Brakes & Suspension Forum sponsored by The Tire Rack |
08-22-2017, 09:54 PM | #26 | |
Member#: 125739
South East
Vehicle:2007 1500HD Need Brakes? 919.420.0021 |
HB616x HB722x AMG too No rear race pads from Hawk so once we verify shape I will hit them up Carbotech and GLoc for now Might be some JDM goodness since it's the IS-F pad
08-22-2017, 10:16 PM | #27 |
Member#: 141952
Vehicle:2023 M340i |
08-22-2017, 11:16 PM | #28 |
Member#: 125739
South East
These AMG's?
08-23-2017, 03:30 PM | #29 |
Member#: 388366
SCIC
Vehicle:2016 SUBARU WRX(cvt) CBS w/eyesight |
Is that a real companies name or are you being sarcastic??
08-24-2017, 10:00 AM | #30 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
You realize that AMG isn't a specific model, right? On Mercedes-AMG's website there are 52 AMGs, covering the full range from the A-class up to the G-wagen. So, no, that doesn't narrow it down for me.
08-24-2017, 11:40 AM | #31 |
Member#: 363268
Vehicle:2015 WRX STi WRB |
Some of then were black. And some had 2 doors and some were sedans. Hope this helps.
08-31-2017, 11:15 AM | #32 |
Member#: 78417
SCIC
Vehicle:2005 WRX/STI Stage 2 Aspen White |
Here is the writeup I did comparing Brembo GT 6 piston brakes vs. 6 piston Brembo from a RA-R. I have no idea what the 2018 specs are but I can only assume they are similar if not identical to the JDM RA-R Brembos.
https://forums.nasioc.com/forums/sho....php?t=2821654 |
08-31-2017, 11:22 AM | #33 |
Member#: 125739
South East
11-27-2017, 04:58 PM | #34 |
Member#: 54202
Vehicle:ASK ABOUT NEW RCE SWAY BARS FOR STI |
Pulled these off today to confirm a few things.... |
11-28-2017, 10:53 AM | #35 |
Member#: 421271
Vehicle:2015 WRX Galaxy Blue Pearl |
11-28-2017, 11:08 AM | #36 | |
Member#: 125739
South East
The issue is the rotors. Subaru only, drilled, and very expensive. http://www.knsbrakes.com/c/car-items...ace+Brake+Pads |
11-28-2017, 06:29 PM | #37 |
Member#: 54202
ENDLESS MX72 front pads fit and available. Rears are in productions.
Pricey but a LOT of initial bite and no squeaking. Good for novice or intermediate track day. Only squeal after 30 minutes on a back road, then once it kools down no sqeal. love this compound. Had it on Essex AP kit on BRZ, Had it on 15 WRX with AP kit. Had on my Cayman S. Reminds me of Brembo TS20 pad or Pagid Blue 4-2-1 pads. Very impressive pad( as it should be) But pricey. |
06-13-2018, 12:33 PM | #38 |
Member#: 253514
NESIC
Vehicle:2002 VF30 WRX psm |
Just by curiosity does 18 sti calipers have the bolt seize problems like the previous years? My neighbor 15 sti had the rear bolt seize problem and snapped the bolt and stuck! Now he has to drill it out and use helicoil. I've just pick up my 18 sti couple months ago, now wondering should I try to break them all loose and put copper antiseize on them before the heat start baking on them?
08-24-2018, 06:20 PM | #39 |
Member#: 105104
VIC
Vehicle:1979 BRAT / 01 RSTI 99 2.5TS (DEAD) |
does anyone happen to know the piston diameters in the front and rear calipers? Playing with some numbers and would like to see what the balance.
08-25-2018, 06:49 AM | #40 |
Member#: 11554
Vehicle:2018 STI RA World Rally Blue #225 |
Front pad is from Lexus RFA- OEM part number is 04465 0W120. BTW, if you can't stand the dust TRW makes a terrific low dust/no noise ceramic pad.
10-04-2019, 09:47 AM | #41 |
Member#: 195423
TXIC
Vehicle:2001 2.5 RS BRP |
10-04-2019, 02:09 PM | #42 |
Member#: 105104
VIC
09-15-2022, 09:15 AM | #43 | |
Member#: 64405
E. Canada
Vehicle:2018 STi WRB |
Anyways, does this looks like steel inserts to you too? First pic you can clearly see what looks like an insert. Second pic is of the other side of the caliper. It was still quite tight when undoing one of the lower bolts, even with all that anti seize and after the lock washer was decompressed, so I'm not sure if the insert will really help long term, maybe the insert itself at some point could rip off the caliper if the screw becomes rusted in there? Car has 53k miles. |
