08-02-2014, 08:54 AM | #26 | |
Member#: 382533
Vehicle:2015 WRX 6MT ltd+nav WR Blue |
For amp turn on, just make sure you connect the blue power antenna wire because the Metra harness loops that back to the pin for amp turn on: Antenna power is 3rd pin down from the right, and amp turn on is the second pin.
08-02-2014, 11:43 AM | #27 | |
Member#: 393302
Vehicle:2014 Impreza Sport |
http://ae64.com/aftermarket-HU-insta...Impreza-BT.htm There is a 16 pin and a 20 pin harness. The amp turn on lead is in the 16 pin harness. |
08-02-2014, 03:04 PM | #28 | |
Member#: 382533
08-02-2014, 04:04 PM | #29 |
Member#: 393302
08-02-2014, 04:19 PM | #30 | |
Member#: 389143
TXIC
Vehicle:2015 WRX Limited DGM |
anyway, you are an asset to the community. thank you for posting this. i will definitely be tackling the upgrade at some point. i picked the factory nav upgrade b/c i really wanted keyless but that piece of **** Fujitsu system had me doubting my choice since i placed the order. well now i have the car and i love it; i dont doubt my choice but i sure as hell don't doubt my decision to dujmp that garbage system and move forward with a NEX 8000! |
08-02-2014, 10:26 PM | #31 |
Member#: 382533
The 5000 NEX doesn't have HD Radio and I never listened to HD on the stock system so I couldn't tell you. Sirius sounds better though but I think it sounds better because the NEX overall sounds better than stock regardless of source.
08-02-2014, 11:15 PM | #32 | |
Member#: 393302
I got the 5000NEX over the 6000 and I couldn't justify the extra $150 for the HDMI port and HD radio. I personally just listen to Pandora while I am in the car. I will probably get a Sirius tuner soon as well. I can't stand FM radio in my area as there is nothing I want to listen to on any of the stations. |
08-30-2014, 09:54 AM | #33 |
Member#: 238303
W. Canada
Vehicle:2011 WRX WRB |
I just had 6000Nex installed with SWC, receive call, Hang up call and voice recognition button doesn't work. Could you please confirm if all the swc buttons suppose to work with nex? Thanks
08-30-2014, 11:41 AM | #34 | |
Member#: 389143
TXIC
you probably have something like this in there to make it work: http://axxessinterfaces.com/index.ph...roducts_id=197 it needs to be flashed to work with your SWC setup |
08-30-2014, 02:51 PM | #35 | |
Member#: 393302
If you did, yours may have not learned the functions automatically. You may have to go through the teach process. |
08-30-2014, 06:22 PM | #36 |
Member#: 382533
09-12-2014, 10:40 PM | #37 |
Member#: 401462
Would the same parts list in the first post work for a 2011 WRX STI with NAV?
10-19-2014, 04:43 PM | #38 |
Member#: 330968
South East
Vehicle:201 WRX WRB |
Thanks so much for this write-up. Excellent info and exactly what I was looking for.
10-25-2014, 10:24 PM | #39 | |
Member#: 384579
This for 2014 WRX fellow who want OEM dash kit, you can buy it from the dealer see pic |
10-25-2014, 11:36 PM | #40 |
Member#: 389409
TXIC
Vehicle:2017 STI WRB, '15 DGM WRX RIP. |
Did you update the firmware on the ASWC? Mine work on the 2015, but I did the firmware beforehand. I haven't programmed mute, but the two phone buttons have been working fine with the 4000NEX so I imagine yours should too.
10-26-2014, 07:09 AM | #41 | |
Member#: 384579
My harness is from ae64, only 20 pin connector the 16 pin connector is not use. |
10-26-2014, 12:22 PM | #42 |
Member#: 6295
So those of us with the Harman Kardon Nav, is the HK amp separate from the NAV headunit?
EDIT: Found the answer early on in the thread. |
12-15-2014, 02:56 PM | #43 |
Member#: 25837
South East
Vehicle:1996 SVX L AWD Laguna Blue Pearl |
This took way longer than I had anticipated, but here finally is my 'parts needed' guide to install an aftermarket HU in Subarus with the OEM Fujitsu Ten nav (including BRZ, Legacy, and Outback, as well as FR-S, GT86, plus other recent Toyotas which use the same "Toyota-style" harnesses):
ae64.com/aftermarket-HU-install-parts-2012FT.htmIt includes answers to many of the questions that have been asked in this thread (e.g., dealing with OEM h/k amp, retain factory XM antenna, GPS antenna, and more). Cheers! (and much kudos to yg17 for his work in putting together this thread) |
12-18-2014, 12:20 AM | #44 |
Member#: 167143
Vehicle:2007 STi SWP |
SVX, are you still making harnesses? I've sent a few inquiries over the last month!
12-20-2014, 05:00 PM | #45 |
Member#: 382135
Is it possible to retain the stock GPS Antenna if doing an aftermarket install?
12-22-2014, 01:53 PM | #46 |
Member#: 409130
South East
Vehicle:2015 WRX Dark Metallic Gray |
Amazon links
Hey man, thanks for the detailed post - helped a lot. The amazon links you posted for under "What you'll need", are those the exact ones your bought? When you select the compatibility check options for 2015 wrx in amazon it says it wont fit the car.
Edit: never mind, just read the parts needed to install site. Last edited by saadistic16; 12-22-2014 at 02:06 PM. Reason: Answered my own question |
12-23-2014, 09:39 PM | #47 |
Member#: 408537
Vehicle:2015 WRX WRB |
This is a great write up, I wish all of this was available when I did mine 6 months ago.
12-25-2014, 12:56 PM | #48 |
Member#: 409130
South East
I just bought the nex 6000 and ordered all the items you listed above except the Sirius tuner since you can always just get Sirius online and stream it from your phone. 60 bux for a tuner wasnt worth it IMO. Anyway, I'll post pictures of the wiring for you guys once I get everything in.
YG17, thanks for this write up it definitely helped a lot. |
12-27-2014, 09:55 AM | #49 |
Member#: 409130
South East
Sent from my iPhone using NASIOC
12-27-2014, 10:49 AM | #50 |
Member#: 408569
Great writeup, does anyone use the NEX units with Android? I can't get a straight answer if I can share my screen to the device. I want to buy it so I can use Waze on my road trips.
