Welcome to the North American Subaru Impreza Owners Club Wednesday March 20, 2019
Old 03-16-2016, 08:32 AM   #1
anfrey
Member#: 170371
2004 gda-d
world rally blue
Default clutch pedal spring snapped!
So the spring on my clutch pedal snapped this morning. Anyone know where I can get a replacement? How much of a pain is it to fix this? The pedal has dropped all the way to the floor and will not engage, even when pulled up manually.
1998 Outback Sport (GF8)
anfrey is offline   Reply With Quote
Old 03-16-2016, 02:12 PM   #2
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
junkyard probably your best and cheapest option. just yank one out of pretty much any subaru. i think the clutch pedal assembly hasnt changed since like 95
Titter is offline   Reply With Quote
Old 03-17-2016, 09:50 AM   #3
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Can't be more then 10 bucks from dealer or maybe weld it?
spoolinsti05 is offline   Reply With Quote
Old 03-17-2016, 11:06 AM   #4
LIChuck
Member#: 266122
2007 WRX Limited
UGM
You have bigger problems than a spring. The clutch should still work even without the return spring.
LIChuck is offline   Reply With Quote
Old 03-17-2016, 02:43 PM   #5
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Agreed I missed that part
Old 02-19-2019, 06:27 PM   #6
saggioWRX
Member#: 18994
15 MK7
10 CTS W
Can anyone find the part number for this spring?
saggioWRX is offline   Reply With Quote
Old 02-19-2019, 08:27 PM   #7
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
part number 36037AA032.
Old 02-20-2019, 09:56 AM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Reply to an old post, but, basically you shouldn't weld/heat any spring UNLESS you go through a heat treating process. Heating it changes it's properties, one being it is more likely to crack/break where it goes from heated area to unheated area.
Old 02-24-2019, 02:57 PM   #9
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
not to mention the filler material wont have anywhere near the same strength as the rest of it and will just break again.
CarmelValleyWRX is offline   Reply With Quote
Old 03-17-2019, 11:34 PM   #10
Brokenmeow
Member#: 374414
2006 Impreza WRX STI
WRC Blue
Junkyard for sure. Or OfferUp part out. Best of luck!
Brokenmeow is offline   Reply With Quote
