05-25-2024, 02:53 PM | #1 |
Member#: 423516
Vehicle:2015 WRX Premium Lightning Red |
Bad clutch slip?
New problem: Had the car at the dealer for some other maintenance work. The test drive by the tech noticed "really bad" clutch slip. The whole assembly has about 50k on it with 300whp from last year's bolt-ons and tune. It kind of answered why it felt like lately the car was falling flat at highway acceleration (namely in 3rd and 4th gear) with an rpm jump initially, and then would feel like it would stagnate, despite still gaining speed. Is this common? And if I now need a new clutch ***128548;, what have folks gone with for aftermarket?
06-01-2024, 11:12 AM | #2 |
Member#: 423516
No suggestions?
06-01-2024, 04:52 PM | #3 |
Member#: 350291
If RPMs increase disproportionately from speed most likely clutch is slipping and needs replaced. It's a wear-n-tear item, so yeah pretty common to need replacement at some point. Just depends on how its driven and if its spec'd for the appropriate power output.
My 07 sti was on the stock clutch for about 120K, most of that on 93oct tune and bolt ons. Went flex fuel and the clutch went south quick on high E fuel. Replaced with ACT HDSS w/ resurfaced FW. Happy and holds great. |
06-07-2024, 09:35 PM | #4 |
Member#: 423516
^ Thanks for that feedback.
11-27-2024, 10:12 PM | #5 |
Member#: 423516
The car is now in the shop to get the ACT HD clutch kit put in, as well as a slew of other work done to it. Fingers crossed....
11-28-2024, 12:50 AM | #6 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
For the future, my usual clutch test is:
3rd gear, up at least a slight grade, RPM's 3000RPM or so, mash the gas. If the tach jumps up but little or no real speed change, the clutch is slipping. You may also smell "hot brake" smell which is the clutch. The gear reduces mechanical advantage. The RPM's gets you near max torque. The hill makes it work harder. |
11-30-2024, 09:01 PM | #7 |
Member#: 423516
Indeed, thanks. My burnt clutch smell was heavy.
01-01-2025, 07:06 PM | #8 |
Member#: 423516
The car has the new ACT HD clutch with oem TOB and oem fork, so this issue seems resolved now. Other issues, not so much.
