10-27-2012, 05:10 PM | #1 |
Member#: 306908
TXIC
Vehicle:2003 WRX White |
modded injectors
I have a 03 wrx and romraider. i modded my injectors and am having a hard time what the scaler, tip in enrichment, and latency should be at ive tried some that people have had work for them but they arent for me. i put my stock map and intake back on my car. How can i get these right?
10-27-2012, 09:07 PM | #2 |
Member#: 306908
TXIC
My af correction goes down to about -20 then raises to 16 then zeroes out after restarting the ecu but my af#3 for 16 bit ecu is -.78
10-27-2012, 11:44 PM | #3 |
Member#: 136566
TXIC
Vehicle:2002 Impreza WRX |
Clear you inbox, it is fulled.
10-27-2012, 11:52 PM | #4 |
Member#: 306908
TXIC
Cleared
10-30-2012, 10:22 PM | #5 |
Member#: 207905
TXIC
Vehicle:2005 forester xt silverf |
Correction. You mean my stock intake.
Get that car tuned and quit sleeping. |
11-12-2012, 09:04 PM | #6 |
Member#: 149262
Vehicle:03WR rallycarFXTleg PrimerGrey |
How did you "Mod" your injectors? Did you get them on a flow bench?
11-14-2012, 06:03 PM | #7 |
Member#: 159743
Vehicle:07 STI Limited TurboMike Tuned 2.35 |
the scaling that i use that gets pretty close is 750cc. Latency they are the same injectors so you shouldn't be playing with those. After you get the car running i normally take the lowest maf value up to about 1.6-1.9 volts and look at the front af correction. if it says -20 then i hit the - button about that many times, interpolate from the 1.9 up to say 2.4 and start it again. You should get it pretty dang close from that then romraider will do its magic... but WOT you are gonna have to play a bit to get it where you want
11-29-2012, 07:16 PM | #8 |
Member#: 136296
TXIC
Vehicle:2005 STi OBP |
When doing a baseline for a car, you can only tune for EITHER the intake, OR the injectors. You can't do both at the same time. Put a stock intake back on the car and tune the injectors. Once you have the injectors dialed in, put your aftermarket intake back on and do your scaling there.
11-29-2012, 07:19 PM | #9 | |
Member#: 283968
Vehicle:2003 WRX MBP |
http://www.injectordynamics.com/WhosGettingDrilled.pdf |
11-29-2012, 09:25 PM | #10 |
Member#: 59837
SWIC
Vehicle:2004 Spec-C Type RA What MAF? -Speed Density! |
Set the car up like you want it to be, with all the mods. You sure as hell can tune everything at once.
Set the injector scalar to 820CC and latency of 6.5V-4.36 9.0V-1.98 11.5V-1.42 14.0V-1.16 16.5V-1.00 turn the timing way down and go do some pulls. If the WOT fueling is lean decrease the scalar by 10cc and try again, if it is rich increase the scalar by 10CC till you are close to your target fueling at >3V MAF. Scale your closed loop MAF scaling. IF you have any fueling issues you may need to tweak your MAF scaling at specific points. Your fueling should be pretty much set then work on your timing. |
12-07-2012, 01:11 AM | #11 |
Member#: 155412
Vehicle:2004 WRX Wagon PSM |
Are your injectors re-drilled or do they just have the spray pattern cap taken off?
02-02-2013, 09:40 AM | #12 |
Member#: 306908
TXIC
Spray caps are takin off.
02-04-2013, 07:52 PM | #13 |
Member#: 155412
Get them cleaned and flow tested...that way the guessing game will be alot shorter when scaling and tuning. Let us know how it goes.
02-14-2013, 05:31 PM | #14 |
Member#: 267815
South East
Vehicle:Be in awe dont hate .) |
^^^^Yeah....the real fun is gonna begin when you get those injectors back and there flow rates are sketchy
ie... 820,825,810,830 mine were 816,820,820,830......wasnt fun gettin em to act equal Still ****in wit it actually lol |
02-14-2013, 06:58 PM | #15 |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
Personally, I'd deal with 816, 820, 820, 830 by putting 816 in cyl 4 (rear driver side) and the others wherever.
Cut stockers aren't going to get you perfectly matched injectors... It's a cheap way to get ~820cc injectors. There are downsides to that. You put the lowest flow in #4, as that's what's most closely monitored by the knock sensor and you start tuning with a scalar close to the average of all 4. If you need better than that, you buy aftermarket injectors that are flow matched. You got injectors that are within +/- 1%. That's really not the end of the world. |
02-15-2013, 01:05 PM | #16 |
Member#: 130063
Vehicle:2003 WRX Silb |
I've tuned tons of modded injectors. I've done so many for a while there I was modding a set every weekend. Here's my Experiance
Scalar on 93. 820 Take stock lats and multiply them by 1.05 You should be golden then, If your still having issues do you have a intake on the car? |
