Welcome to the North American Subaru Impreza Owners Club Wednesday November 25, 2020
Old 11-08-2007, 06:08 PM   #1
9vapors
Member#: 92582
Default Fuel Systems
I am trying to find somewhere that sells complete fuel system upgrades, preferably something bigger than a Walbro... Think Aeromotive stuff. I have checked with JEGS, and Summit, but I was hoping someone is already creating them for Subarus... Anyone know of who might sell these?
9vapors is offline   Reply With Quote
Old 11-08-2007, 06:30 PM   #2
9vapors
Member#: 92582
Found this, but I wish I could find one not from Vivid... http://www.vividracing.com/catalog/p...ducts_id/32179
Old 11-08-2007, 07:10 PM   #3
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Perrin sells that kit direct but I will say that the pump is very, very, very loud
What you looking to spend?
I helped setup a fueling kit on a built STi recently and it turned out very well. Basically a single in-tank walbro fills a TurboXS fuel surge tank. Out of the tank are two huge fuel pumps (can't rememebr the part # off my head) Each pump has an external non return check valve and the outputs of these T togther to a single dash 8 steel braided running down the car. Return lines from the front of the car fills the surge tank, surge tank then overflows into the fuel tank.
It turned out sweet but lets just say it was pricey mainly due to the non return valves, fittings and pumps.
mick_the_ginge is offline   Reply With Quote
Old 11-09-2007, 03:35 AM   #4
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
Get in touch with aeromotive. I have their prototype fuel rail kit for the wrx going onto my rs soon. It was built very well and I'm sure if you get in touch with them they can help you put the rest of the system together,pump,lines,filter etc.
speed_freak27 is offline   Reply With Quote
Old 11-09-2007, 11:13 AM   #5
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
putting the whole system together isn't hard. You just have to think things through...welding a sump for an A1000/2000 to a gas tank is recommended but not needed...oh, they are also VERY loud...right now I'm finishing up my designs on my double and triple 255 intank.
Old 11-10-2007, 07:43 PM   #6
9vapors
Member#: 92582
I wouldn't mind spending the $ if it is done right. I have a GT35R that I hope to get about 500whp out of, but I don't want to have to upgrade my fuel system again if I decided to go faster. I do love Aeromotive's parts, but I haven't seen too much outside of the big V8s. I suppose I can just get a second walbro and run one of these...
http://www.rallysportdirect.com/shop...3bb9a695430876
If anyone can explain how the above would be setup, I would appreciate that...
Old 11-10-2007, 08:48 PM   #7
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
It's pretty easy to set up a surge tank and it is well worth it if you have high hp and track your car or drive it hard on the street. Plenty of fuel for a 35R
Here's what my setup consists of
Intank walbro 255 feeds a surge tank
-8AN feeds a Bosch 044 external pump
-8AN line to the front of the car splits into -6AN Axis Fuel Rails
RC1000cc Injectors
Aeromotive FPR feeds into stock return line that goes to the surge tank
dan avoN7 is offline   Reply With Quote
Old 11-11-2007, 07:21 PM   #8
9vapors
Member#: 92582
^^Thanks, but I can't see the pics! Want to though...
Old 11-11-2007, 09:11 PM   #9
S L O W W R X
Member#: 95109
We just did a setup on my brothers bugeye. Its twin Walboros with 6 an lines merging in a Y into an 8 an line, 8 an line feeds the aeromotive rails(very nice) and then 8an back to the regulator, 6 an return line to the tank.
It works very well. Good Luck
Matt
S L O W W R X is offline   Reply With Quote
Old 11-11-2007, 09:14 PM   #10
9vapors
Member#: 92582
^^Thanks! Sound like a nice setup. Anyone have anything else?
Old 11-11-2007, 11:59 PM   #11
Homemade WRX
Member#: 33782
96 3MI Racing
Rally Stuff
Matt
sounds pretty similar to mine. but y'ing 2 255's to my primary rail and a sinlge 255 to my secondary rails...all -8an because of fuel block availability...running bdl rails with aeromotive fpr's...
fuel block return is 2 -6an to -8an return...
monitoring rail system fuel pressure independently.
Old 11-12-2007, 05:41 AM   #12
bloopsta26
Member#: 131371
05 buy my parts so
i can get my sti running
i know buscher sells a twin fuel pump setup...check it out pretty good price also....
bloopsta26 is offline   Reply With Quote
Old 11-12-2007, 08:09 AM   #13
saintluciascooby
Member#: 109527
1997 GC8 [email protected]
blue
quick question I run dual 044 bosh pumps right now , I had one fail and the engine went lean and blew one time. Does any one make a controller that will just shut down if one pump fails?
saintluciascooby is offline   Reply With Quote
Old 11-13-2007, 12:13 PM   #14
9vapors
Member#: 92582
^^Never heard of that, but I can see where that would be useful. Thanks bloopsta26, gonna go check now.
Old 11-13-2007, 01:09 PM   #15
9vapors
Member#: 92582
Me want!!!
Old 11-13-2007, 02:19 PM   #16
engineerx
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
Me likes this one:
engineerx is offline   Reply With Quote
Old 11-13-2007, 02:20 PM   #17
engineerx
Member#: 42614
0405 WRX STi/S2000
dan avoN7 setup FTW !!
I researched the Aeromotive A1000:
A pump controller is needed to bring the duty cycle down when crusing / idle to lengthen pump life, otherwise your pump will need an early replacement
The Bosch 044 can be used @ 100% DC and it may last longer.
Surge tank : Speedmachine performance.com ~$150
Pump: eBay, web ~$220
fittings / hoses : Jegs, Summit, ANplumbing.com ~$lots
(get good fittings Earls, Aeroquip, not the generic Jegs or Summit brands!)
I recommend the Teflon tubing/Steel braided lines
http://www.anplumbing.com/shop/index...ept=Speed-Flex
http://www.anplumbing.com/shop/index...-Seal-Aluminum
My Setup (GT35R / 1000cc)
Large pic:
http://subaru-wrx-sti.com/web/MODS/B...ytemlayout.jpg
other pics:
http://subaru-wrx-sti.com/web/MODS/f...ne-routing.jpg
Old 11-13-2007, 02:25 PM   #18
9vapors
Member#: 92582
^^^Holy crap! Thanks for that info, that is exactly what I was looking for. That explains everything that my dumbass had a question about. Thanks again!
Old 11-13-2007, 02:52 PM   #19
engineerx
Member#: 42614
0405 WRX STi/S2000
Another of my diagrams:
*dual lines from FPR to surge tank: I used stock return line
*dual lines from surge tank to OEM tank: I used single -06 line
*I added an Aeromotive 10 micron after-pump filter, keep your injectors clean!
*don't quote me on pricing... those are ballpark, I'm not responsible if you end up spending all your yearly allowance or if your car explodes (my disclaimer)
large
http://subaru-wrx-sti.com/web/MODS/f...emdiagram2.jpg
glad to help!
that's what the forums are for.... to ask dumbass questions and get intelligent answers
Weeeeeeeeee vsssssssssss weeeeeeee sssssssssssss
That's the noise most big pumps make (except the Weldons but those are mucho$$$) - you get used to it, usually it gets lost amidst the exhaust, suspension, turbo, radio noises.....
I compared my in-cabin fuel pump noise levels of one of my buddies IN-Tank Bosch 044.... I'm pretty happy about mounting the pump outside, under the car.
Serves 2 purposes:
1. "Safer" - not 100% - But .... the HIGH-pressure line starts outside the car, you still have the tank-to-surge tank line. But minimizing high pressure lines inside passenger compartment is always a good thing.
2. Quieter inside car
Take your time deciding, and make a list of parts you will need, draw a diagram listing parts, it will save you time & money in the long run
Good luck !
Old 11-13-2007, 03:00 PM   #20
Homemade WRX
Member#: 33782
96 3MI Racing
exactly why I'm monitoring mine individually
having a pump take a dump is a big worry...
Old 11-13-2007, 03:12 PM   #21
saintluciascooby
Member#: 109527
blue
Trouble is you have to catch the failing pump instantly or your in the crap.
I want a control board that will shut down or send an ecu signal as soon as one fails.
I have really resigned myself to getting a big weldon pump.
Old 11-13-2007, 03:14 PM   #22
Homemade WRX
Member#: 33782
96 3MI Racing
and I have two good friend who design both the electrical and mechanical controls systems for pumping systems
also working on my own meth kit with them.
failsafes are a must
Old 11-13-2007, 03:33 PM   #23
engineerx
Member#: 42614
0405 WRX STi/S2000
Aeromotive makes one ~$275
Or
1. you can use a Pressure Sensor Switch: out put relayed to Ignition cut. When sensor detects less than your specified pressure use Bosch relay to shut off ignition, problem with this is that in turbo applications the Fuel pressure rises with boost. Better than 12v logic is needed.
2. you can use your Defi warning output so when light comes on - relay shuts off IGN, same problem as above
3. you really need custom electronics and digital logic:
When pressure less than X amount of Y boost pressure
then trigger output IGN cut and/or open wastegate
Just a few Truth Tables, Bolean Algebra, some JK Flip Flops, away
Fuel pumps failing on boost sucks!
maybe it would be a good idea to just replace pumps every 2? years
Old 11-13-2007, 03:59 PM   #24
Homemade WRX
Member#: 33782
96 3MI Racing
which with walbro's would be $2-300 or with bosch's like $400-600
Old 11-13-2007, 04:07 PM   #25
saintluciascooby
Member#: 109527
blue
The pump in question broke on its eighth 1/4 mile run at the 80ft mark, and funny enough its replacement broke on its second run at 1/8 mile. hopefully just a bad batch of pumps replaced the pumps for free but it cost me 5 grand to fix the motor though!!!
Walbros dont put out like the 044 bosch pumps
Need APS fuel system and tumbler deletes to use APS fuel rails? GoRacerXGo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-17-2005 03:07 AM
Difference between fuel SYSTEM cleaner and fuel INJECTOR cleaner? burnout555 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-17-2003 12:52 PM
Maximum HP on stock RS fuel system with walbro fuel pump Chav Normally Aspirated with bolt-on Forced Induction Powertrain 11 06-17-2002 04:42 PM
fuel system managment system jeffsnyder Normally Aspirated Powertrain 2 09-23-2001 02:13 PM
Fuel Injectors / Fuel system JC SPORTS Technical Forum Archive 75 07-14-2000 09:51 PM
