Welcome to the North American Subaru Impreza Owners Club Sunday July 21, 2019
Old 08-28-2007, 02:46 PM   #1
MMastro
Member#: 18230
1993 EG Civic/ITR
Default '02+ steering rack in '00 by swapping pinion valve assemblies?
I'm swapping my entire '02 wrx engine and suspension into a '00 RS. Now many people use the RS suspension in there swaps and just change the PS lines. However, since I want to use the RS steering column with the WRX rack/suspension that won't work.. Many people modify their universal joints to mate the two, but my question is why hasn't anybody done this...
We pulled the "pinion and valve assembly" (#27 in wrx manual diagram below) as well as the one from the RS and they appeared idenitcal... So we then swapped the RS one into the WRX "valve housing" (#22 in diagram) and it fit in fine. Has anybody done this? Is there any reason why this shouldn't be done? I've heard time and again that these steering racks are the same, so why don't people do this instead of welding together the u-joints?
MMastro is offline   Reply With Quote
Old 08-28-2007, 04:11 PM   #2
sidewayz
Member#: 5810
2001 S366 2.5RS
why are you bothering to swap the suspension over????
sidewayz is offline   Reply With Quote
Old 08-28-2007, 04:32 PM   #3
MMastro
Member#: 18230
1993 EG Civic/ITR
I have brand new KYB AGX's, Eibach lowering springs, & sway bars from my totaled wrx...
Old 08-28-2007, 11:34 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
still don't see why you don't want to use the rs rack ?
is the wrx a better ratio?
Old 08-29-2007, 01:44 AM   #5
moss
Member#: 10197
I believe the 04 STi rack is a slightly better ratio.
05+ is idea... but they're attached to the crossmember
moss is offline   Reply With Quote
Old 08-29-2007, 01:53 AM   #6
trowa
Member#: 145060
1998 2.5RS
I did that cause mine went and the only one I could get was 02 WRX and it works fine for me.
trowa is offline   Reply With Quote
Old 08-29-2007, 02:29 AM   #7
MannyMohawk#5
Member#: 98807
1999 RSTi
RHD BF5 & BJ6
What do mean they're attached to the crossmember? You can still remove the rack just like the older style...
MannyMohawk#5 is offline   Reply With Quote
Old 08-29-2007, 02:41 AM   #8
moss
Member#: 10197
er, sorry, the mounting points are different?
I forget now...i just had this conversation . All I know is you need the entire 05+ STi crossmember to put the rack into a GC or anything older than 05.
Old 08-29-2007, 08:43 AM   #9
MMastro
Member#: 18230
1993 EG Civic/ITR
I believe it is the same ratio. The reason was to use the WRX suspension, hubs, etc because it is in much better shape than the RS stuff which is rusted, corroded, and beat up from 210,000 miles and Rhode Island winters. Also the wider track width... hopefully rubbing isn't an issue.
The point also is why is almost everyone (except for trowa) modifying their u joints if they could do this instead?
Old 08-29-2007, 09:34 AM   #10
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
you can still use the wrx suspension/hubs/subframe with the RS rack the tie rods ends have enough adjustment for the extra width ... what you won't be able to change is the strut top mounting point ... which isn't that big of a deal ...
i would speculate that you may have been the first as opening up the rack is kinda scary .. care to do a write up on it?
Old 08-29-2007, 10:29 AM   #11
elsanto
Member#: 34832
1989 M3
good idea indeed. how much do you have to take apart on it?
elsanto is offline   Reply With Quote
Old 08-29-2007, 12:01 PM   #12
MMastro
Member#: 18230
1993 EG Civic/ITR
Well trowa did it first apparently, and actually my buddy (a Honda guy) really did it not me... He removed the power steering lines from the valve housings, unbolted the valve housings and removed the entire assemblies 21-31 from each rack. Compared the assemblies and they appeared identical, so he then gently wiggled the RS one into the WRX rack. T11 x2 is all that is required for removal/assembly minus whats needed to get the hard lines off the housings.
Jaxx, that would have been good to know before we went this route... we compared the tie rod + steering rack lengths and it was shorter so we decided to try this instead because we were afraid the geometry may be screwed up.
Old 01-28-2008, 09:25 PM   #13
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Bump... curious to hear how this is working!
jamesfacts is offline   Reply With Quote
Old 01-29-2008, 09:56 AM   #14
MMastro
Member#: 18230
1993 EG Civic/ITR
Well I still have an alignment or steering issue of some sort (along with clutch slippage, a fuel tank pressure sensor code, a leak in my charging system)...
Before I got an alignment I had some uneveness in the feel throughout the range; being worse with the tires on the ground. I would describe it somewhat similar to post # 4 here: http://forums.nasioc.com/forums/show....php?t=1418388
We guessed it was probably air in the system which was somewhat likely as fluid was low when we first started driving it to work out the bugs. Since I got the car aligned the steering appears to have memory, as in if I make a hard right the car pulls to the right for a while when I return the wheel to straight. I was told by a knowledgeable friend it may be alignment, probably castor issue... Maybe the wrx control arms changing the suspension geometry? I post my alignment specs on one or both of these threads once I scan them so maybe some can make some sense out of what my issue is...
Old 11-17-2009, 09:33 PM   #15
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
MMastro I wanted to say thank you for posting this information. You just solved a future issue in one of my swaps
Old 11-17-2009, 09:49 PM   #16
MMastro
Member#: 18230
1993 EG Civic/ITR
No problem... I've done my fare share of research on these forums over the years and thought I'd share some useful knowledge for others.
For anyone else that finds this thread it has worked like a charm for 2 yrs now and the steering issue was entirely due to torn strut top mounts from the previous owner not using conical washers...
Old 11-17-2009, 09:55 PM   #17
ciper
Member#: 15543
90BJ Legacy LS ABS
If I remember correctly the steering racks from all the 90's legacy/impreza/forester were essentially the same so this mod should work for those as well.
Now I wonder if say an 05 STI rack is the same as the 02 WRX rack - in other words for example could I use a 90 Legacy pinion valve setup on an 06 STI rack?
Old 11-17-2009, 10:21 PM   #18
MMastro
Member#: 18230
1993 EG Civic/ITR
In the online parts catalogs the pinion valve assemblies are listed for the year ranges '02-'04 wrx, '04 Sti and '05-'07 wrx seperately, but the price is exactly the same for the wrx pieces. I think I remember reading STI's are a slightly quicker ratio so those may be different gears. I don't know where to look up part numbers for anything after '02 , but for '02 WRX and '00 2.5RS the part numbers are 34117FE010 and 34117AC010 which are pretty similiar
Old 11-18-2009, 12:46 PM   #19
JRach
Member#: 78075
98' SF5 STI
93' GF8 (rally)
Ciper- The 90 legacy crossmember wont accept an 05' sti rack as mounting points are different. However an 04' sti rack is a different story as it's the same mounting design as the 93-05 impreza/wrx
JRach is offline   Reply With Quote
Old 11-18-2009, 02:12 PM   #20
kay95
Member#: 45494
95 impreza L awd
green
Just make sure when you do that everything is shimmed correctly. I took one apart for a project for a cheaper quick rack and the pinion is shimmed to height so just make sure it is close or you will have slop in the steering.
kay95 is offline   Reply With Quote
Old 11-19-2009, 02:16 PM   #21
jorel
Member#: 186710
1997 impreza L
black
I love it when old threads spring new life. I've always woundered about this but not enough the do a search. Now I def. want to do this.
jorel is offline   Reply With Quote
Old 11-19-2009, 06:23 PM   #22
ciper
Member#: 15543
90BJ Legacy LS ABS
Thank you for the information. I didn't intend to use a Legacy crossmember though...
14 PSI actuator for 16G, Rear diff support bracket, '02 steering rack Vlad Engine/Power/Exhaust 29 01-29-2011 06:36 PM
Will this fit: 04+ STi steering rack in '00 GC? nytoy Brakes, Steering & Suspension 1 10-11-2006 11:59 PM
'02 Steering rack, gutted uppipe, and axles 555ideways Private 'For Sale' Classifieds 2 06-21-2006 10:29 PM
'00 Steering rack in JDM swap confirmation rob Subaru Conversions 6 03-31-2006 04:16 PM
'02 WRX steering wheel in '00 RS aowRS Interior & Exterior Modification 0 04-18-2001 06:18 AM
