Mid Atlantic Impreza Club Forum sponsored by Annapolis Subaru |
09-05-2017, 03:42 PM | #1 |
Member Sales Rating: (51)
Member#: 187877
South East
Vehicle:2004 FXTi |
WV: 1999 & 2000 RS Coupe Part Out
Parts list & pictures updated: 7/25/18
Parts are from 1999 and 2000 RS coupe both 5 speeds. Located in Fairmont WV & shipping isn't a problem just message me for a quote. If you want pictures of a certain part just ask. Thanks, Tony *Links to albums of individual pictures of each part are located beside each group* GC Parts Engine & Drivetrain Pics: https://imgur.com/a/F23PkWq ***8226; Main pulley $15 ***8226; Intake manifold $50 ***8226; Engine harness $50 ***8226; Rear subframe $40 ***8226; Front subrframe $80 ***8226; Rear differential carrier 'T' subframe $50 ***8226; Rear differential $75 ***8226; Transmission subframe $25 ***8226; RWD converted 5 speed transmission $400 ***8226; Transmission mount $20 ***8226; Purge valve solenoid $15 ***8226; Air assist injector #16632AA001 $15 ***8226; Gas cap $10 ***8226; Fuel pump assembly with pump $20 (1 piece broken) ***8226; Fuel lines $50 ***8226; Injectors $40 set ***8226; DW200 $50 ***8226; Clutch master $30 (2 available) ***8226; Slave cylinder $30 ***8226; Steering rack $75 ***8226; Throttle cable $10 (2 available) ***8226; Alternator $40 (2 available) ***8226; Power steering pump $70 ***8226; Power steering reservoir $15 ***8226; Power steering reservoir bracket $5 ***8226; Ignition coil $20 ***8226; Coil packs $40 set ***8226; Throttle body $20 ***8226; Oil fill neck and cap $15 ***8226; Cam gears $10 ***8226; Axle with one busted joint $25 ***8226; Intake silencer $10 ***8226; Coolant overflow tank $10 Suspension & Brakes Pics: https://imgur.com/a/vaSJf0R ***8226; Struts & springs $200 ***8226; Sway bars $40 each ***8226; Lateral links $20 each ***8226; Trailing arms $40 set ***8226; Endlinks $20 set ***8226; Control arms $25 each ***8226; Brake booster and master $40 ***8226; WRX rear calipers $50 ***8226; ABS module $40 ***8226; Front ABS sensors $15 ***8226; Front brake caliper mount $5 Exterior Pics: https://imgur.com/a/l3wK1sO ***8226; Depo glass driver side headlight $100 ***8226; Scoop $75 ***8226; Hood vents $40 ***8226; Vent tray $15 ***8226; Doors $100 ***8226; Rear bumper $100 (2 available) ***8226; Front bumper beam $75 ***8226; Black trunk with small wing (no dents needs repainted) $50 ***8226; Blue trunk with small wing (has few dents) $50 ***8226; Passenger fender (dent behind headlight) $25 ***8226; Inner fenders $10 ***8226; Door windows $40 each ***8226; Hood release cable $10 (2 available) ***8226; Roof trim $40 each (Shipping is expensive due to size) ***8226; Windshield trim $25 each ***8226; Wiper cowl $40 ***8226; Wiper motor & linkage $40 (2 available) ***8226; Sunroof $100 ***8226; Taillights $80 ***8226; Taillight trim $25 set (2 available) ***8226; Quarter panel trim $10 each ***8226; Blue gas lid $15 ***8226; Hood prop $5 Interior Pics: https://imgur.com/a/zlSelwm ***8226; Rear Dash $40 ***8226; Radio & HVAC trim $25 ***8226; Steering Wheel $20 ***8226; Driver airbag $40 ***8226; Dash bar $50 (2 available) ***8226; Trunk side panels $15 each ***8226; Rear seats $50 ***8226; Hood release handle $5 (2 available) ***8226; ECU cover $10 ***8226; Ebrake handle $20 ***8226; Door kick panels $10 each ***8226; Wire covers for inside door kick panel $10 side ***8226; Fuel pump cover $5 ***8226; Gas pedal $20 ***8226; Blower motor $50 ***8226; Dash cup holder $10 ***8226; Rear view mirror $20 ***8226; Interior lights $10 each ***8226; Seatbelts $40 (no driver front but have the rest) ***8226; Steering column $50 ***8226; Speaker brackets $5 set (2 available) ***8226; Weatherstripping $5 ***8226; Tweeter cover $10 each ***8226; Door handle trim and pocket $10 set ***8226; Visor clips $5 set ***8226; Jack $10 ***8226; Shift knob $10 ***8226; Door panel bolt covers $5 set ***8226; Door panel brackets $10 each ***8226; Door mirror cover $5 ***8226; Gauge cluster trim $10 ***8226; Seat bolt covers $10 set of 4 ***8226; Rear speaker covers $10 set ***8226; Passenger A pillar $15 ***8226; Rear heat vents $20 set (2 available) Electronics Pics: https://imgur.com/a/3779vWz ***8226; Knock sensor $10 (2 available) ***8226; Sunroof harness $10 (2 available) ***8226; Cruise control unit #87022FA110 $20 ***8226; Interior fuse box $20 ***8226; Engine bay fuse box $20 ***8226; Door ajar sensor $10 ***8226; Fog light switch $10 ***8226; Horn and cruise control steering wheel switch $20 ***8226; Cruise control dash switch $10 ***8226; Hazard switch $10 ***8226; Antenna with screws $25 ***8226; Headlight switch $20 ***8226; Wiper switch $20 ***8226; Airbag sensors $10 each ***8226; Airbag harness $25 ***8226; Airbag control unit $25 ***8226; Main harness $50 (cut by driver headlight) ***8226; Alternator to battery cable $10 (2 available)
09-05-2017, 03:43 PM | #2 |
Member#: 187877
South East
Vehicle:2004 FXTi |
https://i.imgur.com/naI7VBw.jpg https://i.imgur.com/5f77k2K.jpg https://i.imgur.com/xIZr8l6.jpg https://i.imgur.com/IdFSp2d.jpg https://i.imgur.com/Go0zJmu.jpg https://i.imgur.com/uOi3Ki2.jpg https://i.imgur.com/glocydX.jpg https://i.imgur.com/XEGuJ7c.jpg https://i.imgur.com/PqUsSSi.jpg Last edited by BlobeyeSTi; 06-28-2018 at 01:35 PM. |
09-08-2017, 10:41 PM | #7 |
Member Sales Rating: (131)
Member#: 72891
Vehicle:2018 STI 99 2.5RS 2dr - 2017 XV |
Looking for the following. 99 front axle, defroster switch, left roof molding, and trunk floor carpet. Maybe a few other things.
