09-04-2005, 05:42 PM | #1 |
Member#: 35924
UP Rattle but no leak / What kind of replacement nut for UP studs?
Two-parter here.
After putting in an uppipe, I'm leak free but I seem to have aquired a rattle. It's noticeable slightly at idle and louder only at sub-1000rpm engine speeds. After that it either goes away or is drowned out. In trying to track it down, I removed the turbo and exhaust manifold heat shields but the rattle is still there. I noticed that one of the uppipe studs is missing a nut on top. It's the one closest to the passenger side/front of the car - it doesn't connect through the turbo, only through a bracket that the turbo heatshield bolts up to. I figure that's the next most-likely candidate for the rattle. Can anyone tell me what kind of nut those use? I can provide a pic if this is confusing. Also, if that's not the issue, are there any other common sources of rattling from an uppipe install that I may not have thought of? Thanks.
09-04-2005, 10:45 PM | #2 |
Member#: 54942
South East
Vehicle:2004 WRX |
I believe it's a M10 1.25, same as the rest of the nuts attaching turbo to UP and DP; you can grab a pack at Advance for a few bucks, Grade 8. They also carry a nice plastic box assortment of metric bolts, nuts & washers, all Grade 8, for twelve bucks or so. That size is in there, as well as a bunch of others you may find yourself needing down the line.
That particular nut connects the upper end of the UP & turbine side of the turbo to a bracket, that connects to the block. Without it, the next hard connection point is about halfway down the DP. It could be the source of your rattle. |
09-05-2005, 07:39 PM | #3 |
Member#: 35924
Thanks!
I picked up some M10 x 1.25 nuts, and that box assortment for next time. Nut did the trick, no more rattle. |
09-05-2005, 08:09 PM | #4 | |
Member#: 49895
NESIC
Vehicle: 09 Forester 06 Legacy 2.5i Wagon |
You can also pick up the correct flanged nut at the dealership for about $1.00.
09-05-2005, 08:28 PM | #5 |
Member#: 35924
Dealership would have been the next stop, but it's labor day weekend and I'm impatient.
I was able to find a replacement at Pep Boys that was flanged like the OEM ones. |
09-05-2005, 10:42 PM | #6 | |
Member#: 54942
South East
Vehicle:2004 WRX |
09-05-2005, 10:42 PM | #7 | |
Member#: 54942
South East
Vehicle:2004 WRX |
09-06-2005, 07:48 AM | #8 | |
Member#: 49895
NESIC
What kind of lug nuts are there in the world...? | NewShockerGuy | Tire & Wheel | 5 | 01-19-2006 05:30 PM |
Replacement nut for Up Pipe stud | Gonz | Mid Atlantic Impreza Club -- MAIC | 8 | 05-17-2005 10:34 AM |
What kind of an Audio set-up is in your STi? | essogas | STi Forum Archive | 28 | 08-30-2003 01:12 PM |
A little OT, but what kind of tranny fluid for a 1st Gen SHO | blue-sun | Transmission (AT/MT) & Driveline | 1 | 02-11-2003 10:51 PM |
What kind of lug nuts are you using with Rota rims? | Need4Boost | Brakes, Steering & Suspension | 29 | 12-27-2002 11:58 AM |
