Welcome to the North American Subaru Impreza Owners Club Thursday April 15, 2021
Go Back   NASIOC > NASIOC Subaru Models > Crosstrek Forum
Old 12-10-2020, 07:21 PM   #1
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
Default Front lower control arm: rear bushing replacement
While doing brakes on the front of our 13 Crosstrek, I took a look around and that LCA rear bushing is pretty worn out. Watching the Youtube guy do the job with his $700 Snap On tool looks just ducky. For those of us without any snap on tools besides the 2 screw drivers I found on the street a decade apart, is this a DIY kinda job? What do you use for a press?
Old 12-10-2020, 11:28 PM   #2
Blktrax
Member#: 220971
2004 Impreza
You really need a shop press and the correct size insert to get the shell out easily. You can do the old fashion burn out the rubber and hack saw the shell, then press in the new bushing.
The new bushing is orientation specific. Rubber casting/injection tits down and the air gap with the 3 ridges inside the shell faces the ball joint.
Or just rockauto some complete arms, usually over 100K the front bushing starts to fail anyway.... and pressing that on anything but a rust free arm usually results in some fun twisting and crunching.
Blktrax is offline   Reply With Quote
Old 12-11-2020, 09:17 AM   #3
Jack
Add Lightness
Member#: 13699
2021 Building
It Better
Good to know that. Maybe new arms are in order instead. I can certainly remove/install a pair of control arms.
