11-01-2008, 11:39 PM | #1 |
Member#: 191422
Swapping a 2.2 into where a 2.5 once was.
It can be done. I know you guys probably already know this, but, perhaps I could help out if someone decides to do this down the road with their own vehicle. When I searched for it, I got almost nothing. So I kinda winged it.
Let me start with the story behind all of this... Since late 2002, I've driven Subarus. I've wrecked a few, sold a few, and I am currently driving a 1993 NA 5 speed. It has 207K, and I would not think twice about driving it across the country. I love these cars, especially the 90-94 Legacy. Well, a few months ago, my 19 year old little sister found a 1998 Forester with 120K for $3,800. I drove it, looked at it, and all seemed well. I am not in the business of fixing cars for family or friends, because I do not want to hear about a problem 24/7 if something goes wrong. With this in mind, I suggested she change the timing belt soon, being an interference engine, with no history available, I figured this was a good suggestion. I also advised her to flush the transmission fluid as well. About a month after she had it, she took it to the one local Subaru garage. We have a an actual dealer here, along with two independent garages that deal mainly with Subarus. They called her, and said they noticed some oil in her coolant. So they went ahead and checked out the engine, and noticed some holes drilled into the thermostat. The car had overheated at some point, and it was being masked with these holes. It was not acting funny at all, but it would probably become more noticable when winter came around. They wanted $1,500 to do the head gaskets. This is where I come in. As much as I did not want to get involved, I offered to to the head gaskets for her. I could get them done coming in around $500. I ordered a full engine gasket set, Subaru of course, radiator hoses, thermostat, and some Subaru coolant. Of course, some other odds and ends were included. I spent an afternoon on the car, with the engine in the vehicle, heads were off. Took them to the machine shop, had the milled, they were warped a little. When they were there, new valve seals were installed. The next afternoon, I had the engine running. Let me say this though, putting the heads on an EJ25, while it's in the car, is kind of a bitch. The torque sequence is like, wtf? lol Ok, so I started the car, and about 20 minutes in, making sure it was running right, hitting proper temp, all of that... I hear "clunk" and the car stopped. I run out under the hood, try to turn the crank, nothing. I can move the timing belt up and down with my bare hands right at the tensioner, after I took the drivers side cover off. It must have skipped a few teeth, and it died. The guy at the Subaru place cranked it down with a vice, and I said that the manuals said to do it differentlly, and he said he has done it 100 times. So, I thought maybe he was on to something... wrong. So I got online, and I got the idea of the 2.2, but NOTHING was available for it. The usmb site was hacked, and I could not get to the two links I did find with potential info. So, I did manage to find out that I needed a 95 2.2. I guess they switched to a single exhaust port on the newer ones. I managed to track down an engine with 195K for $200, complete. The day I went out to get the engine, the place called me and said they dropped it... the driver side cam pulley was messed up. I was cool, I have a spare. When I got to the engine, I noticed the cam was snapped right off. I managed to get the engine for $100, with all electronics and sensors attached. So I when I got it home, I found the head was cracked on that side... I had a spare, but it was from a 1990. I did some research, and it was grey, some places seemed to think it would work fine, others didn't. I know from looking at it, the cam lobes seemed wider on the 1990. So here is what I needed to do... I am not going over the obvious service steps like unhooking, and draining and stuff. First, I took the 2.5 out. With that engine out, I removed the oil pump, timing belt pulleys, and water pump, all were much better than the 1995 engine. These parts all bolted right up to the 1995 engine. I replaced the rear main seal, and the oil separator seal while it was out. I guess the thing you really want from the 95 is the intake manifold, and the electronics with it. The harness will plug right up to a 1998 Forester, and I would assume any other Subaru in that generation. I swapped the flexplates, not only was the 95 messed up, I just did not want to take chances. I left the EVERYTHING in place on the 95 manifold, I did swap out the throttle body, and the IAC valve, simply because they were in much better shape on from the 98. I replaced the 95 head with the 90 head I had, I figured it SHOULD work, from what I could find out, but you never know... When I replaced the head, I decided to go Fel Pro for the head gasket. Good thing I did, when I opened the box, I noticed it was made in Japan, and it had a FHI logo on it... while saving a few dollars. Subaru head gasket in a Fel Pro box, works for me. I used the rocker assembly from the 95 on the 90 head, to be safe. The center timing belt cover is the same on the 2.2, or the 2.5. I actually managed to use a lot of parts from the engine kit with this, which was cool. Some of the vacuum lines are different. I guess the 95 still has a charcoal canister. There is a line right below the fuel, and fuel return lines that leads to this, it goes through the metal tube, and into the canister. I eliminated this tube, and ran a line right from the throttle body to the solenoid, and then with a chuck of vacuum hose, right into the one below the fuel lines. The power steering hoses do not line up, so you will need to make something for them, I did, but they seemed pretty stable without. I may go into a bit more detail on this, but this pretty much lets you know what you should know. From what I have learned any 1990-1995 2.2 will work. The 95 has the intake and electronics you need though. If you find a ****ty 95, and have a great engine from an earlier year, score. Now my sister has a 1998 Forester with a 2.2. No head gasket issues, no interference. I drove the car for a little while, and it felt fine, sure there is less power, but for normal driving... I could not tell a bit. I did not throw a check engine light ONCE. Everything seems to be running well since then. Like I said, I will add, and update. If any of you have questions let me know. I figured there needed to be SOMETHING out there for this topic! David
11-02-2008, 07:31 AM | #2 |
Member#: 17548
Interesting swap. Less power is never bad for a younger driver, though.
11-03-2008, 06:08 PM | #3 |
Member#: 159682
NESIC
Vehicle:1995 WRX 2015 F150 |
Yes, this is a very common and easy swap. I have done almost 20 of the phase 1 EJ25 > EJ22 swaps. Cheap and reliable, everything just plugs in and works, everyone that I did has a happy owner!
11-03-2008, 07:09 PM | #4 |
Member#: 192143
I was unaware this would work into a 98 Forester (DOHC). Subaru360 has this down to a science with Legacy's. I've done several myself.
FYI couldn't find anything real simple for a 99 Forester to swap. Wiring is different so the usual 2.2 swap didn't look do-able. Dave |
11-03-2008, 07:25 PM | #5 |
Member#: 159682
NESIC
Yes, EJ22 phase 1 works great on a 98 forester.
I working on a 2000 legacy EJ25 phase 2 now. I think an EJ22 phase 1 may be do-able if you want to take the time to read over the wiring diagrams and splice all the sensor wires on the engine harness, most of the sensors are different. I have not attemped this swap yet, but may sometime in the future. |
11-03-2008, 11:54 PM | #6 |
Member#: 191131
Vehicle:06 LGT Silver |
I was thinking about doing this swap. I have a 97 subaru legacy 2.5l, and well the engine seized, so I am looking at any options. And the 2.2l swap is an option right now. Thanks for the write up, I might need it.
11-23-2008, 04:44 PM | #7 |
Member#: 130759
NESIC
Vehicle:2002 Forester S |
I had asked this in another topic, but I thought I'd ask it here too.
I've got a 2000 Phase II 2.2L from an Impreza that I'd like to put into a 1999 Legacy. How compatible would it be if I got a 1999 Legacy GT 2.5L to put it in (wiring and ECU)? And if I just got a 1999 Legacy L which had a Phase II 2.2L it should hook up no problem, right (I'd think so, but I'm asking because you never know sometimes...)? |
11-23-2008, 05:04 PM | #8 | |
Member#: 159682
NESIC
11-23-2008, 05:15 PM | #9 |
Member#: 130759
NESIC
I'm quite sure that in 1999 the Legacy was stuck with the Phase I 2.5L but got the Phase II 2.2L.
http://wiki.nasioc.com/wiki/EJ22#EJ22 http://www.cars101.com/subaru_legacy_archive98_99.html |
11-28-2008, 02:58 PM | #10 |
Member#: 123362
Vehicle:'97 E36 M3 351W FTW |
Maybe I missed it in one of the previous posts but if you're looking for a 2.2L I have one that I just pulled from my 98L (86,xxx miles) and don't plan on using it. Send me a PM if you are in need of a motor.
11-30-2008, 12:25 AM | #11 |
Member#: 74907
NWIC
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
The only big difference between the Phase I and II EJ22 are the heads. If the heads look like SOHC EJ25 heads, then its phase II. If they look like normal run of the mill EJ22 heads, it is Phase I.
AFAIK, The phase II EJ22 was only in the 2000-2001 model year, then it went all 2.5. ~Josh~ |
11-30-2008, 12:31 AM | #12 | |
Member#: 159682
NESIC
12-01-2008, 07:37 PM | #13 | |
Member#: 15543
Vehicle:555 Having a Subaru shop means too many cars |
99's also got the phase 2 Ej22 |
12-15-2008, 10:22 AM | #14 |
Member#: 183617
SWIC
Vehicle:1997 Legacy White |
So from what y'all are saying. . .doing the opposite of this swap in order to gain a little more power is a bad idea? I have a Legacy with a tired 2.2l and I was considering swapping in the 2.5l, but everything I've heard says they suck and I am better off with my reliable snail-wagon.
12-15-2008, 12:44 PM | #15 | |
Member#: 159682
NESIC
12-28-2008, 02:55 PM | #16 |
Member#: 198565
Vehicle:96 subaru outback blue |
69subaru360 can I only use a 95 2.2 or can I use a newer 2.2 engine?Maybe change exhaust?Thanks.
12-28-2008, 03:22 PM | #17 |
Member#: 159682
NESIC
12-28-2008, 03:29 PM | #18 |
Member#: 198565
Thanks!
12-28-2008, 04:07 PM | #19 |
Member#: 106631
Vehicle:98 wagon gringo green |
pics of swap or sister?
01-06-2009, 09:23 AM | #20 |
Member#: 199333
2.5 swap into 95 legacyL??
what all is required to swap entire 1996-1999 2.5 nonturbo(NA) motor into 1995 legacy L with a 2.2 sohc body, will engine slide into trans, what wire harness do I need, ecu from2.5?
01-06-2009, 10:23 AM | #21 |
Member#: 159682
NESIC
03-31-2014, 04:52 PM | #22 |
Member#: 275921
Vehicle:2006 forester XS dark blue |
i know this thread is a few years old. ima gonna take my chance and ask some questions regarding my swap. im planning to swap a 2.2L into my 98 forester S( DOHC). what year of the 2.2L should i be looking for?
hoping someone will respond to this thread haha |
03-31-2014, 05:39 PM | #23 |
Member#: 94350
NESIC
95/automatic is the "perfect" engine for it. 90-98 2.2 will all work with varying amounts of swapping required.
03-31-2014, 06:15 PM | #24 |
Member#: 275921
12-08-2014, 02:52 PM | #25 |
Member#: 351621
Vehicle:1998 legacy 2.5gt lt red |
If anyone is still checking on this thread, I have major questions. I have a 1995 impreza Wagon with a 2.2 manual, and a 1998 subaru legacy 2.5 gt limited auto, what would I have to do to swap the drive train from the impreza into the legacy?
Engine swap, '06 2.5i into '00 2.5RS--Direct swap? | singincanary | Subaru Conversions | 13 | 10-01-2007 09:47 PM |
Swapping a 2.2t Shortblock into my NA 2.5DOHC then Turbocharge | MY99 2.5GT | Subaru Conversions | 15 | 11-08-2005 10:32 AM |
Do they make a wiring harness kit for a JDM STI 2.0 into a '99 2.5rs? | underground-mpyre | Subaru Conversions | 12 | 10-22-2004 08:44 AM |
02 Wrx Swap Into A 99 2.5 Rs What Cani Use What Cant I | GODSON | Subaru Conversions | 10 | 10-12-2004 03:56 PM |
swapping 2.2T into 95L 2.2N/A..questions | scottsubarus | Normally Aspirated Powertrain | 4 | 04-01-2003 08:37 AM |
