Welcome to the North American Subaru Impreza Owners Club Tuesday March 26, 2019
Old 03-29-2015, 04:22 PM   #1
therewasnone
Member#: 417273
Default '00 OBS engine swap
Would it be possible to put the 2.5 Baja engine in a '00 OBS? Would it even be reasonable to do so?
therewasnone is offline   Reply With Quote
Old 03-31-2015, 04:11 PM   #2
LegacyWRX
Member#: 127048
97 Impreza coupe
blue
Probably, the biggest issue is whether they are sohc or dohc. Both engines should be the same. I've done a couple of random swaps by swapping the intake manifold onto the new engine, that way all of the original electronics stay with the car. Then you just have to worry about what exhaust you're using. The engine mounts and bell housings will match.
Edit - Forgot to also say to check the timing gear patterns. I've put an ej22 into a 2001 Forester using this method: swapping the drivers side cam gear and crank timing gear, along with the intake manifolds onto the new engine. Can't say this will work in every instance though.
LegacyWRX is offline   Reply With Quote
