09-27-2000, 02:54 PM | #26 |
Member#: 856
International
Vehicle:2123 JDM STi Black |
it's not parallel with the ground that counts, its keeping the steering arms following the same arc as the suspension under bump rebound.
Some designs need the rack moving up/down to achieve this, others need the rack going forward/back. I am pretty sure the impreza needs the rack lowering. Like i say though, this needs a dedicated test and adjust session. [This message has been edited by johnfelstead (edited September 28, 2000).]
09-27-2000, 03:41 PM | #27 |
Guest
Member#:
It is PART of a ensemble of tweaks.I've read on the Sidc or the Scoob board about the settings. It was written that it wasn't as harsh as autocross settings and worked WITH the bumpsteer adjustment.... and consequently did not eat tires fast like the autocross settings.I think I could be happy with the bumpsteer shim and some matching camber caster settings.Along with good tires which is more important anyway.
This has been a very entertaining thread. |
09-28-2000, 05:05 AM | #28 |
Member#: 1178
South East
Vehicle:2011 BMW 535i Alpine White |
John,
Thanks for the info. Bummer Powerstations is so tight lipped, its just a little difficult for someone in the states to bring them our cars... Now all I have to do if find a confident race shop that understands how to do this. I feel like I'm sitting in a field with 20 haystacks and the damn needle is in one of them and I gotta check all 20... Oh well. Thanks again Eric. |
09-28-2000, 12:52 PM | #29 |
Member#: 856
International
10-01-2000, 06:02 PM | #30 |
Member#: 20
Everyone has raved about this mod, so I am eager to try it. Even with the Prodrive suspension, 20mm bar, antilift, Gr. N bushings throughout...yada yada yada, it still understeers. That being said, my car will be at Rallispec as of this week having a wee it of work done (they are doing the engine swap for me, since I had no esire to tackle the wiring). If it can be done, I will do it, and hopefully, it will be something they can offer to the public. Promise to keep you posted.
10-03-2000, 09:29 AM | #31 |
Member#: 1540
Vehicle:92 JDM GC8 WRX 2004 2.5 twin scroll 6MT |
Chaps!
Please remember that the P1 has significantly more power and torque than even an RS and it is very easy to get power understeer if you are too eager with the gas. Do this a few times and the edges are gone on the front tyres. Hello understeer!! I run a 2.0 Sport with std suspension and P1 tyres. It has no understeer as it hasn't got the power to destroy the tyres. The P1 suspension has unique springs designed specifically for this car, the idea being to tune the suspension for the Uk and retain good road manners and ride comfort with 17" wheels and tyres. Engineering understeer into the chassis was not an objective and we did not achieve it either. The best handling Subaru I have ever driven was a Legacy 2.0 fitted with our springs and P1 size wheels and tyres for exactly the same reasons. We used this car for a Drive day in Greece and all the drivers, including Simon Jean-Joseph our latest WRC driver, preferred it to either an Impreza WR or P1 as it was more fun. Simon was actually approaching the corners backwards in complete control! (some of the time) I hope this helps!!!! Mike Wood |
10-03-2000, 10:47 AM | #32 |
Member#: 1575
South East
Vehicle:2011 WRX Premium Blackest Black |
WOW I am so flattered one of my posts has attracted the attention of Prodrive! Cool! Anyway I still standby what I said about the P1. If I was wrong why did they just introduce the P1 WR? And by the way why in the face of overwhelming evidence do people insist that the P1 comes with Bilsteins?
10-03-2000, 10:54 AM | #33 | |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
bummer he didn't comment on the part numbers that we are tring to verify
10-04-2000, 06:38 AM | #34 |
Member#: 1540
The P1WR uses a 225/35x 18 PZero without changing any other suspension components. As the tyre is larger and therefore less likely to have the edges destroyed it gives less understeer.
Virtually all magazines take pictures of the cars first when they do a test. This normally involves attempting to get spectacular cornering shots which as previously explained will scrub off the edges of the front tyres. This can be so bad that all the letters are scrubbed of the sidewall!!! Then they do a driving assessment and hey, the front tyres have less grip than the rears! Anyone who has driven either the P1 or one with the 18" wheels (or any other Impreza) will realise that the car does have a slight amount of understeer like all four wheel drive cars, but when encountered a slight lift on the gas will remove it. A big lift will result in oversteer that can then be controlled on the throttle. Jaxx Not sure what the spring part numbers relate to but they are definately NOT P1 springs. These will probably be STi5/6 and are black? The P1 springs are different in both rate and ride height to any STi spring, thats why we specified them as STi did not have anything suitable Mike Wood |
10-04-2000, 09:03 AM | #35 |
Member#: 177
NWIC
YAY!
finnaly a definate anwser thank you VERY much for posting Mike. |
10-04-2000, 09:38 AM | #36 |
Member#: 2080
Vehicle:06 Impreza Wagon Red |
Mike,
It's great to see you and Simon posting here. Since we're on the subject of the P1, I have a couple questions. In the past, some have said that the P1 was designed to be used with 17" wheels. (I see from your post that you also mate the P1 with 18" wheels. I'm more or less referring to 17" vs 16") Is there any truth to that, and if so, why? Also, could you quickly comment on how the P1 compares to the other Prodrive options available to us yanks. The Prodrive GT and the WR Sport. |
10-04-2000, 12:35 PM | #37 | |||
Member#: 856
International
Hi Mike, good to see you posting on this side of the world as well as scoobynet.
I am a fellow Impreza Sport driver and run my car on standard suspension, 16" turbo alloys and SO2 PP 205/50/16 tyres(tires ) The sport has enormous grip in the wet in particular with its soft suspension and no anti-roll bars giving great mechanical grip. I do find the car beautifully balanced. I also have the pleasure of driving a 22B both on track and road and found at the limit the 22B did suffer from understear, very safe but frustrating, especially considering i drive a very powerfull RWD car in the main on track and enjoy overstear handling. The 22B was modified at powerstation to eliminate the bump steer and i have to say this transformed the car at the limit, making it perfectly balanced and eliminating the understeer. I am a little intrigued by your statement about the P1 handling. Quote:
It does seem to be a major bugbear of Impreza drivers accross the world that the car understeers, to date the best solution to this i have found has been to remove the inherant bump steer, that admitedly is there to protect us from ourselves. Do you agree that this modification reduces the understeer inherant in the Impreza or am i making a bad judgement on what i am feeling when driving the cars in there diferent specs. best regards john |
10-05-2000, 07:40 AM | #38 |
Member#: 2563
John
Perhaps I should have added the word 'more'! As you say, all Imprezas understeer. What we achieved with the P1 was a safe handling car with minimal understeer and neutral characteristics in most circumstances, particularly emergency situations like braking on corners. You know yourself that ALL Imprezas with a viscous centre diff and as much power as the P1 generally suffer from power understeer and it's quite easy to wreck the front tyres by trying too hard which then leads to understeer. This is improved with the wider 18" tyres, that's why the reports have been more favourable. I have never driven a car that has 'had the bumpsteer removed' so I can't comment on it's effectiveness. All I can say is that all cars are built to a tolerance so very few will be absolutely perfect but should all be within tolerance. To answer some of the previous questions, the P1 suspension was designed to suit both 17 & 18" PZeros but that does not mean that the suspension would not suit 16" wheels. The P1 was developed as a discrete model wheras the WR Sport parts are upgrades for the standard Turbo models available in the UK. Most of these parts are also suitable for the normally aspiratred cars and we now have a rear silencer available specifically for the non-turbo models. Mike |
10-05-2000, 08:52 AM | #39 |
Member#: 856
International
Thanks for the clarification Mike, much appreciated.
Please don’t take this the wrong way as I respect what Prodrive does enormously. Can I make a suggestion to you, get yourself down to PowerStation and have the bump steer modification carried out on some of your test cars. You never know, you may think it is so good you decide to market a Prodrive kit of parts to give what most enthusiastic Impreza drivers want. Less understeer. PS. I want 10% royalties |
10-05-2000, 11:49 AM | #40 |
Member#: 265
Vehicle:1998 22B Blue 1986 Ford RS200 White |
hey, John
You could always pop down to Banbury and take Mike for a ride in mine Richard |
10-05-2000, 04:59 PM | #41 |
Member#: 856
International
thats a good idea richard!!
Mike, you fancy a spin in a modded 22B?? Not literally i hope |
10-06-2000, 03:12 AM | #42 |
Member#: 2563
John
If you're passing sometime, then why not! You could have a shot in our P1 with the 18" wheels etc Mike |
10-06-2000, 05:09 AM | #43 |
Member#: 1722
Mike, John and All,
John, I think you should do this. Take Richard's car down (with his kind permission) and have Mike drive it. If he doesn't love it, then you will have to shoot him Seriously Mike, I'm good mates with the guys at Powerstation who spent the time to work out what needed doing to sort this bump steer out. I have yet to hear a negative response to this modification, in fact most seem overly postive But Mike also has a point, I bet if say the P1 was released with this modification, then quite a few of them would have been off into the weeds by now. Maybe if Mike likes it, it could be added to the modification list for the P1 or P1 WR. Of course, I also would want 10% royalties And to fight the Powerstation corner, it would only be fair to discuss this modification with Powerstation and maybe some kind of back-scratch could happen as they spent a lot of time (hence money) working on this mod. Cheers Ian |
10-06-2000, 09:40 AM | #44 |
Member#: 265
John, Mike..
Go for it mate.. I'd be very interested to find out Mike's reaction to the setup on the car.. Richard |
10-08-2000, 10:07 AM | #45 |
Member#: 856
International
OK Mike, i will get in touch soon. Been away since thurs night testing and on a rally.
Working away monday so probably contact you on tuesday. Regards john |
10-09-2000, 11:26 AM | #46 |
Member#: 2080
Mike Wood,
I guess I need to rephrase my question about the P1 and wheel/tire sizes. First let me quote the October 2000 issue of CAR. In an article on the P1 WR on page 44,it read "The OZ Racing rims are the same as those of the standard P1, but an inch larger in diameter at 18 inches, and they're fitted with 225/35ZR18 Pirelli P Zero tyres. Not only do these changes sharpen up the steering's responses but they also make the helm feel calmer and less prone to tramlining." Now I think they misspelled that last word. I think they meant "trampolining", but I could be wrong. If it was trampolining and going to 18 inch wheels reduces the tendency of this happening vs 17 inch wheels, then I would think 16 inch wheels with 205/50ZR16 P zeros would be more prone to trampolining. To me trampolining basically means you're getting some bounce from the tires, which would get annoying on long trips. It is also the basis for my original question about the P1 being design around 17" wheels instead of 16". Now an additional question. You have clearly stated that the part numbers 20330FA160 and 20380FA450 are not P1 springs. What about the strut part numbers? People who have supposedly gotten P1 kits in the US have listed the strut part numbers as 20311FA960 left front, 20311FA950 right front, 20360FA960 left rear, and 20360FA950 right rear. Are these correct? |
10-09-2000, 11:33 AM | #47 |
Moderator Member#: 922
Vehicle:16 WRX (white) 04 FXT (red) |
Scottie - I think tramlining means following the cracks and such in the road... I think the wider tires would help with that so they probably got it right.
10-09-2000, 11:47 AM | #48 |
Member#: 265
8
Spot on Dude I hate to see my Scoobie trampolining Richard |
10-09-2000, 11:57 AM | #49 |
Member#: 2080
Richard & 8,
I guess I thought CAR meant "trampolining" versus "tramlining", because either "Road & Track" or "Car & Driver" used the word "trampolining" in a short review of the 22B versus M3 a year or so ago. I'll have to dig that article up. [This message has been edited by Scottie (edited October 09, 2000).] |
10-09-2000, 12:41 PM | #50 |
Member#: 265
Scottie,
Don't worry about it.. It was probably just a misprint in the magazine Mind the thought of Scoobie doing layouts, and front somersaults, just doesn't bear thinking about.. Richard |
10th anniversary of the P1 | Chris & Rosy B | Member's Car Gallery | 13 | 05-11-2010 04:36 AM |
The Myth of the Recovery | Mike Wevrick | Political Playground - Chaotic Neutral Edition | 53 | 04-05-2010 07:41 PM |
Myths of the Heathcare Bill | matt30 | Political Playground - Chaotic Neutral Edition | 22 | 09-09-2009 03:02 PM |
Unraveling the myth of the Straight Talk Express | HB_Dad | Political Playground - Chaotic Neutral Edition | 4 | 09-14-2008 01:12 AM |
Just ordered a set of the P1 rims (woo, hoo!) | gtguy | Brakes, Steering & Suspension | 3 | 12-06-2000 08:29 PM |
