Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 05-22-2020, 04:25 AM   #51
Stewadom797
Member#: 514976
Default Just bought 96 Legacy
So I just bought a 1996 Legacy about a week ago. Got it home just fine but since then it idles low, stalls constantly, and the rpm's jump up and down until it stalls out. Code reads P0100. Replaced MAF sensor and it is still there. Replaced spark plugs, plug wires, ignition coil, changed the oil and the oil filter, and replaced the air intake filter but still can't get that code gone and can't get it to run without stalling or idling badly. Going to try "hard resetting" it in the morning and see what happens.
Stewadom797 is offline   Reply With Quote
Old 05-22-2020, 12:45 PM   #52
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
P0100 is a CIRCUIT malfunction. Check the wiring to the MAF, be very thorough and even check that the pins in the connectors are seated and making contact. Check the engine main harness. Clean all grounds, even the one on the intake manifold.
Old 08-16-2020, 04:03 PM   #53
jteastwood
Member#: 517582
Default 07 impreza stalls unless alternator is disconnected
trying to solve my daughters impreza issue. car would occasionly stall coming to a stop. Now its constant and will not idle in my garage after about 20 seconds after cold start. when cold idles fine and smooth and then just dies. odly i noticed when changing the alternator belt that it ran great without the alt plugged in. Ok, maybe a short in the alt. changed it with no change. also changed maf. Running out of ideas. Anyone run into a similar issue??
JT
jteastwood is offline   Reply With Quote
Old 08-18-2020, 01:16 PM   #54
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
reset the ECU, see if it idles then. If so, let it idle for a while to re-learn.
Old 09-24-2020, 03:07 PM   #55
billyedtimmy
Member#: 504069
So, do I ALSO need to do the idle relearn AFTER the throttle body clean, or no?
billyedtimmy is offline   Reply With Quote
Old 11-11-2020, 10:23 PM   #56
riot609
Member#: 520233
Default 2010 forester stalling when stopping or shifting
so I just bought a 2010 forester 5speed manual that had bad drivers head gasket I decided to pull engine do both gaskets water pump timing belt kit and a throw-out bearing and now after reinstalling car idles perfect when started will sit for hr. no issues at all but when I go to drive it put in reverse back out of garage when I push clutch in it stalls same when going from 1st to 2nd and so on basically anytime after moving and pushing in clutch checked all vacuum lines battery alt just cant seem to get it to run when trying to shift I have tried the idle relearn process multiple times with no change also to note when car is sitting at idle I can press clutch and brake and it remains fine its only after engaging movement in gear then pressing in clutch that it stalls....any ideas
riot609 is offline   Reply With Quote
Old 01-28-2021, 05:49 PM   #57
GOLDY27
Member#: 522009
Default 2010 Subaru Forester stalling issues
I'm having the same issues, stalling. Did all the head gaskets, etc. reset throttle relearn and same issue.
GOLDY27 is offline   Reply With Quote
