Welcome to the North American Subaru Impreza Owners Club Saturday November 28, 2020
Old 11-15-2013, 04:32 PM   #1
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Default Why you don't need GR (11mm) Oil Pump in GD (10mm) Engine
Old 11-15-2013, 04:36 PM   #2
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Opening clearances by a couple thousandths is nothing compared to dual AVCS requirements, and certainly doesn't require the extra +30% in flow that the 11mm pump is capable of putting out.
Old 11-15-2013, 04:38 PM   #3
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Plus running an aftermarket ball bearing turbo uses a smaller oil restrictor, requiring less flow.
Old 11-15-2013, 04:47 PM   #4
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
Where is that oil pressure gauge installed? Idiot light plug right above the pump?
morrocco88 is offline   Reply With Quote
Old 11-15-2013, 04:54 PM   #5
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
I have thought this is an interesting topic for awhile now because its nearly a default to get an 11mm pump if someone builds a block these days.
I was criticized over and over about getting the 10mm, seeing "oiling is such an issue" on our motors
Pretty sure the pump is FAR from the weak link. Rev her to 8k everyday, have your pan/pick-up/baffle along with the Perrin AOS and my oil system seems to be issueless thus far (8500 miles going hard).
Scuby04STi is offline   Reply With Quote
Old 11-15-2013, 05:30 PM   #6
mboulton
Member#: 174433
More details about setup please. I don't see that kind of drop on my built 2008.
mboulton is offline   Reply With Quote
Old 11-15-2013, 05:39 PM   #7
Paidfor
Member#: 267815
Be in awe
dont hate .)
How does having too much flow make the pressure drop?
Confused about that gauge fluctuating..............never seen this.Wouldnt this be more of a cracked pickup issue?
Old 11-15-2013, 05:58 PM   #8
Th3Franz
Member#: 37146
2005 Legacy GT
Stage tree fitty
My single AVCS engine does not exhibit that behavior with an 11 mm pump. Oil pressure is rock steady and in line where it should be. Ball bearing turbo also.
My oil pressure gauge sender is installed at the top of the block, where the factory sensor used to be.
Th3Franz is offline   Reply With Quote
Old 11-15-2013, 06:01 PM   #9
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Dusty
That's not a pump issue, that's a gauge sender issue. You likely have a wire grounding out, or a sender that's having issues. Oil would not fluctuate like that at constant low revs.
The only other issue MIGHT be the by-pass valve sticking closed in the pump, but that seems rather unlikely.
subydude is online now   Reply With Quote
Old 11-16-2013, 05:51 PM   #10
lee586
Member#: 212926
97 Wrx
I agree, I had sender issue like this to.
lee586 is offline   Reply With Quote
Old 11-15-2013, 06:36 PM   #11
the suicidal eggroll
Member#: 51961
2005 STi
The pressure on my '05 doesn't do that. It does fluctuate a bit, but it's more of a slow oscillation up and down a few psi. The stock 10mm pump had the exact same oscillation on my car too, it was nothing new with the 11mm that I installed with the built motor. The video in the OP looks like more of a gauge or bypass problem to me.
Old 11-15-2013, 08:00 PM   #12
subydude
Member#: 80649
Dusty
The oscillation is normal since the pump "spurts" kind of like a heart. If the gauge doesn't have a reducer or isn't programmed for that you'll always see some oscillation.
Old 11-15-2013, 08:19 PM   #13
Justin V
Member#: 98747
07 WRX
The video is a GR by the gauge cluster, so I really can't tell what it is trying to prove.
My friends oil pressure was a bit weird with her build and prosport gauge. It dropped scary low sometimes then seemed to perk up and stablize.
I've heard of the bypass valve sticking too, don't know how common it is though. My next pump will be taken apart and checked before install.
Justin V is offline   Reply With Quote
Old 11-15-2013, 10:49 PM   #14
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Some great speculation and guesses here. Lets see if we can fill in some blanks
Yes. This is the best place as it's immediately at the pump's output before distribution to the different galleries.
^ Rock on Mr Man!
Setup is stage II+ 2012 STi. If you emulate these conditions I'm very certain you'll see nearly the exact same thing.
Too much flow doesn't make the pressure drop. The AVCS exhaust cam solenoid DOES cause the pressure drop. What you don't see in the vid is that I am at cruise and then I lift off. AVCS solenoids open, pressure drops 40psi!
It won't drop because you don't have dual AVCS, but because you ARE pumping +30% more oil, it's just going through your bypass valve. Adding heat you wouldn't normally add, and at high RPMs you can experience a pressure drop due to aeration, unless the pump/bypass has been properly ported
No sender issue, no gauge issue. It's got a Killer B Pickup installed of course Everything works just as it should.
Again, you won't see those fluctuation with a GD because there is no dual AVCS. Fluctuations you see are likely due to the bypass regulating pressure.
Observed oscillations are due to bypass valve operation typically. The pump squeezes oil MANY times per revolution of the crank. It happens much too fast to see or for a typical gauge/sensor to react to.
Just showing the reason an 11mm pump IS needed in GRs
Old 03-11-2017, 05:38 PM   #15
AndrewD5418
Member#: 366602
^ Rock on Mr Man!
So, an 11mm pump is only needed on a GR sti with dual avcs, correct? The wrx stick to 10mm?
Sorry for bringing back from the dead. Hah.
AndrewD5418 is offline   Reply With Quote
Old 11-15-2013, 11:01 PM   #16
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
Mine doesn't drop that much when I lift off of the throttle, more like 20 psi. I make around 90 psi at redline, 80 psi at any rpm above 2800rpm. I'm not concerned with the oil pressure dropping on throttle lift. Yeah it sounds scary, but it really isn't, and it doesn't drop the instant you lift. You have to lift and engine brake for a while. Even then, the load on the engine is very low, it's spinning fast but there isn't nearly as much bearing load so you don't need the pressure that you would if you were WOT. When the exhaust side fully retards it helps slow the car down faster. 30% more oil flow makes up for the pressure drop.
Old 11-15-2013, 11:16 PM   #17
vicious_fishes
Member#: 158864
2003 SOHC destroker
fwiw i ran the stock 8mm pump when i boosted my N/A EJ251. would only lose oil pressure once the oil got really, really hot. installed an oil cooler and problem solved.
no idea how different the demands are on the N/A donks with SOHC heads though.
Old 11-15-2013, 11:42 PM   #18
mboulton
Member#: 174433
Ok. I have a GR with sensors on the head and block galleys because Chris mentioned this stuff previously. Yet I cannot get such a pronounced drop under various conditions.
Not sure I am a believer.
Please reply with the exact testing conditions so I can try to reproduce it. I have rapidly responding sensors but have not seen anything widely close to what you demonstrate on the video.
Not dismissing, just doubting the conclusion.
Mel
Old 11-16-2013, 12:09 AM   #19
Th3Franz
Member#: 37146
2005 Legacy GT
Stage tree fitty
It sounds like this thread is misleading. It appears it should instead be titled:
"Why you shouldn't put a GD (10mm) oil pump in a GR (11mm) engine."
Also, correct me if I am wrong, but won't it only bypass if the pressure is higher? How is only 30% more flow a bad thing? And why do some well-known engine builders recommend a 11mm oil pump in a GD engine?
Old 11-16-2013, 02:03 AM   #20
subi400
Member#: 216984
1996 Impreza outback
Green
That is because these so called engine builders don't understand that if they want more oil to the bearings and such that the bearing clearances need to be opened up some to allow the full flow from the pump to reach the bearings, allowing a stronger film of oil and effectively removing more heat. There won't be more flow or pressure to the heads because only so much can go to the heads. 30% more flow is bad when the engine doesn't need it that's why. I have seen hybrid builds revving to 9k with a 10mm oil pump with plenty of flow and pressure and they run great. Now explain that. Since that is the case, then why would they need a 11mm pump?
The argument that "hey look the oil pressure isn't that high as rpms go up" with a larger pump, but that doesn't fly..., because the extra flow and pressure is going through the bypass.
For reference, I was seeing 97 psi at 6-6.5k rpms on my 2.5 na engine with 2.2 heads and hla's with a new wrx 10mm oil pump with 2 stock shims. Mains were around 0.0024 on a cold block and around 0.002 for rods. Going a bit tighter this time around.
So, how in the world does a 02-05 wrx owner need more oil pressure and flow or a hybrid owner either stock redline or higher need much more flow or pressure when the 10mm pump puts out plenty? Even the 04-07 sti has a 10mm oil pump. So this issue really is quite simple, but people don't want to learn about what is TRUE, or simple just want to use something because they have the idea stuck in their head.
There was a known guy on here running a 11mm pump and they had 70 psi or so at 7 or 8k rpms. The pressure should of been at least 90+ psi. I believe this person was experimenting with the 11mm pump to see what it would do.
There are a lot of opinions out there and very few people that understand what is and what isn't. KillerBmotorsport is one of those few people that understands it.
Old 11-16-2013, 09:36 AM   #21
mboulton
Member#: 174433
I understand fully the concept. I simply have not been able to reproduce the drop in pressure as the avcs changes intake and/or exhaust timing. Because Chris has mentioned this before, I set out to experiment and investigate this. Hence why I am requesting the conditions of testing so that I can try to replicate. I do have a P&L modified 11 pump however, and a custom Cobb tune that won't allow me to look at the AVCS tables. It is possible that my tuner has limited the amount of advance or retard thereby not 'demanding' so much oil diversion and hence the lack of a measurable drop.
Once I have a better explanation of the testing conditions I will try again and report. I will try to log rpm/load/oil pressure/and avcs simultaneously. That should help with understanding.
Mel
Old 11-16-2013, 11:40 PM   #22
mboulton
Member#: 174433
Okay. Eyeballing my gauges at about 2000 rpm in 3rd gear, if I let off the gas from a cruise situation the exhaust AVCS drops from 24 degrees to 0. The head oil pressure drops from around 50 to maybe 10 in a flash and then almost instantaneously rebounds back to 50. The block oil pressure measured at the rear right galley does not change at all. The head oil pressure appears to parallel the very fast AVCS timing changes.
I will try to get a video of it, and perhaps a true data log.
Mel
Old 11-17-2013, 11:01 AM   #23
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
The video isn't meant to scare people and you're absolutely right. The flow compensates for the AVCS demand, which is exactly why these pumps belong on GRs.
Mel
Low speed cruise, 4th gear. There are pressure drops like this all over the RPM/load range, but under these particular conditions the drop is near its highest.
Well said and sadly too true. If you're shopping for a builder and they include an 11mm pump on GD builds, ask why. If they give you the 'bigger is better' routine (with clearances opened up less than .002), or can't tell you why you need+30% more flow, or can't tell you what the different flow rates/pressure ratings are for pumps the different pumps then look for another builder.
Maybe the title should be changed?
The 30% more flow isn't going into the engine, it's going through the bypass and recirculating immediately back into the pump. Everytime oil is squeezed through those pump gears it adds heat so the less you can recirculate over and over and over, the better. The bypass also has poor flow characteristics and if you push enough through it, will aerate causing a pressure drop. Cold pressure can max the bypass causing seals to leak and/or overwhelm the turbo seals causing smoking (this is fairly well documented).
Mel
Mel, low RPM low load. Lift and the pressure drops. I have no idea how your particular tune may effect these variables. The P&L pumps do not follow OEM specs so that will also effect your results. It is odd that you're only observing the pressure drop in one location. Are your sensors calibrated to the same specs. Can you log them, swap the locations, and exactly duplicate your logs?
It's not a sender problem.
Mel
When you lift it should drop and when you put any throttle back in it should recover. Basically following the cam timing, as designed
Old 11-17-2013, 11:38 AM   #24
sidewayz
Member#: 5810
2001 S366 2.5RS
So it has nothing to do with the garbage sensors stri uses?
sidewayz is offline   Reply With Quote
Old 11-17-2013, 02:28 PM   #25
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
That's right.
Originally Posted by Irv Weissmanhowerton View Post
You might not always "need" an 11mm oil pump on a gd. But are you saying that it actually hurts something?
I know there are endless people who could chime in with no problems at all like your experiencing. Sounds like just one instance your dealing with, if soooo many equally experienced tuners & builders have done the 11 in a gd in the past, I personally have had my last 4-5 motors with 11mm, My most current motor being built by Mike Keegan, who went over the parts list with me & assured all good, no problems, he was part of building ali/esx 1400whp 7 second car's motor
I'm sure alot of people will question this thread & take your input personally as most of us has had other reputable people tell us, 11 is all good, I have always understood 12 was overkill & out of the question, but 11 being bad on a single avcs or causing any issues, not so sure
Does it hurt something? That depends. If the motor is built super loose, lessening restrictions through the block/heads, bearing journal turbo, and the 11mm pump is shimmed to 85psi (from factory 76psi) it may be the right choice. Putting an 11mm pump on a moderately built short block, or 'stock' built block with drop-in, it will be more harmful than beneficial. For street guys flogging it through a few gears once in a while it would likely never be any sort of issue. At some level of performance adding another thermal load, aeration, and increasing parasitic losses (yes it takes more energy to pump +30% = several more gallons per minute) it all add up.
We've seen track guys have high RPM pressure drop, that disappeared after downsizing pumps.
A good builder will always have oiling in mind when building an engine for a specific application. Different applications require different components, clearances, etc... including the proper oil pump for the build. I know there are a lot of good builders out there. There are also some not so good builders out there that do not even know or understand the differences besides "the 11mm flows more'. As a manufacturer who designs Subaru oiling system products, we have a pretty decent knowledge of the Subaru oiling system, consult and work with builders and race teams all over the world, and have our products on MANY Subarus taking podium finishes almost every venue of motorsports Subarus are involved in. I should hope we know what we're talking about
My intention with this thread was to spur some discussion and debate... and just maybe a bit of knowledge to help the uninformed make an more informed decision. As I said before, there probably are hordes or users that run 11mm pumps without issues and I know there have been some that HAVE had problems. If this thread prevents an issue for someone, it's been worth it. If it offends anyone, that was not my intention.
