Welcome to the North American Subaru Impreza Owners Club Thursday September 19, 2019
Old 01-13-2015, 08:29 PM   #51
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Originally Posted by Offroadguy View Post
I can see TD40L on my JDM turbo installed in the car. I might be able to get more numbers if it helps.
Hi,
Thanks for the info...I'd bet it's the exact same as US. But there are a few other variants of TD04 that might have been used, such as the TD04HL-19T (a turbo I'd like to have!).
Next, hopefully someone w/the JDM EJ205 from a 5-speed / Manual-equipped car will reply.
TD
wtdash is offline   Reply With Quote
Old 01-16-2015, 03:52 PM   #52
X-Mode
Member#: 344780
Hoping somebody can help me out with the following. My nephew has just ordered a 2000 JDM Subaru Legacy B4 from an importer here in Canada. It has a 2L twin turbo engine. So it would be a EJ20? What is the proper designation of what model of engine that it has? What is the correct oil filter for this engine here in North America? Thanks in advance for your help!
X-Mode is offline   Reply With Quote
Old 01-19-2015, 07:26 AM   #53
eph
Member#: 83120
1992 SS EJ225T
cj91legss
Sorry for the delay, still new to this site.
The JDM engine had a flex-plate on it that bolted right up to my torque converter. Yes, mines an automatic
The turbo looks identical, so I used the JDM, waste gate and all.
The JDM intake manifold had no TGVS on it so I used the USDM one. I don't know how hard it would be to make the JDM intake work, it would flow much better for sure and the retune would be able to negate the DTCs being set.
I'm not sure what years of engines will work best.
You shouldn't have to change all the timing gears. I changed the crank gear and one cam gear, the ones with the sensors on them. I kept the JDM crank and cam sensors.
Got lucky, my engine knock was the timing belt tensioner rattling. I compressed the rod on the tensioner too fast and blew out the seal on it when I changed the timing components.
Here is a pic of the rear of the crank pullies, you can see the signal sent to the ecu is different.
http://i.imgur.com/SqWVWnr.jpg
That timing crank pulley looks like a phase 1 pulley. Maybe you got a phase 1 engine?
This thread is a good read, I'm looking at heads options for my swap at the moment.
eph is offline   Reply With Quote
Old 03-15-2015, 07:27 PM   #54
209WRX4life
Member#: 416040
Subaru Stars jdm ej 205 swap
I recently ordered a JDM ej205 with avcs, intercooler, and mafs from japan direct in Canada. motor has 51k on it not sure what year. to do the swap all i did was remove all the wiring that went to fuse box alternator etc. dropped it into my stock 02 wrx it bolted right in with no issues timing looked new along with the other belts plugged everything in, adjusted the clutch, and had to replace the iacv. been driving it for 3 days now with no problems or cels. don't know if this helps anyone but if you have any questions feel free to ask.
209WRX4life is offline   Reply With Quote
Old 03-15-2015, 11:19 PM   #55
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Plz clarify:
---wiring>>>> Did you replace individual wires, the whole harness or swap the Intake Manifold which includes the harness?
--- IACV>>>Why replace? What was wrong/different/incompatible?
--- Throttle>>Cable or DBW on the JDM engine ?
---Timing>>You didn't swap the cam and/or crank sensors?
---AVCS>>>Not using?
If possible, post a pic or list the info from the passenger side timing cover, like this:
Thanks
Old 03-16-2015, 01:27 AM   #56
209WRX4life
Member#: 416040
Originally Posted by wtdash View Post
Plz clarify:
Thanks
The motor I ordered came with the main fuse box/relay box and harness that went to the alternator, that's what I took off, the Ecu wires and all coil packs and spark plugs that came with the motor I'm using.
I changed the IAVC because when I did first start it threw a CEL for the IAVC so I took it off and it looked pretty dirty.so I took the one off the motor I was replacing cleaned it up and put it on. started it and she hasn't thrown a code since.
The throttle is cables.
Timing, I did not have to change anything.
and AVCS, I honestly don't know i was reading threads today trying to determine what people meant by AVCS wiring and having to order a different harness? forgive me I'm pretty new to really working on subi motors i plan on using the motor i pulled to learn more about the motor by doing a rebuild.
It was hard to get a pic of the whole number in one frame with it installed but here are the numbers as I can see them EJ205DX3BE-1BA 068026 EF10
I was also reading that some JDM motors are a 9:1 compression but I couldn't find out how to find out. I also plan on getting a tune done but was looking for exhaust first. hope this helps and again plz forgive my newbness.
Old 03-16-2015, 10:58 AM   #57
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
^^Thanks for the info.
I believe there are 3 plugs for the harness(es) that run from the engine to behind the battery.
You reused your original harness for the AC and Alternator, and used the two other JDM harnesses for the CoP (coil on plug), etc. , correct?
"ECU wires"...you did NOT run the harness wires to the ECU in the car, correct?
There should be wiring for the AVCS on the JDM engine. Since they DON'T exist in the harness to the ECU from by the battery of your car, you'll need to buy the http://www.iaperformance.com/ harness that'll run from the AVCS connectors on the engine back thru the car's firewall to the ECU to run the AVCS.
Yeah...you'll need a tune if it's indeed 9:1 CR. I don't know how to tell.
Thanks again
Old 03-16-2015, 04:03 PM   #58
209WRX4life
Member#: 416040
Subaru Stars
yes, there are 3 main plugs coming off the motor, but two are on the driver side behind the battery and one is on the passenger side. there are two other plugs for the passenger side but one is an exhaust temperature sensor the other is a front o2 sensor.
Correct, I used my a/c, alternator and fuse relay box and wires, but kept the CoP and the main harness with the three plugs that came with the motor.
The only wires I plugged in were the main wires; the two on driver side behind battery, and the one on the pass side, along with the temp sensor and o2 sensor. so no i didn't run any wires straight to the ecu.
I think the wiring for the avcs was on the fuse/relay box harness that i didn't use. i took pics but am new to this sight and don't know how to post them. Sorry for any confusion.
Old 03-16-2015, 04:09 PM   #59
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Cool - thanks for clarifying.
Pics can be UPloaded (hosted) to a photo sharing site (free) such as flickr. Then copy the URL from the site and paste into the image (mountain/moon) icon.
Search online for better instructions, but I don't think pics are necessary in this case.
td
Old 03-16-2015, 04:18 PM   #60
209WRX4life
Member#: 416040
Your welcome, I hope some of that helps.
Thanks for the picture upload info.
Old 04-03-2015, 08:32 PM   #61
BuggaSaurusRex
Member#: 395637
2003 WRX Sedan
Hi,
Im currently about to drop in a v7 JDM ej20 with AVCS into my 2003 v7 usdm wrx. AVCS will not be activated. Emissions are not an issue for me, so the intake manifold from the JDM motor will be retained. After it is placed in the car I will have a dyno tune by Cobb.
From what I have read, it seems that v7 motors will run properly without switching cam gears and the main crank sprocket? There seems to be a lot of confusion when people post without clarifying which generation motor they have.
My question is, if the JDM engine is from the same generation as the USDM, all that is needed is to plug the wiring harness in at the proper junctions (brown & grey near the battery)?
BuggaSaurusRex is offline   Reply With Quote
Old 04-08-2015, 09:09 PM   #62
snow60X
Member#: 295469
2003 Forester 2.5X
My engine was a 2002-2003 JDM EJ205 that came with a JDM STI ECU and I just dropped it in, plugged the harnesses together and wired the AVCS in with the IAPerformance kit and then tuned it with Steve at IAPerformance. Very easy to do and no swapping cams or anything. Complete plug and play. You don't have to wire the AVCS at all but why not? It's an extra $200 but super easy to do if your engine came with the JDM ECU. Just keep the USDM one and plug it in when you need to do emissions or smog and get the tune ported from the JDM one to it so you can safely cruise with the USDM one if you need to drive far to get to an emissions/smog place.
The only issue I had was with my ECU not being in the ROM Raider system cause it was a rare option, Automatic JDM STI. Just unlucky but after I got around that issue with Steve it was easy. I ran out of time to finish the tune but I'll have 2 weeks off that I can knock it out and finish it. Its an easy swap and a bit nerve wrecking while waiting to see what condition the motor you get is in but I was satisfied with Dallas JDM
snow60X is offline   Reply With Quote
Old 04-10-2015, 03:43 PM   #63
GreeleySubie
Member#: 412984
2005 WRX
Red
Hello all,
I am currently trying to drop in a JDM ej205 engine with no avcs into my 2005 WRX. Bought the engine off of ebay, shipped from Canada but assuming it was imported from Japan. Went into the shop today to switch out the turbo and injectors that I was going to put on my old USDM ej20 engine and noticed that the JDM ej205 had the yellow sidedeed injectors? Didn't notice anything else that was completely different. Both engines have been stamped with "ej20". Still confused with the yellow STI style side feed injectors. Is it just a matter of switching over the fuel rails from my wrx? Is the engine still plug and play after that? Would it be a better route to return the injectors I had bought for my wrx and buy larger sidefeed injectors? If I do go that route would it still be plug and play and just in need of a tune?
Thanks
GreeleySubie is offline   Reply With Quote
Old 04-10-2015, 03:55 PM   #64
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Hi,
I'd just swap the Intake Manifold (IM).
Injectors go into the TGV's and I'm not sure if the TGV's are swappable between the Top-feed and Side-feed and still fit the US IM.
And are you sure it HAS TGV's? This ONE on ebay has side-feed yellows too.
Depending on the year of the JDM 205, those 'might' be the older 480cc injectors ( I doubt it), which were NOT interchangeable w/the US STi side-feeds injectors.
GL,
Td
Old 04-10-2015, 04:12 PM   #65
GreeleySubie
Member#: 412984
2005 WRX
Red
Hi,
GL,
Td
I didn't get a chance to take a look at the TGV'S. Will head over tomorrow and will get a better look. So are the injectors on the ej205 interchangeable with any other aftermarket injector? Still using the WRX ecu. Would any of this affect plug and play?
Old 04-10-2015, 04:44 PM   #66
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Which EJ205 - US or JDM? Regardless, I'm sure either version has upgrade options.
If those JDM side-feeds ARE 440cc or 480cc the stock WRX ECU should be OK? But as a reference, JDM STi PINKS (565cc) and USA STi/WRX Dark Blues (565cc) are NOT the same. Cobb and others say to NOT interchange when using their OTS maps...due to latency, I believe.
BUT You can use most any injector size (and maybe style - top vs side) ONLY IF YOU GET A TUNE.
The problem I see here is that you don't know exactly what injector you have on the JDM. If you pull one, take a pic and note the P/N there may be help on here / online.
I still vote for swapping IM's. .....and replace your turbo inlet hose while you're @ it.
Read thru THIS post too.....probably covered on here, but didn't look.
Old 04-10-2015, 08:03 PM   #67
GreeleySubie
Member#: 412984
2005 WRX
Red
That makes sense. I was already planning on getting a tune because of the bigger turbo and injectors I have! I will go ahead and switch the IM's and turbo inlet and read through that post. Will there be any need to tune for the actual engine? I know the CR on both should be the same.. Will play it safe and do some more research. Thanks
Old 04-10-2015, 08:06 PM   #68
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Rumor is the CR is 9:1 on the JDM EJ205, but AVCS or Non-AVCS? I don't know. Get a conservative tune and go from there.
Old 04-10-2015, 10:32 PM   #69
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Got a reply on a set of JDM 205 SIDE-feed injectors on Ebay:
Subaru Impreza WRX JDM EJ205 Side Feed Fuel Injectors w/ Rails OEM 02 03 04 05
I wouldn't call this definitive, but worth noting:
Originally Posted by busted_finger_motorsports
Everything I could find states 444cc for the jdm 205.
Old 04-11-2015, 12:09 AM   #70
GreeleySubie
Member#: 412984
2005 WRX
Red
Talking to a mechanic Monday and seeing what we can do then. I think 444cc sounds about right. Wondering about switching over fuel rails from old wrx engine and going with top feed? Ideas?
Old 04-11-2015, 12:21 AM   #71
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
I'm confused...if you put your old/US IM on it's a done deal. Those ARE top feed. What's the issue???
What 'bigger injectors' do you have??? BOTTOM-Feed?
Old 04-11-2015, 02:18 PM   #72
GreeleySubie
Member#: 412984
2005 WRX
Red
Sorry I was a little confused I thought you meant getting an STI IM to match the side-feed injectors! So switching over my wrx IM and fuel rails, correct? Wondering if I should port the TGV's and IM while it's off... The bigger injectors I have are top feed to replace old WRX injectors
Old 04-12-2015, 01:52 PM   #73
AlexWRXbruh
Member#: 373710
2002 Subaru WRX
Porsche White
Default Jdm Ej205 Into Usdm 03 Wrx?
For anyone wondering...another option is buy an ej20g long block and transfer the ej205 heads, manifolds, accessories and all timing components to the ej20g shortblock using cometic 1.3mm gaskets and you'll have a BEAST motor for the price. My jdm ej205 blew up after 6k miles...still an open deck motor that cant withstand a good beating, while my ej20g is closed deck and comes with forged pistons and sti rods
AlexWRXbruh is offline   Reply With Quote
Old 04-12-2015, 01:55 PM   #74
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
^To clarify, not all the EJ20G's are closed-deck. Only the very early years, from everything I've read, and not that common any more.....and the forged pistons depend on the year.
List HERE.
EJ20G Open (left) vs. closed:
Old 04-18-2015, 02:22 PM   #75
subaruvirus23
Member#: 393229
04 wrx
black java
Do you know what ecu's to will run the avcs and work with romraider, I have a 04 usm wrx with an 03 jdm ej205 and ecu, but the ecu will not go into test mode on ecu flash. I have the iap wiring kit in and a e tune lined up already also
subaruvirus23 is offline   Reply With Quote
