10-19-2005, 10:29 PM | #1 |
Member#: 64528
Anyone blown engines with J&S and or Water Injection
Anyone blown RS-T engines with J&S and or Water Injection
10-19-2005, 10:41 PM | #2 |
Member#: 71348
RMIC
Vehicle:1999 EJ207 RS.TI |
I'm not sure if there are but there is no subsitute for good fuel delivery and engine managment. If you want it to last do it right.
10-20-2005, 09:33 AM | #3 |
Moderator Member#: 922
Vehicle:16 WRX (white) 04 FXT (red) |
You can blow a motor with anything.
A J&S will certainly help, though. And water injection, as long as you don't use WAYY too big of a nozzle, works very well as well. |
10-20-2005, 11:01 AM | #4 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
Unless you lower your compression, you are going to blow your engine no matter what EM you run...
10-20-2005, 11:33 AM | #5 |
Not necessarily true... I could run an RS-T at 4-6psi for years without blowing the motor, so long as it's tuned decently.
10-20-2005, 01:04 PM | #6 |
Member#: 90396
Vehicle:2005 Legacy 2.5i Brilliant Silver Metallic |
Tru dat, also once you do blow that stock short block, throw in an STi shortblock and hold on to your pants!
10-20-2005, 01:19 PM | #7 |
Vendor
Member#: 12347
SCIC
Vehicle:ECU ReProgramming Dynapack AWD Dyno |
We ran Aquamist one summer. It worked great....until the pump failed at a track event, knocked the motor like hell and took out bearings, piston and crank. That inexpensive pump cost us quite a bit in repairs.
Nothing against Aquamist, but we steer away from injection on street or track cars. Drag cars...that's another animal Chris I-Speed USA |
10-20-2005, 06:23 PM | #8 |
Member#: 2604
Vehicle:1999 2.5RSt RBP |
mine is still holding strong.
J&S and WI here The J&S doen't see much activity though. I use it mostly as knock detection / safety when tuning |
Similar Threads | ||||
Could methanol or water injection be a replacement for sleeving a 2.5ltr block? | tino | Water/Methanol Injection, Nitrous & Intercooler Cooling | 7 | 08-05-2005 09:15 PM |
U-tec and methanol/water injection on STI | modifyd | Engine Management & Tuning | 4 | 03-17-2005 09:06 PM |
Nitrous or Water Injection??? | Spoolin16PSI | Water/Methanol Injection, Nitrous & Intercooler Cooling | 21 | 03-04-2004 11:10 AM |
Anyone blown their engine with J&S Safeguard installed??? | FLaBrit | Normally Aspirated with bolt-on Forced Induction Powertrain | 9 | 08-25-2003 10:16 PM |
J&S Safegaurd and Aquamist Water Injection | replacement killer | Water/Methanol Injection, Nitrous & Intercooler Cooling | 3 | 05-30-2002 05:27 AM |
