Welcome to the North American Subaru Impreza Owners Club Friday February 3, 2023
Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Legacy Specific Parts
Old 05-23-2019, 09:14 AM   #1
dvinke1
Member Sales Rating: (2)
Member#: 163030
Default TONS of 05-09 Legacy GT parts - Aftermarket & OEM
Parting out my 2005 Legacy GT wagon w/ TONS of aftermarket parts. Located in Salt Lake City, Utah (Sugarhouse area).
4k miles on all aftermarket parts, unless otherwise noted.
More parts to be posted. If you need something not here, ask because I probably have it! (parts to follow include KW coilovers, Whitline swaybars and other suspension stuff, CNC ported heads, 5-speed blast plates, Cobb short throw shifter)
Next post with more parts/pics soon!
Prices do not include shipping or 3% paypal fee, if you are not local. Open to package pricing.
$475 - Cobb Accessport AP3-SUB-002 (of course it's unmarried... if not what good is it...)
$975 - Full Autometer guage setup. Includes all gauges/sensors, AEM wideband O2 sensor, cubby pod and vent pod holders, as well as the factory dimmer switch bezel because it has the Autometer dimmer knob for the gauges custom built into it. I will leave it as "plug and play" as I can, for easy installation, and will also include the length of hose for the boost gauge. **Also, please do your research before b!tching about the price - these are not ***** Depot guages - these are Autometer with programmable warning lights as well as memory for peak readings. This whole package cost me over $1200. Not to mention the 4-6 hours of mounting, wiring, and testing that you won't really have to do**
$120 - Perrin Turbo inlet with clamps and fittings
$325 - IAG AOS (air oil separator). Includes OEM hoses (brand new still, as well as the Gates braided fabric hoses (hence the slightly higher price. I replaced almost all the hoses under my hood with the Gates braided, so I did the AOS also.
$175 - Mishimoto aluminum Radiator. 10k miles on it. Includes newer hoses also.
$550 - Spec Stage 2+ Clutch w/ brand new throwout bearing (I used a TSK repair TOB sleeve kit). Great shape, only 4k miles on it and just broken in! I HIGHLY recommend this clutch - super strong grip, but OEM pedal feel, and almost ZERO chatter! (in the past I have used and compared this to OEM, Comp stage 2, and South Bend. I like Spec the best)
$150 - WRX Single Mass Flywheel. Purchased brand new and only 4k miles on it.
$100 - TSK throwout bearing repair kit. Only 4k miles on it and in great shape.
$225 - Blast plates for 5speed Transmission. Copy-cat blast plates, but I was told it is thicker metal than Moore blast plates. Exactly identical mounting as the Moore plates.
$55 - Grimmspeed Alternator cover. Brand new in box never installed. Subaru WRX 02-14/STI 04-15/Forester XT 04-09/Legacy GT 05-09
$45 - Grimmspeed Radiator Shroud support. Like new, only used for 2k miles.
$125 - LIC Motorsports adjustable timing belt idlers - only 1k miles on them.
$250 - Complete Yakima setup. Bars, towers, and fairing. Used for 10k miles, not like new.
dvinke1 is offline   Reply With Quote
Old 05-23-2019, 09:15 AM   #2
dvinke1
Member#: 163030
Old 05-23-2019, 08:44 PM   #3
dvinke1
Member#: 163030
Autometer Gauges as follows:
****Better pricing and descriptions now****
All genuine Autometer gauges, most of them purchased directly from Autometer --------- High quality, and NOT cheap...
Many of them are brand new, never used --- The others have less than 2-4k miles of use. I removed some of them from my car years ago and 2 gauges have dents in the outer silver rings (see pics and further descriptions below).
All prices below include shipping via USPS flat rate Priority. Paypal fee required to be paid by buyer and added to total, however.
$150 shipped --- Shift light and controller (controller is needed in order to use). Part numbers 5330 &5312 --- Brand new never used (no box/packaging)
https://www.autometer.com/quick-lite...ite-black.html
https://www.autometer.com/dpss-controller-level-1.html
$155 --- Electric Oil Pressure gauge w/ peak pressure memory & programmable warning light --- part number 3652 -- 2-1/16" --- 0-100 PSI Full Sweep Electric Oil Pressure Gauge w/ sending unit --- less than 2k miles of use
https://www.autometer.com/2-1-16-oil...-fse-44***8230;
$55 --- Mechanical Oil Pressure gauge w/ Peak psi and Warning setting --- Brand new never used (no box/packaging) --- part number 3323 -- 2-1/16" --- 0-150 mechanical
https://www.autometer.com/2-oil-pres...-sport-***8230;
$135 --- Oil TEMPERATURE gauge, W/ PEAK & WARN --- 140-280 °F --- STEPPER MOTOR ---- less than 2k miles of use
https://www.autometer.com/2-1-16-oil...fse-443***8230;
$155 --- Pyrometer EGT gauge, w/ Peak & Warn custom lights --- Brand new, Never used ---- Part# 3647 --- 2-1/16" ---- 0-2000 °F ----- STEPPER MOTOR ---- exhaust Probe and harness included
https://www.autometer.com/2-1-16-pyr...0-f-fse***8230;
$85 --- Pyrometer EGT gauge, w/ Peak & Warn custom lights --- Part# 3647 --- 2-1/16" ---- 0-2000 °F ----- STEPPER MOTOR ---- less than 4k miles of use --- exhaust Probe and harness included ----- Probe is BROKEN though!! ---- Price reflected above ---- New probe is approximately $90 (from Amazon.com) ----
https://www.amazon.com/Auto-Meter-52...30;/B0013B87I2
$125 --- Pyrometer EGT Gauge ----- 2-1/16"----- 0-1600 °F ----- STEPPER MOTOR ------- Product # 3344 ---- less than 4k miles use ----- older model than the two above ----- has minor dents in the outer silver ring, and the price reflects ------
https://www.autometer.com/2-e-g-t-ki...sweep-s***8230;
$150 ---- Wideband Gauge & wideband o2 sensor ---- 2-1/16" ----- WIDE BAND AIR / FUEL RATIO ----- ANALOG ----- 8:1-18:1 AFR ----- Product # 3670 ----- less than 2k miles of use
https://www.autometer.com/2-1-16-ana...-sport-***8230;
$195 --- Fuel Pressure gauge w/ peak and warning light ---- 2-1/16" -------- 0-100 PSI ----- STEPPER MOTOR ------ Product # 3671 ------ Brand NEW, never used (no box/packaging) -----
https://www.autometer.com/2-1-16-fue...i-fse-4***8230;
$55 ----- Boost / Vacuum Gauge --- 2-1/16" ----- 30 IN HG/30 PSI ----- MECHANICAL ------ Product # 3603 ---- will include a long length of quality rubber hose ---- Brand NEW, never used (no box/packaging) ---- only mounted in pod as pictured, zero miles of use ----
https://www.autometer.com/2-1-16-boo...30-psi-***8230;
$25 ----- Boost / Vacuum Gauge --- 2-1/16" ----- 30 IN HG/30 PSI ----- MECHANICAL ------ Product # 3603 ---- less than 4k miles of use, however I removed it from my car several years ago and the outer silver ring has some minor dents in it, See picture ----
$925 --- Pods and 4 gauges - Setup as pictured ---- if someone wanted it as a package by chance --- Pictures are of the pods and gauges installed in my 2005-2009 Subaru Legacy GT (will fit 2005-2009 Outback also) ----- Includes the 4 gauges as pictured installed in my vehicle, sending units, hoses, wires, and all accessories for said gauges, both gauge POD holders (center mount pod above radio AND vent pod to the left of the steering wheel for dual gauges, and also the OEM as well as Autometer dimmer switch bezel, and all wiring as complete as possible in order to make installation as easy as possible
**Willing to substitute / mix and match gauges with pod purchase also
*****Please don't balk at the price, Autometer are not cheap - I have almost 1500 bucks sunk into the pods and 4 gauges, not including my hours of labor wiring it up******
********** Gauge pods/holders are in my Subaru - Sorry to taint your group with the likes of that blasphemy - But obviously the gauges are more or less Universal to any/all cars.**************
Old 05-28-2019, 03:14 AM   #4
VaderSubi
Member Sales Rating: (1)
Member#: 486762
2006 WRX
Obsidian Black Pearl
what does the shiftknob and boot look like? interested in them.
VaderSubi is offline   Reply With Quote
Old 06-06-2019, 12:15 PM   #5
dvinke1
Member#: 163030
Bump. Still lots of parts for sale.
Old 06-08-2019, 11:45 PM   #6
motorbykemike
Member Sales Rating: (13)
Member#: 273868
bump
waiting for the parts I paid for
noticed you can post here that parts are for sale but cant respond to my inquiry about tracking info for the parts I paid for just under two weeks ago
sorry , multiple inquiries.
that's right
called out
motorbykemike is offline   Reply With Quote
Old 06-12-2019, 01:04 AM   #7
dvinke1
Member#: 163030
Originally Posted by motorbykemike View Post
bump
that's right
called out
Mike, I thought I had texted you sooner. Did you get my text today with shiping and tracking info?
Old 06-24-2019, 11:22 PM   #8
matthewlee
Member#: 428769
Interested in the fuel lines/regulator setup and the TGV/rails.
Lmk how much as I dont see anything.
matthewlee is offline   Reply With Quote
Old 07-10-2019, 03:42 AM   #9
MotoTraverse.com
Member#: 497889
Please check PMs dvinke1
MotoTraverse.com is offline   Reply With Quote
Old 07-18-2019, 09:31 AM   #10
MotoTraverse.com
Member#: 497889
Has anyone else tried to buy something from this post? I paid and have received nothing
Old 07-18-2019, 04:54 PM   #11
car_freak85
Member Sales Rating: (43)
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
What's the word on the Suspension?
car_freak85 is offline   Reply With Quote
Old 07-19-2019, 07:27 PM   #12
MotoTraverse.com
Member#: 497889
Looks like I'm not the only one who sent payment
Old 07-22-2019, 05:49 PM   #13
car_freak85
Member#: 13530
EJ205
Ha! Didn't buy anything, just looking for parts!
Old 08-08-2019, 07:56 AM   #14
echoe09
Member#: 286148
Full inbox bump
echoe09 is offline   Reply With Quote
Old 08-08-2019, 03:41 PM   #15
STiNL
Member#: 292422
2008 WRX STi
I'll take the alt cover if still available. PM'd you a few days ago...
STiNL is offline   Reply With Quote
Old 10-24-2019, 05:18 AM   #16
Brianable
Member#: 381141
Interested in accessport is this available?
Brianable is offline   Reply With Quote
Old 12-31-2019, 02:41 AM   #17
moddingbug
Member Sales Rating: (17)
Member#: 220165
2005 LegacyGT Wagon
Satin White Pearl
Interested in the KW and whiteline parts.
moddingbug is offline   Reply With Quote
Old 02-21-2020, 09:36 AM   #18
My27KGame
Member Sales Rating: (3)
Member#: 294927
2011 STi
Do you still have the AP?
My27KGame is offline   Reply With Quote
Old 05-18-2020, 12:59 AM   #19
InsatiableAmos
Member Sales Rating: (11)
Member#: 92706
2000 Swapped 2.5 RS
Silverthorn Metallic
Going for a true, full part-out? I'm looking for:
- Cobb Accessport (it's unmarried, right?)
- Your whole steering wheel assembly, airbag incl.
- E-brake handle and leather shroud
Your inbox is full, otherwise I would've PM'ed you!
InsatiableAmos is offline   Reply With Quote
Old 05-26-2020, 10:31 PM   #20
cal71919
Member Sales Rating: (4)
Member#: 353064
1995 Legacy LSi
white
Are you willing to sip the radiator? I'm at 77089.
cal71919 is offline   Reply With Quote
Old 05-27-2020, 04:16 PM   #21
ttnio
Member#: 515073
Default no response since 04/20
no response ever since
ttnio is offline   Reply With Quote
Old 08-22-2020, 05:26 PM   #22
2000GTB
Member Sales Rating: (7)
Member#: 20800
2000 Legacy GT Wagon
Engine harness?
2000GTB is offline   Reply With Quote
Old 09-24-2020, 03:46 AM   #23
HighC
Member#: 488676
2005 Forester XT
Hello McFly? Im looking at that AP, is it available? I will take it if so.
HighC is offline   Reply With Quote
Old 11-07-2020, 02:29 AM   #24
miked003
Member#: 455149
Default parts
6512610799
Text if you have parts to sell. Lgt
miked003 is offline   Reply With Quote
Old 11-12-2020, 04:58 PM   #25
Subaru4lyfe42
Member#: 503455
Shoot me a text or call since I dont check messages often. Looking to buy your AP V3
248.464.4555,
Mike
Subaru4lyfe42 is offline   Reply With Quote
