Welcome to the North American Subaru Impreza Owners Club Wednesday March 20, 2019
Old 04-19-2003, 12:45 AM   #1
grantn
Member#: 25398
2005 STi
Default Need Help
i changed the headers, up and down pipes and stealth back and the car seems to be making more noise than it should. additionally, i dont think the turbo kicks in because the car has lost a lot of power. also there is some smoke and smell coming from the turbo and no CEL.
PS: GT-Spec Headers and uppipe, TurboX Stealthback, OEM muffler.
grantn is offline   Reply With Quote
Old 04-19-2003, 12:52 AM   #2
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
The smell and smoke is prolly because it is new and is burning off the residue oil or paint. It should go away is a short time, should. Headers do make the low end punch not as hard, but the power band is more linear and you can rev past 6500rpm without the power dropping off. The oem muffler is a bit restrictive considering you are running a free flow up front. Also, you may have to reset the ecu. It has to learn all over again since you modded the engine. I have the Maxim headers and my car did the same thing.
Ver.III is offline   Reply With Quote
Old 04-19-2003, 01:33 AM   #3
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
Sounds like a leak in the uppipe to me.
slim speedy is offline   Reply With Quote
Need Help, Need Help nicholas112481 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 11-10-2010 01:24 PM
Need help!! Need to find a +12v switched wire NOW! Please help! nxwrxfx Electrical & Lighting 16 04-25-2006 05:29 PM
Hard Drive Recover Help much needed... ATA RAID 0 knowledge needed HELP PLEASE!!! 2k2 Off-Topic 63 12-24-2003 10:35 PM
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-18-2003 12:11 PM
Need help!Need flywheel bulletin from SOA.Please help. RallyeX General Forum Archive 3 06-01-2000 07:57 AM
