without doing my own research, midpipes do NOT have CAT's.
Why?
They need heat.
The further from the engine, the cooler the exhaust, thus a CAT won't work.
Go back to my earlier post, CAT's are BEFORE the spring loaded exhaust connection.
How about looking up your exhaust on RockAuto.....see where the bits are?
Have a good day.
