Welcome to the North American Subaru Impreza Owners Club Sunday January 19, 2025
Old 02-12-2015, 01:44 PM   #251
chasewrx198
Member#: 411663
I am currently installing an AEM meth injection kit and have a pretty good idea on how to install it im just not sure were im supposed to connect the green boost safe wire too
chasewrx198 is offline   Reply With Quote
Old 03-02-2015, 09:05 PM   #252
kred
Member#: 351724
2006 Legacy GT LTD
Making a tough decision. AEM or Snow Performance meth kit? Who can tell me which is better from a reliability stand point? Trying to make a safe 400-450 wheel on pump + meth.
kred is offline   Reply With Quote
Old 03-23-2015, 08:41 PM   #253
chase1873
Member#: 382339
2013 STI
Satin White Pearl
good read, thanks
chase1873 is offline   Reply With Quote
Old 06-25-2015, 02:09 PM   #254
roadtrip1098
Member#: 185688
2006 STi
WR Blue
Default Lessons learned
So I've been running the AEM Water Meth injection for about 2 years now on my 06 STi. The system has had a number of hiccups, but overall I like it. From time to time - seems to be right after using the IC sprayer, the system will kick on and then not shut off (makes the car run rich and you have to stay in throttle until you get to a point where you can pull over, power down and re-start the car). I have tried to track it down, but they're on different circuits - so no dice. Other times it will get a circuit short error code, the wiring is all good, and it hasn't really been an issue since putting a bigger battery in. Additional power adders are as follows:
20g XTR
850cc injectors
300LPH fuel pump
2011 STi Intercooler
EL Headers
3" Catted DP
3" Exhaust
Currently running 24psi with 11.1 AFR at peak boost and 400cc/min WM Injection. I've added a boatload of timing, and either my knock sensor is completely offline, or it never knocks.
Here are some things I've learned:
1. Water Meth is awesome. Especially if you do your own tuning, it gives you plenty of room to 'mess up' your map and not have to replace a motor because of it.
2. There is a delay when it kicks on, especially if you are running the pump and resevoir from the trunk. When I first installed my flow meter, I noticed half a second of dead time betweenwhen the pump would kick and the needle would move on the flow gauge . This can be mitigated by moving the setup to the front of the car and using less line between the pump and injector.
3. Inject after the intercooler and before the throttle body for most effective use.
4. Create an ultra-safe failsafe map. Mine dumps in tons of fuel going around 10.0 AFR. It's not very efficient, but I'll burn a few extra drops of gas over replacing a motor any day.
5. The systems can fail. Sometimes a hose will come loose, or the injector nozzle backs out of its threads, or your low level light never comes on. Get a flow meter.
roadtrip1098 is offline   Reply With Quote
Old 06-25-2015, 02:17 PM   #255
roadtrip1098
Member#: 185688
2006 STi
WR Blue
I have AEM, my friend has Snow Perfomance. The AEM kit has had a few issues. I've had to call tech support a few times to get the flow guage working (it was assembled backwards at the factory). The flow meter / failsafe is arguably the most advanced ont he market.
The Snow Performance kit is more pleasing to the eye and looks to use the same model pump as AEM, just with their logo. I like their injector better too because it incorporates a 90 degree swivel elbow where the AEM is a 2" injector with a straight exit meaning you need 3" of clearance to mount it. The controller is similar, but we haven't had any issues with the Snow Performance.
Old 08-05-2015, 09:35 AM   #256
jacob.elder22
Member#: 353830
06 Impreza STI
I have a question I couldn't find in the notes.... Is a plastic tank the safest to go with or can you do aluminum? Heard it can corode
jacob.elder22 is offline   Reply With Quote
Old 09-12-2015, 01:41 PM   #257
mikey951
Member#: 417569
Can some one do a write up for nos?
mikey951 is offline   Reply With Quote
Old 11-18-2015, 10:30 PM   #258
MrGatr
Member#: 434543
Midnight Blue
Is running a meth injected WRX really worth the money you spend on the system and everything? I'm looking into a Stage two Snow Performance kit and I've heard nothing but good things from locals about how well these kits work on just a slightly modified car. But I'm still scepticle if it's worth running or if natural injection works better.
MrGatr is offline   Reply With Quote
Old 12-16-2015, 04:31 PM   #259
Myblack2006sti
Member#: 391159
Great thread cant wait to see more
Myblack2006sti is offline   Reply With Quote
Old 01-09-2016, 12:02 PM   #260
Half Crazed
Member#: 321842
08 460/420w 08 STi
17 Stock WRB WRX
Originally Posted by Davenow View Post
Here is mine from a while back
NOTE* This FAQ is very SMC and Subaru specific, as this is what I know. But it mostly applies to all cars/setups
What does alcohol injection do? It injects a mist of alcohol directly into the intake stream, this has the effect of massive "chemical intercooling" along with greatly raising the octane level of the air/fuel charge. On 93 octane pump gas, the general concensus is that when the system is spraying, you are at or around 110 octane
So what does that do for my car? Well higher octane and a MUCH cooler air charge means a MUCH higher detonation threshold. It will take a LOT more to make your car knock
My car isnt knocking now, why do I care? Because one spot of bad gas can make it happen. And where "stage 2" wrx's last forever, there have been quite a few "stage 2" STIs blow up. You want as little chance to detonate as possible. With alcohol injection, its probably about 100 times less likely to detonate. And if you dont tune super agressively, you can pretty much set the car up to where its almost impossible to cause it to knock in any driving condition, with any weather change
What Benefits are there other than the above? POWER. You can tune leaner, running up to 12-1 under full boost. I run 11.7-1 at 19lbs and never see det. Your EGTS typically go down up to 200 degrees too. Mine are about 75 deg lower than pre alch. You can also run up to 5 degrees more timing and 2-4 more lbs of boost. Want detonation free 21lbs of daily driving boost on a stock STI turbo? You got it. It will be hard on the turbo, but those are cheap enough
Typically I would say running 2 more psi boost, 20% less fuel under boost and 3-4 more degrees timing would be a "normal" alcohol injection tune.
It also has the effect of "steam cleaning" the engine from the throttle body to the exh ports. No carbon buildup on the backs of your intake valves, and the domes of your pistons stay MUCh cleaner. Which means MUCh less chance of "hot spots" which cause detonation
But that sounds expensive to run Alcohol, in 1 gallon cans is about 7-11 dollars per can.
wow thats nuts, how long does 1 gallon last? Well the SMC kit uses your washer bottle, thats 1 gallon. Most people get 2 to 3 tanks of gas out of 1 fillup. I average about 2 1/2 tanks of gas for each alcohol fillup.
When you are tuning your car, it will go MUCH faster as you are spraying a lot more often. At a track day, it will REALLY go fast. I havent done a track day with it yet, but I would suggest you plan on AT LEAST 1 tank per session. If you use a 1 gallon tank, it MAY not even last the entire 20 min run session, or it might, you would have to talk to someone that has run it at a trackday. Best bet, if you are going to try it, is have EM that you can switch maps on the fly. That way if it runs low (watch for the light) you can switch to a non alch injection map on the fly. It may not be an issue, I have no honest idea. If you run a bigger tank, you shouldnt have a problem. If you are going to do a lot of track days and want to run this, you should consider buying the 12L Spec C tank and using that as your tank. SMC will install the pump in that for you if you would like
Can I mix the alcohol with anything to stretch my dollar?? YES!! Many, in fact, in the subaru world, most ppl run a 50/50 mix of distilled water and alcohol. The difference in what the alcohol injection does for your car is small. FIgure if straight alch would yeild you a 110octane charge, figure 50/50 would net you 108ish. I am totally talking off the top of my head, but I use those numbers to illustrate how small the difference is.
Also, if you mix, you end up with 2 gallons of mix. Which means for about $13 max, you get 4-6 tanks of gas worth of alc injecting goodness. That drastically lowers the cost to run this
What kind of alcohol?? WHere do I get it? Home Depot is one of the most common places people get it. The type is "Denatured Alcohol". Rubbing alcohol can be used too! If you are tuned for denatured, and you cant find any for some reason, you can stop at any grocery store, or drug store, and buy rubbing alch, dump it in, fill that bottle with water, and dump that in. I did that just the other day, it worked great
What about Methanol? Works great. Tune will be SLIGHTLY different than denatured
* Methanol might be harder on the seals in the pump than Denatured, so before running it you should check with SMC (or whoever's kit you choose) to be sure their pump and such will be ok with it. I will email SMC and ask about it and update this as soon as I hear back from them
Doesnt alcohol eat rubber? Yes a little, but that doesnt matter as this never touches any rubber
Alcohol is flamable, will my car catch on fire?? If its straight alcohol, and you get hit hard enough to puncture the container, yes it could. But at that point, sorry to say but your car is most likely totalled anyway. The fire will just prevent the insurance company from trying to fix it and leaving you stuck with a car that has been in a BAD wreck and was repaired. If you run a 50/50 mix, it will not catch fire as the 50/50 mix does ignite. At least when several of us have tried to ignite it, it just will not light, so if you run 50/50 you are 99.99999999% safe
So is this dangerous for my motor?? Well if you are boosting hard, and it fails, there is a very high chance your motor will blow. However, this is ULTRA rare, in fact I have yet to ever hear of a single case where it has failed. I know it HAS happened, but so far, not in the subaru world, and from what I have heard and read, the cases where it failed, were bad installs. One guy with a VERY early SMC kit had a pump go bad, but his motor was fine
So how does this work?? Ok So, you have a few parts. This is standard with all the kits, some have a couple differences, but here are the basic parts.
Tank
Pump
Controller
Nozzle
Some kits have a single stage or dual stage controller that sprays at either a constant flow rate regardless of boost pressure, or sprays at a higher rate after a given boost pressure.
Yet other kits, such as the SMC kit or the Devils own kit use a progressive controller. This is by far superior. It starts spraying at a predetermined boost pressure, that YOU can set and ramps up to maximum spray at another, higher predetermined boost pressure that YOU set. The SMC kit, and I THINK the devils own kit come set to kick on at 7PSI, and max out by 15 PSI. This doesnt mean it doesnt spray past 15PSI< it means it is a constant rate past 15 PSI. And you could make it 20PSi if you wanted to, you arent limited to 15PSI, thats just the default.
Some people set it to only kick on at say 15 PSI or so, which saves a TON of juice, but you lose all the benefits of lower boost spray. 7PSI is great because then it will JUSt kick on when you are at part throttle boost.
More details please! (the info here is based on a progressive controller) Ok so you are cruising along, you hit the gas, you hit 7PSI and the spray control unit kicks on. It turns on a high pressure pump that sends the mix down a hose to the nozzle which is typically located 2-3 inches in front of your throttle body. TMIC people usually drill a hole in the bottom front of their tmic and put the nozzle there. FMIC guys typically put it in the pipe, again, 2-3 inches in front of the throttle body.
As boost increases, the pressure from the pump increases, which causes more to be sprayed into the intake stream, up to the max point (default is about 15PSI)
IF YOU DO NOT HAVE A KIT WITH A PROGRESSIVE CONTROLLER> It will begin spraying at a constant rate at whatever boost pressure it is set to, many times this is not adjustable and is determined by what pressure switch it uses. This kind of kit still works, but it isnt nearly as nice and not nearly as tunable as one with a progressive kit. I would recommend staying away from these, and at least getting a kit with 2 stages. However if you are just going to have it spray at or about your max boost, this kit should be fine. However be aware that there is a good possibility of a "hesitation" like feeling at the point that it kicks in, no matter how much you tune.
I live where they only have 91 octane, will this help me out?? In those cases, you are helped out EVEN MORE than the 93 octane people. You will have a lower overall effective octane, but it will still be well above the equivalent of 100 octane. Your power and detonation resistance gains will be more dramatic than the people who can get 93.
So this is like running race gas? Yes and no. Its better than 100 octane(and MUCH cheaper) but its no C16 (which is 116 octane) Its a heck of a lot more economical, because lets face it, you dont need high octane when you are cruising around off boost, or even at 1-4 PSI boost. Heck I drove my WRX around on 89 octane and wastegate boost with no issues for awhile just to test that theory. Think of this as race gas when you NEED it, and cheap pump gas when you dont.
Do I need engine management to run this? Yes, 100% absolutely you HAVE TO have, at a minimum, some way of tuning fuel. Because when this sprays you will go INSANELY rich, like 7-1 rich. That is rich enough to be dangerous and can cause bore wash (this is where there is so much fluid in the cyl that it rinses the oil off the cyl walls, and the rings tear themselves and the cyl wall up.)
I dont want a ton of power, I just want the safest car possible Then leave it stock. There are no absolutes and ANYTHING you do to the motor increases the chances of it blowing up.
HOWEVER, you can make your car a LOT safer than it would have been. If you are considering this as a precautionary mod only, you can leave the timing and boost alone, and only tune to a "normal" a/f ratio as if it didnt have alch injection. Note than a "normal" non alch a/f is richer than what is considered a "normal" alch injection a/f, at least a little(in most cases).
I want m@d p0w3r y0! Great! Some have been able to go as agressive as: 3 more PSI, 5 more degrees timing, and 12.5-1 a/f without detonation and safe EGTS!!!!!!!! That is not the common setup though. Most knowledgeable people will recommend something around this : 2-3 more PSI boost, 3-4 more degrees timing, depending what your car will take without det, and a/f's around 11.7-1. On a "stage 2" (Em and turboback) STI, gains are typically around 20-25whp and 25+ft/lbs of torque. Combine 20whp, 25ft/lbs of tq and a safer running car, and you can start to see why this is such a great mod.
I have never heard of this, I am suspect of something this new Its not new at all. The turbo buick guys have been running this for probably 15+ years. Other racing cars have run this going back past the 60's. Rest assured, this isnt something "new"
The SMC kit is nice, but I want something more "stealth" that you cant see easily under the hood Then something like the Cooling Mist or Devil's Own, or some of the other "build it yourself" kits would be your ticket. These kits are just as complete, but are more labor intensive. Once installed and adjusted, they do the same thing. Of these types, the "Aquamist" is probably the best, but its VERY expensive and you dont really get a lot more functionality for the money IMHO. However Aquamist has a VERY good name for a reason. VERY high quality parts. Does this mean that the $300-500 kits are worse quality? Not typically.
I have an STI with Em and a turboback and I am maxing my injectors duty cycle at 100%, will this help me?
Absolutely. At 19PSI I am only seeing a max injector duty cycle in the mid 70%'s with my alch injection.
I want to go for some kind of stock turbo record, will this allow me to "safely" run really high boost??
You could run 23PSI easily, if not 25PSI, on pump gas, with alch injection. I have a buddy running 23PSI on his TD04 on his WRX with alch injection. He just trapped 105.5mph with that setup. Pump gas, 2.0l WRX, TD04, alch injection.
I am not very mechanically proficient, which kit is easiest to install? SMC by far. It typically takes about 1 hour to unpack, install and get up and running. Why? Because of how it is setup. The kit comes with a washer bottle with the pump assembly already installed. Yes, you get a replacement, smaller washer fluid bottle so you retain your ability to wash your windshield.
Can we use the intercooler spray tank in the trunk? Yes. SMC will install the pump in it if you send it to him. If you are using one of the other kits, you can install it anywhere you like as well.
How much are these kits? $249 to $1000+ The SMC is 499, the Devil's Own is like 349, the coolingmist has an option for 249 I believe, and the top of the line Aquamist is over a grand IIRC.
My methanol setup looks like it is set to come on at like 5psi and end at 15psi. Do you know why this may be happening? I'd think it'd be like on at 5 and end at 30 or something. Is there enough methanol to go around by the time 15psi comes and thats why it shuts off
The default is 7ish to 15ish
This means it maxes flow at 15PSI, not that it stops spraying (you probably knew that). Once it is spraying at full volume it is flowing a good bit. 15PSI is a lot of pressure, even if your max boost is 28PSI, so you want it to get to full spray by then. You dont really want it at full spray lower than that because it doesnt NEED that much of a boost in octane lower than that. Past 15PSi you want as much of a boost in octane/cooling as it can give. Which is why peak spray is set at 15PSI.
If you set it higher, you essentially take the ramp up rate, and make it longer/slower. If 7 and 15 means a 45 degree angle, 7 and 30 PSI would be like a 30 degree angle. Get what I am saying?
I ended up actually making mine come on a bit sooner, so it starts spraying at about 5.5PSI
The low number is when it STARTS to spray. The higher number is when it reaches maximum flow, it does NOT stop spraying at that number.
My car didnt come with a turbo but I added one (like a turbo'd honda/acura) I wonder if this could help me?
Absolutely! Cars that didnt come with forced induction have higher compression motors than cars that came with a turbo/supercharger. Higher compression brings in a higher chance of detonation. And since a cooler air charge, and higher octane means more resistance to detonation, you would surely benefit from alcohol injection, possibly more than cars that came with a turbo from the factory.
Think of it this way.
How much boost can a civic/whatever with a turbo handle with NO intercooler? How much more power can you make WITH a nice FMIC on that same car? Alcohol is essentially chemical intercooling. I would obviously still recommend an intercooler obviously, but this at least illustrates the point.
Uh, what: If you run a 50/50 mix, it will not catch fire as the 50/50 mix does ignite.
Make up your mind
Half Crazed is offline   Reply With Quote
Old 01-09-2016, 12:04 PM   #261
KornShaDoW097
Member#: 313618
2004 WRX
Default Water/Methanol Injection FAQ
Actually 50/50 is flammable... I think you have to go down to 70/30 for it not to be flammable... A few guys on YouTube actually debunked that theory.
I'm not sure why they market it as safe... Maybe because it's the ideal mix to profit from? Since you can't find that specific percent anywhere already premixed (outside of brand name guys )
KornShaDoW097 is offline   Reply With Quote
Old 03-26-2016, 02:19 AM   #262
DGM7rex
Member#: 395340
WRX
Hard to find Subaru specific meth/water info only seen a few cars with it . Thinking of going this route for my 2013 wrx . Can't find much info on the failsafes
DGM7rex is offline   Reply With Quote
Old 05-16-2016, 01:03 AM   #263
JMlegacy
Member#: 341649
You know, I find that engine oil is easier to ignite than a 50/50 mix.
JMlegacy is offline   Reply With Quote
Old 06-19-2016, 12:39 PM   #264
JMlegacy
Member#: 341649
So my aquatec pump failed on me. It wasn't holding any pressure and wasn't pressurizing beyond 140 psi. I adjusted the allen key screw for more pessure, nothing happend. So out of curiosity i disassembled the pump head.
The inner chamber had a split in the walls!
I suspect that water hammer is the cause of this. I'm getting a water hammer arrestor to install on my home built system.
Old 03-13-2017, 05:58 PM   #265
cmross13
Member#: 464454
can anybody tell me why i should choose one kit over another?
ive been looking at the Snow Performance stage 2 kit with the throttle body plate. seems like a reasonable kit and the controller can easily replace the OEM Boost gauge in my GR STI
any vendors offering a deal on said kit, or perhaps, something better?
cmross13 is offline   Reply With Quote
Old 07-22-2017, 12:30 AM   #266
Profoxcg
Member#: 169036
2015 STI
Guys, in a subaru, do you inject into the intake (pre-turbo) or after the intercooler?
Can this be used for a track day? or is it more for drag racing?
thanks
Profoxcg is offline   Reply With Quote
Old 07-22-2017, 09:49 AM   #267
point78
Member#: 344329
2008 Wrx, 6mt
thanks
Right after the intercooler, as far away from throttle body as possible. (Gives it more time to do its thing...)
I use it on my DD, only have Craptastic pump91 where I live
point78 is offline   Reply With Quote
Old 07-22-2017, 11:18 AM   #268
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
thanks
You can inject pre turbo but there's more to doing it properly and not damaging the compressor wheel.
It does come with some extra perks, including improved compressor efficiency.
I'm planning on playing with pre turbo and post turbo as well as a main injection post intercooler.
Old 07-22-2017, 12:14 PM   #269
Profoxcg
Member#: 169036
2015 STI
I have an OEM top mount, there little room (just the TB space)
It does come with some extra perks, including improved compressor efficiency. I'm planning on playing with pre turbo and post turbo as well as a main injection post intercooler.
Sound like at both locations would be a winner.
From a risk mitigation point of view, it seems like pre-turbo would be the safest.
I have a car that despite some cooling upgrades run a bit hot at time (where I live does not help either). So was thinking of an Intercooler sprayer, and then came across H20+M injection.
If I am misting pre-turbo, I am just cooling the air to be compressed and cooling off the turbo.. the post IC. charge will still be the same temp (hot). Is there really anything to gain ?
I am most afraid of the nozzle failing and spraying water like a hose into the engine and hydro-locking it. realistically speaking what are the risk of that really happening?
I am not too concerned with a clogged nozzle, and I would make that an item to check - part of my check list.
I am wondering if I just need to stock to the IC sprayer. - maybe I will buy a h20+M kit and install it to spray my IC for now. (pump and reservoir)
Thoughts please?
Old 07-27-2017, 11:30 AM   #270
mmoyer32017
Member#: 471804
meth
mmoyer32017 is offline   Reply With Quote
Old 08-14-2017, 08:53 AM   #271
sergey2007
Member#: 304910
2004 LGT ej207 7163
I wanted to consult on the next question. I had trouble, bending and breaking the connecting rod. Everything looks like a hydro shock. Among different versions of the causes, an uneven injection of alcohol between the cylinders is considered. Although this is unlikely, but I want to protect against all possible causes. Would it be useful to install 4 jets on each manifold pipe instead of one before the throttle.
sergey2007 is offline   Reply With Quote
Old 09-30-2017, 01:40 AM   #272
syounger
Member#: 420857
2015 sti
dark grey
I just purchased the hsf-3 water meth kit and was wondering on the best place to mount my nossle I have a throttle body spacer I was going 2 use for the install but i just picked up a fmic and am now not sure where the best place to put the spray nossle.Is the spacer a bad place to put it? If I am better to put it in the fmic piping how from the throttle body should I be going?
syounger is offline   Reply With Quote
Old 09-30-2017, 01:43 AM   #273
syounger
Member#: 420857
2015 sti
dark grey
Anyone have any insight on placing the jet in one of those silicone pipe couplers? Do they work? Are they crap?
Old 11-01-2017, 10:19 PM   #274
Sergey_mos
Member#: 477034
Default Hello!
Tank
Pump
Controller
Nozzle
Hello! Looking for friends or crazy) Installed the nos system on the ej20 atmosphere "wizard"
Sergey_mos is offline   Reply With Quote
Old 11-01-2017, 10:57 PM   #275
Sergey_mos
Member#: 477034
maybe I'm wrong with the topic? Installed wet through one crossfighter".Installed petrol pump 3bar + afr setting.motor no turbo stok AT, fuel 10% alcohol,
very good start 900psi 5lb /forced to think vw wrs, AT )
I'm from Moscow
I live in Highland Park
water / methanol injection kit -new or used blazin sti Private 'Wanted' Classifieds 3 05-27-2006 09:01 PM
Water/Methanol Injection or Race Fuel or Both ejh25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-28-2005 07:35 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-01-2004 06:52 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-01-2004 05:51 PM
