01-12-2003, 11:43 AM | #1 |
Member#: 30112
Vehicle:2000 Legacy GT Sedan |
parts vs. coilcovers for legacy sedan setup
If I do not go with the whole coilcover setup, will I not have to get springs, shocks, and...?
Then have a Mechanic put all this on, due to lack of tools? I just think I would do better with a Tein S-tech (these are Eibach right?)soft springs. KYB/AGX struts setup. I only want to drop the car like a inch and use it for daily driver with some on-road racing. Found this setup on another guys car, sounds fine. |
01-12-2003, 12:17 PM | #2 |
Member#: 2609
Vehicle:98 BK-GT White '97 SVX Ebony Pearl |
Sounds cool, except for the mechanic and $$$ part. Why don't you post on your regional forum, as well as here, what/when and most important where? you want to do the swap. Lots of experience on these boards, and willingness to help. You may well find some folks in your area willing to help you out for small(BBQ and/or beer?) compensation, and meet some new friends to boot.
For struts and springs there should be no other parts required, save for an alignment, and brake-bleed if you open the lines, asap after you finish it up. Did mine alone, with no prior experience doing struts/spring compressor stuff. Verrrry happy with the results!! http://home.earthlink.net/~nuburu2/ If you're in my area I'd be willing to help. Glenn O |
01-12-2003, 10:19 PM | #3 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
Thoughts
A common method is this.
Get the KYB/AGX struts for an Impreza wagon. Lowering springs for the Legacy (Whitelines, Eibachs whatever) Install and get an alignment. The Impreza struts have a bottom spring mount that is ~1/2" higher up than the Legacy. This reduces the drop due to the spring by ~1/2". Also the Impreza strut list is longer than the Legacy list. If you get Whitelines (like Nubaru) you have a choice of "control" or "lowering". There is a difference in spring rate and drop. Do a search in this forum. About 1.5 weeks ago I brought up the same things and got back lots of ideas and I added links to a couple sites. I will be going this route in the spring. I don't want too much drop since I have snow to deal with. I also don't want adjustable spring perches due to Auto-X restrictions. |
01-12-2003, 10:52 PM | #4 |
Member#: 21800
Vehicle:2001 Legacy GT Black |
a place here in canada called tom motorsports carrys coil over sleeves for the legacy. im going to try them out this summer and see what they are like. i will post results. i will be running the factory shocks and 17 rota titanium battles...
01-25-2003, 08:11 PM | #5 |
Member#: 14760
Vehicle:2002 Legacy GT LTD Black Granite Pearl |
the KYB/AGX struts for the Impreza fit MY02 Legacys??????
01-26-2003, 12:33 AM | #6 | |
Member#: 768
Vehicle:OB, volt, 911, ram 1500, 1098s, m620 |
01-26-2003, 01:04 AM | #7 | |
Member#: 8048
International
damned multi-links.. |
01-26-2003, 12:47 PM | #8 |
Member#: 30112
Well just so I am clear, what are coil overs. They look just like if I was to go get a AGX shock and Springs. Also if I am more interested in performance than looks, I would get something like TEIN CS Coilovers? For fun, can I get any of those in "FLEX" so if I want to adjust them from inside the car I can? Think that FLEX part is more a toy than anything.
01-27-2003, 12:12 AM | #9 |
Member#: 30669
OOPS, my bad. I did not notice his MY.
Froggert is correct, when SOA changed to the multi link rear, some of the options went out the window. Sorry for that. "I promise to look closer next time." |
Similar Threads | ||||
WTB:91-93 legacy sedan for parts | ImprezaSti'd | NWIC Private Classifieds | 3 | 01-01-2008 08:43 PM |
Parting out all '95 Legacy sedan | swordofdoom | Complete Car Part-Out | 1 | 03-20-2007 06:49 AM |
Stromung Midpipe: diff. part for Legacy vs. Impreza? | snowone | Normally Aspirated Powertrain | 0 | 05-01-2004 02:35 AM |
sedan parts vs wagon parts | dan avoN7 | Newbies & FAQs | 8 | 05-28-2003 11:01 AM |
WRX factory strut part numbers identical for wagon/sedan? | Cosworth | Brakes, Steering & Suspension | 2 | 08-01-2002 08:10 AM |
