10-13-2000, 07:26 AM | #1 |
Member#: 498
South East
Vehicle:1981 jdm swapped gc sniklfritz |
Installing apexi S-afc?
how do i install it on a my98 ive looked at www.lagging.com and dont understand the instructions..also how do i split the wires etc.... thanks
Greg
10-13-2000, 02:03 PM | #2 |
Member#: 1801
Vehicle:2000 2.5RS Blue |
*** read warning at bottom first! ***
simple instructions: (simple as in off the top of my head) 1. disconnect your battery 2. expose the ecu --- repeat for all applicable SAFC wires --- 3. find what SAFC wire goes to what ECU connector pin (see lagging.com diagram) 4. about 1 inch back from connector, remove wire insulation (i used x-acto knife, but be careful to to damage wire!) 5. strip last 2-3mm of SAFC wire 6. tin both wires 7. solder the exposed wires together (it is easier if you bend the end of the SAFC wire into a hook shape and have someone else hold the 2 wires together and keep tension on them while you solder) --- end repeat --- 8. reinstall ECU 9. connect battery *** if you really dont know how to solder or feel in any way like you can't pull this off, then DONT!!! I did my own cause I've been soldering for years and have had more than 1 job doing electrical assembly. Better to let someone experienced do it than F up your car! -Jeff V. (SkinMask) [edit: typos] [This message has been edited by SkinMask (edited October 13, 2000).] |
Apexi S-AFC II install on "99 RS | Kincaid Racing | Other Engine Management | 3 | 10-04-2006 12:54 PM |
PICS of Apexi S-AFC installed... | CRAZY KEN | Normally Aspirated Powertrain | 8 | 01-29-2002 03:49 PM |
('93-'01) Apexi S-AFC installed! | HudsoN456 | Impreza Forum | 6 | 10-26-2001 08:52 PM |
Apexi S-AFC install HELP??? | tmaler13 | Technical Forum Archive | 3 | 08-26-2000 10:39 AM |
