Welcome to the North American Subaru Impreza Owners Club Friday June 22, 2018
Old 02-07-2011, 11:08 AM   #76
OnyxSTI
Member#: 141234
2009 Impreza WRX STI
Default Jealous
Awesome install! Now, I just have to find some fog light installs for an 09 STI...japanparts doesn't have the assembly.
OnyxSTI is offline   Reply With Quote
Old 03-27-2011, 12:29 PM   #77
echardcore
Member#: 260638
2011 WRX Sedan
Spark Silver Metallic
Looks like Japan Parts has the two trim pieces if you dont want to cut for that OEM look
Part: 317-055-001
Subaru: 57731G/57731H COVER, REAR BUMPER
Price is for one side so please choose it for RH(57731G) or LH(57731G)
$20 each
echardcore is offline   Reply With Quote
Old 03-27-2011, 09:27 PM   #78
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
Originally Posted by littlewhitewagon View Post
Just to add this in here. The way to get the stalk that works right for our cars (LHD) is from Germany or the other Euro areas that have LHD. JDM stalk doesn't work since it will be on the wrong side. I think I have found the combination switch and it is around 280USD. This way, we will have the front and rear fog switches the way it is supposed to be. BUT, you will still need to make your own wiring and relay assembly.
So, the Body Integrated Unit (BIU)...the computer that controls your lights, indications, etc...has a setting for "Rear Fog SW Input" that is set to off on the USDM cars. I have yet to get a straight answer from a Subaru tech as to whether it can be enabled on our cars. If so, then you should be able to use an EDM wiring diagram to finish the wiring. If anyone knows the answer to this question, please let me know.
I've been working on putting a rear fog on my 09 hatch, but I REALLY want to use the OEM switch, so I've been waiting to install until I can get a clear picture of whether or not I can use it.
I got my switch off of eBay, seller was from Latvia. My LHD lamp came from Israel.
Ogden is offline   Reply With Quote
Old 03-27-2011, 11:40 PM   #79
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
I have a friend who has set up the relays for me. Its a 3 way toggle switch, I can switch it from foglight powered (based off of the front fog lights being on), brake light activated (linked in with the 3rd brake light) or just off.
I learned from friends and their 2010 LGTS, don't mess with BIU... its too expensive to mess up.
Yipee, I also got confirmation from Ralleysport that they have mailed it.
Old 03-28-2011, 01:37 AM   #80
littlewhitewagon
Member#: 103068
11 STI sedan
My idea would be just to not include the BIU. I would just use the stalk switch to go to my own relay and wiring assembly which would join the rear segment that goes to the bulb. I haven't had time to pull everything apart since I don't have the stalk yet in order to see if there are pins populated on the car side. My guess is that there are no wires there.
littlewhitewagon is offline   Reply With Quote
Old 03-28-2011, 02:20 PM   #81
GUIL-BOT
Member#: 270940
2011 WRX Sedan
Nice found
GUIL-BOT is offline   Reply With Quote
Old 03-29-2011, 01:12 AM   #82
thabigo
Member#: 268329
2011 Wrx STI
So where did you guys order this from??
thabigo is offline   Reply With Quote
Old 03-29-2011, 08:41 AM   #83
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Yipee, I also got confirmation from Ralleysportdirect that they have mailed it.
See above.
Old 03-29-2011, 11:25 PM   #84
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
That would be perfect. The OEM switch has the rear fog switch as a spring-loaded function. You turn it to the rear fog position and it springs back to the front fog position. I presume that this sets it up such that the rear fog runs only until the car is shut off and requires you to toggle it again once you restart the car if you want it on again. It keeps us from looking like idiots driving around with our rear fog lamps on all the time.
That said, the switch may require a specific relay to mimic that function, as it cannot simply be set to "on".
Old 03-30-2011, 01:03 PM   #85
GUIL-BOT
Member#: 270940
2011 WRX Sedan
Is there a way we can order the Rear Fog light switch ?
Old 03-30-2011, 02:32 PM   #86
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
You'd have to get the whole stalk. Not sure if the JDM version is on the same side of the wheel.
jonklein611 is offline   Reply With Quote
Old 03-30-2011, 03:58 PM   #87
scotheocelot
Member#: 254768
2011 STi Sedan
Thats the issue. The one you really need is the UK version. Its on the correct side from what I've read. Im just going to add a small swith under the left stalk for the fogs. Im going to tap into the front fog light wiring.
scotheocelot is offline   Reply With Quote
Old 03-30-2011, 06:46 PM   #88
littlewhitewagon
Member#: 103068
11 STI sedan
This is not a problem, you can be lazy and use a PAC TR-7 and latch the output digitally, or you can make a latching relay setup with a 5 connector SPDT relay. Come on... easy easy easy....
Old 03-30-2011, 10:23 PM   #89
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
Yeah, as I noted, I suspected that you could mimic the function with a relay of some sort. Glad to know it's easy.
Old 03-30-2011, 10:27 PM   #90
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Just use the rear window defogger to activate a regular relay. Its timed for 10 minutes?
Old 03-31-2011, 01:16 AM   #91
littlewhitewagon
Member#: 103068
11 STI sedan
And just keep your rear fog light on 10 minutes at a time? Gets nasty and get rear ended in 15 minutes?
Seriously, a latching relay takes all of 2 minutes to make.
Old 03-31-2011, 07:03 AM   #92
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Be practical, this light isn't preventing you from getting rear ended its not magical... it just attracts attention to the rear of the car when weather impairs distance vision and maybe won't confuse american drivers in bad weather. I would bet that if weather is so bad outside that you REALLY need this passive device, your rear defroster will be on anyway.
It was just an option, your option might be the way you want to go... that doesn't mean that it is the best option for everyone. I have mine wired.
Old 03-31-2011, 02:36 PM   #93
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
My first preference is to use the factory switch and latching function. I've never built a latching relay, but I'm sure that I can handle it once I figure it out...or I can probably just purchase one.
My second option is an aftermarket switch. I'll still probably want it to latch though.
Old 03-31-2011, 02:43 PM   #94
jonklein611
Member#: 117776
WR Blue Pearl
With a multimeter and a battery, I can figure most things out...
Keep us posted on how this works out. I'm trying to hunt down one for my hatch, you sedan folks have it easy.
Old 04-01-2011, 11:04 AM   #95
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
Actually, I'm in a hatch too. I found the lamp for an LHD car by pure luck on eBay. I got the switch on eBay as well. It took some time and a lot of searching.
Old 04-01-2011, 12:57 PM   #96
steverx05
Member#: 128269
I ordered mine from a Subaru parts place in Europe. It's a little pricey but it beats trying to find one one Ebay since they only pop up very rarely.
steverx05 is offline   Reply With Quote
Old 04-01-2011, 10:03 PM   #97
dakrat
Member#: 272840
2011 STI
Originally Posted by steverx05 View Post
It's to keep people from slamming into the back of your car in really bad weather.
you don't need a bad weather to get rear ended around here...
dakrat is offline   Reply With Quote
Old 04-11-2011, 09:45 AM   #98
scotheocelot
Member#: 254768
2011 STi Sedan
For reference.....
I ended up wiring a new circuit with a 30amp relay and a tiny rocker switch i mounted under the left hand stalk on the steering column. If or when I source a Euro stalk I will get a new lower plastic piece for the column and change out the stalk. Did anyone ever notice that the fuse panel diagram on the our cars shows "R. Brake/R. Fog" on the 20amp circuit?
Old 04-24-2011, 07:41 PM   #99
GUIL-BOT
Member#: 270940
2011 WRX Sedan
Installed mine yesterday
Not wired yet.
Old 05-12-2011, 05:01 PM   #100
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
bad cellphone pic.
If I knew this would be so easy to do... it would've been done months ago.
B9 Tribeca amber rear signals and rear fog light DomozitoLK Tribeca Forum 4 02-01-2007 12:42 AM
Rear Fog Light Mod, Anyone done it? wrxEMT Interior & Exterior Modification 4 11-23-2001 12:21 PM
('93-'01) Rear fog lights on 2002 WRX US models ?? ginowrx Impreza Forum 15 06-15-2001 06:34 AM
Rear Fog Light Kit HRE | giulio Interior & Exterior Modification 19 05-12-2001 06:48 PM
Rear Fogs lights-uk Subarus come with? MichiganRS Interior & Exterior Modification 9 12-15-2000 09:03 PM
