Welcome to the North American Subaru Impreza Owners Club Sunday September 23, 2018
Old 07-07-2016, 02:21 AM   #1
kyd
Member#: 295685
2011 WRX
Default 2011 WRX Borg Warner S200SX-E/S257SX-E 20psi on 93oct
Car: 2011 WRX
Tuner: E-tuned by Eric @ Torqued Performance
Dyno: Mustang Dyno @MR Performance in Westbury, NY
Weather: 80ish, Sunny
Transmission: 2011 STi 6 Speed from Rallispec
Mods:
Stock Motor
Black Label Fab and ECS Performance Turbo Pedestal/Rotated Adapter (turbo-kits.com)
Borg Warner S200SX-E/S257SX 57/61, AGP's .82 A/R
Grimspeed EWG Upipie
Tial 38mm Wastegate
Modified 3" Tsudo Downpipe
Invidia Q300 Catback
Synapse Synchronic BOV
Grimspeed EBCS
GM IAT sensor
Omni Map sensor
Speed Density tuned via Cobb V3 by Eric @ Torqued Performance
IAG Catch Can
ID1000 Injectors
DW 65c Fuel Pump
Southbend Stage 3 Daily Clutch
OEM Flywheel
At 20psi
394whp/ 390wtq with filter on (red line)
398whp/ 401wtq with filter removed (green line)
looks a bit laggy on the dyno, but I'm seeing 20psi ~4k rpm on the street
kyd is offline   Reply With Quote
Old 07-07-2016, 02:07 PM   #2
REDCHARGE
Member#: 187304
Your gonna lift the heads on that stock motor , start saving for a block.
REDCHARGE is offline   Reply With Quote
Old 07-07-2016, 02:08 PM   #3
REDCHARGE
Member#: 187304
Old 07-07-2016, 03:04 PM   #4
BroBroBroBroBro
Member#: 338211
2011 wrx cobb 20G
lots of people will wanna copy this setup. a little custom work to make it happen and pretty easy hp.
BroBroBroBroBro is offline   Reply With Quote
Old 07-07-2016, 04:53 PM   #5
kyd
Member#: 295685
2011 WRX
Already in the works
The setup in parts, install and fabrication ran me less than $2500.
Old 07-07-2016, 05:04 PM   #6
rexblake
Member#: 178426
2010 S4
Gray
Very impressive setup.
rexblake is offline   Reply With Quote
Old 07-07-2016, 05:04 PM   #7
everkain
Member#: 84150
2013 WRX Hatchback
i was thinking of doing something similar since i have a tomei elh and they dont make a 3 bolt rotated upipe. what did you do for the downpipe to rotate it? With the extra height from the pedestal mount, does the downpipe still line up with the catback?
everkain is offline   Reply With Quote
Old 07-07-2016, 06:04 PM   #8
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
How do you think the pedestal adapter compares to a true rotated kit?
rexworx is offline   Reply With Quote
Old 07-07-2016, 07:58 PM   #9
kyd
Member#: 295685
2011 WRX
MR performance basically fabricated a half a downpipe and welded it to my existing downpipe so it fit like stock.
Well I mean I think the performance is very similar to a true rotated set up, but I haven't seen any rotated kits with the same turbo as mine. Only thing is that this adapter makes it near impossible to fit an inlet onto the turbo. But since I'm speed density tuned it didn't bother me. I've been told that if I unbolted the ABS unit and shifted it over a few inches I'd have enough clearance for an inlet.
Old 07-07-2016, 10:37 PM   #10
ericz
Member#: 224467
2005 CGM STI
93 4Runner 1JZ swap
Looks good. I've been wondering about these as a budget option.
ericz is offline   Reply With Quote
Old 02-15-2018, 02:07 PM   #11
adam sti
Member#: 457414
2004 STi
May I ask why you are on an E tune?
adam sti is offline   Reply With Quote
Old 02-20-2018, 09:51 AM   #12
kyd
Member#: 295685
2011 WRX
I was happy with Ericís e-tunes, he tuned the car ever since I purchased it. His service was great.
Now the car is built and was tuned on a dyno.
