07-02-2014, 11:11 PM | #2301 |
Member#: 6850
Vehicle:1996 Camaro Z28 1LE, '23 WRX & '19 XV |
It seems really low to me too. Both Greg and I use 32/28 for our 285/30R18s. With the Boss302 Mustang I ended up running at Toledo, it was one 315s, and still was 31/29.
07-02-2014, 11:14 PM | #2302 |
Member#: 80649
South East
Vehicle:2000 2.5 Auto-X RSTi Sparkly |
I run mid 30's (as recommended by hoosier) on my 18x11's and 315's. I've been watching the wear patterns and might actually reduce my front camber a little. Still more testing to do, but where's the fun if you're not into semi uncharted area.
07-03-2014, 02:49 PM | #2303 | |
Member#: 115961
Vehicle:2005 Wide STi Wagon WR BLUE |
I have only had to do one front and 1 rear bearing on mine, but I upgraded my fronts to the LIC ones recently anyway. I think it is just luck of the draw with them. I know we chatted a bit about pressures etc, and I have very limited experience with the Hoosiers as I told you it was my first time running them at Crows. They felt much better when we upped the pressure (thanks for letting me use your air) on the second day to the low to mid 30's also. Even though I drove like crap my co-driver agreed that they felt better with the pressures higher. We were running low pressures like yours and I have a very similar pic that someone got with the sidewall flex from the first day. Also I grabbed a few pics of you on from Saturday at Crows let me know if you want originals: A few more here Good luck at Packwood! Last edited by k-dogg; 07-03-2014 at 03:12 PM. |
07-05-2014, 08:06 PM | #2304 |
Member#: 147776
NWIC
Vehicle:2001 Forester 2013 Scion FR-S |
Nice photos! Thanks a lot bud
07-06-2014, 01:56 PM | #2305 |
Member#: 115961
07-07-2014, 01:46 AM | #2306 |
Member#: 193756
NWIC
Vehicle:2005 LGT Wagon Silver |
Nick Johnson, singlehandedly making sure the WRX moves to ASP. Good driving, bud
07-07-2014, 02:26 PM | #2307 | |
Member#: 147776
NWIC
It was an awesome weekend, great weather and great people! Besides my girlfriend getting heat exhaustion , an otherwise beautiful weekend. My co-driver Chris Heady put the stomp down and landed third by only 0.273 seconds! I ended up swapping out the 10k front springs for 12k (left the rear 11k alone) since Crows to try and reduce lift in the inside rear. It helped a little, and the car didn't lose too much rotation. It felt a lot more neutral, but it's still bouncy and hoppy in sections... Might try putting the 11k up front and the 10k in back to soften everything up a bit, or I'll just leave it alone |
07-07-2014, 07:21 PM | #2308 |
Member#: 80649
South East
Diffs are the answer to your hop.
07-08-2014, 12:14 AM | #2309 |
Member#: 147776
NWIC
07-08-2014, 02:19 AM | #2310 |
Member#: 127883
Vehicle:'09 C63 AMG '99RSTi '05 CGM STi - RIP |
You were very fast at Packwood. I was co-driving an EVO in SM, and your times would have been competitive with us. We finished 2nd and 4th in class, 8th and 23rd in PAX.
07-08-2014, 10:56 AM | #2311 | |
Member#: 80649
South East
I'll send you a PM about the diffs. |
07-08-2014, 09:04 PM | #2312 |
Member#: 147776
NWIC
Yeah, I'm just blown away!
Here's an awesome group shot of ESP after the end of day 2 runs: That's my co-driver making the "P" and me on the far right in my "Cheater-Hoosier-Checkers" shoes |
07-08-2014, 10:50 PM | #2313 |
Member#: 6850
Your codriver is not nearly as energetic as either Jerry nor Jess.
07-09-2014, 02:07 AM | #2314 |
Member#: 147776
NWIC
Hahaaa, poor Chris. I just look awkward... me with my go-kart-exhaust burn on my arm
Yeah Jesse and Jerry are pretty awesome You should have come out, it was a great time! |
07-11-2014, 10:34 AM | #2315 |
Member#: 175837
Vehicle:#61 9.5% FP |
Silly question. I have the opportunity to pick up some cheap aluminum full back seats. Does the 25 lb minimum seat weight from ST* apply to us? I don't wanna purchase them then have to ballast a seat.
07-11-2014, 11:08 AM | #2316 |
Member#: 80649
South East
No, there is no minimum seat weight in SP.
07-11-2014, 11:26 AM | #2317 |
Member#: 175837
Thank you sir.
07-15-2014, 08:25 PM | #2318 |
Member#: 147776
NWIC
So, after Packwood, I took all of your guy's advice and tried raising my tire pressures a bit with the 315s.
I ended up (on asphalt) bringing the fronts up to about 31/32psi and the rears up to 26/37psi (from 25psi/20psi). Hard to say if there was an improvement from Crows since that was asphalt, but there was still tons of grip and responsiveness. I haven't seen any pictures, so hard to say about sidewall flex. Last edited by BeBop86; 07-15-2014 at 08:35 PM. |
07-16-2014, 01:40 PM | #2319 |
Member#: 172179
Vehicle:2006 WRX |
I ran 40 in the rear on the 17s at the last El Toro practice day during the last half of the day and it seemed to solve my major issue without causing any significant new issues. I think I have found a new setup. We will see at the next local event.
Might add a little more rear camber to balance the added psi out and improve tire longevity. My plan on the next set of 18s was to run them 5 psi higher than the 17 to see if I could get a more reasonable life out of them. Now that is starting to run into the max inflation pressures and sounding like the front of GS/HS car. So not so sure any more. Probably try it any way... |
08-07-2014, 02:30 PM | #2320 |
Member#: 58865
RMIC
Vehicle:2004 WRX 99ESP - Drew =) |
Anyone ever run a mixed tire setup (used tires in the back, new in the front)? I figure the diffs would be ok for just racing. Right?
08-07-2014, 02:33 PM | #2321 |
Member#: 127099
BAIC
Vehicle:02 IMPERZA WRX BLACK |
THAT WOULD BE INCORRECT . you cannot do this. you will kill your trans and diff. if they are slightly used tires in the back maybe but if you have really low thread and NEW front you will kill the drive train.
08-07-2014, 03:01 PM | #2322 | |
Member#: 80649
South East
The driveline will accept small differences in tire size without issue. Regarding used tires in back and new in front, I've run newer in front with very old in the back. Other than being stupid tail happy it was fine. I've even *gasp* mixed compounds before for local events and my car didn't catch fire |
08-07-2014, 03:45 PM | #2323 | |
Member#: 60566
SCIC
Vehicle:2005 XT 5sp, 02 WRX 01 Legacy 95 Impreza L |
I did this last year at nats due to a shipping issue and necessity, used rear/new front. It worked out ok for me and the car didn't assplode. I actually liked the balance better! Each day we had new fronts. |
08-07-2014, 07:02 PM | #2324 |
Member#: 58865
RMIC
I know smark had tried running just new fronts on the tt... never asked how it worked.
Sounds like I'll be running sticker fronts and 30ish run rears. maybe 1-2/32nds difference. The rears have been more heat cycled then worn (damn hot laps at the match tour). |
08-21-2014, 02:57 PM | #2325 |
Member#: 147776
NWIC
37 entries so far for Nats... getting excited!
ESP-The 2002 WRX Project | Butt Dyno | NASIOC Project Cars | 803 | 05-08-2022 08:15 PM |
The Competition (strictly by the numbers) | R Diamond | STi Forum Archive | 9 | 05-22-2003 05:16 PM |
The Competition is Worried..G Stock is worried | Scooby South | Motorsports | 10 | 02-23-2001 05:41 PM |
Weapon R Intakes vs. the competition | Matthew Nelson | General Forum Archive | 3 | 08-31-2000 01:19 AM |
0-50 vs the competition | bryanw | General Forum Archive | 11 | 08-11-2000 09:15 PM |
