Welcome to the North American Subaru Impreza Owners Club Monday July 22, 2019
Old 12-09-2018, 09:45 PM   #201
Kostamojen
Member#: 2272
2018 Type-RA 196/500
1999 OBS Camo Wagon
Looking for confirmation of fit for any of these wheels:
Enkei TS10 18x8.5 +50
Wedsport SA72R 18x8.5 +50
Gramlights 57cr 18x8.5 +50
Volk TE37 18x8.5 +50
Probably will never splurge that much on Volks, but 15lbs makes it tempting
Old 12-13-2018, 12:52 PM   #202
Lennonp
Member#: 493293
Default 19" TE 37 Ultra Fitnent Question
Hello,
I was wondering if anyone has experience with this particular fitment, with the new brakes on the sti. I am a newbie to this stuff, so please forgive me if this is a dumb question.
I am looking to putting on a set of 199.5 +35 TE37 Ultras. They are quite expensive, so I dont want to make a mistake. Will these fit on my car, and will they work with the stock suspension? Will I have to do any fender roll? Will they clear the brakes?The car came with 19s, so I'd like to keep the same diameter of wheel. Also, in the future, I'd like to change out the suspension to aftermarket, with control arms. Does anyone have a similar set up, who can give me solid advice please? Would it be better to go with an offset that is in the +40s range? Will it still look good, and will it clear the brakes?
Thanks a lot guys! I'm a newb with this stuff!
Lennonp is offline   Reply With Quote
Old 12-13-2018, 01:30 PM   #203
Kami Speed
Member#: 96479
2006 WRX STI
Obsidian Black Pearl
Originally Posted by Lennonp View Post
Hello,
Hey! The Volk Racing TE37 Ultra in 19x9.5 comes in two offsets for the new 2018+ STI. You can choose the 19x9.5 +44 which will fit the car no problem, clear your Brembos and your fenders even with a drop. But the only downside is you get a Face 2 Concave. Which will look like this on the car:
Or you can go with the 19x9.5 +35 which also clears your 18+ 6-Pot Brembos (if anyone else reading this that has an STI from 2015-2017 these wheels will require 3mm spacers), but depending on tire size and camber settings this setup will rub your fenders in the rear. If you do plan on dropping the car with coilovers and getting lower control arms, you could fix the issue with a smaller tire and add negative camber in the rear. But with this setup, we still recommend a mild roll in the rear. Plus side is you get the Face 3 concave face which looks like this:
Kami Speed is offline   Reply With Quote
Old 12-13-2018, 01:42 PM   #204
Lennonp
Member#: 493293
I really like the face 3 concave. If it was possible to get a custom fit of 199.5+37, with face 3, would that work?
Old 12-13-2018, 01:42 PM   #205
Lennonp
Member#: 493293
I appreciate the pictures to clarify!! Tha is for replying!
Old 12-13-2018, 01:44 PM   #206
Lennonp
Member#: 493293
Without fender rolling and suspension change**
Old 12-13-2018, 01:44 PM   #207
Kami Speed
Member#: 96479
2006 WRX STI
You are welcome.
Volk does not make a +37 offset and they do not offer custom one off sets.
Let me know if you want to order any of those sets and I can help you out
Old 12-13-2018, 04:00 PM   #208
Lennonp
Member#: 493293
You are welcome.
I will do! Thanks a million!
Old 12-17-2018, 01:27 PM   #209
MrFine67
Member#: 336054
2019 STi
CWP
It is okay to assume Enkei TS-10 18's that were mounted on a 2015 STi will fit my 2019 STi?
The guy doesn't know the specs and I'm not looking to throw money out the window if they dont fit. Can't test fit them, unfortunately.
MrFine67 is offline   Reply With Quote
Old 01-08-2019, 09:17 PM   #210
poefosho
Member#: 410492
Originally Posted by Thugmufin View Post
The ones from the begging one the thread on the lapis blue are NOT these wheels as mentioned below... JJay03 and myself are both running the BBS that look very close to these... 18 spokes similar design
nobody has confrimed the 2011-2012 STI wheels fit...
I have searched the net and cannot find any pictures of these fitting the 6 pot brembos..
poefosho is offline   Reply With Quote
Old 01-17-2019, 10:05 AM   #211
Subi117
Member#: 476273
has anyone tried the Varrstoen ES2 wheels?
Subi117 is offline   Reply With Quote
Old 01-17-2019, 11:12 AM   #212
AWD BRO
Member#: 488722
2000 2.5rs w/EJ20K
& (now) 3 other GCs
Real wheels save lives..
AWD BRO is offline   Reply With Quote
Old 01-17-2019, 11:14 AM   #213
Subi117
Member#: 476273
here we go...lol
Old 01-19-2019, 09:30 PM   #214
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
Wound up going with a set of 08-14 BBS's for Autox wheels. Had them repaired and powdercoated gloss black. Turned out pretty good...
Old 01-29-2019, 07:57 PM   #215
defaultstivaper
Member#: 486819
2018 STI
Pure Red
So 18x9 ET 35 with a 245/40 tire should clear no problem correct?
At first I was concerned because I saw 18x9.5 et 40 wouldn't clear, but then I realized that was for pre 18 brembos. The new 6 piston brembos are thinner than the previous year STI brembos?
defaultstivaper is offline   Reply With Quote
Old 01-30-2019, 11:17 AM   #216
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Nope, as every wheel design is different. It's more how the spokes are designed as to whether it will clear these big calipers.
Scorpius is offline   Reply With Quote
Old 01-30-2019, 02:05 PM   #217
defaultstivaper
Member#: 486819
2018 STI
Pure Red
They're Motegi m131 traklites, 18x9 et 35
https://www.wheelpros.com/wheel/23454/mr131-traklite
Old 02-07-2019, 10:47 AM   #218
stajerker
Member#: 48970
2019 STI
CBS
looking to confirm that Wedssport SA-10R 18x8.5 -45 will fit the 2019 STI.
They only come in face 'F' for the 18x8.5 which is my worry it might not clear the brembos
Or the SSR GTX01 18x8.5 offset 44.
thanks in advance
stajerker is offline   Reply With Quote
Old 02-10-2019, 01:20 PM   #219
jasonrp7743
Member#: 497226
2019 STi
Crystal White
I gotta newb question: What size tire height would I want, if I go to 18" from my 19", so that the OD of the wheel/tire combo is exactly the same?
I have a 2019 STi limited (not sure if the limited part matters?), with stock 19" rims and the yellow 6-piston front brakes.. I want to get some winter rims, that will match the current factory OD so that the speedo/odo is not thrown off. I don't plan to lower the car, or do coilovers, or change camber, or roll fenders. So, that's my goals. Oh- want something that looks decent* of course, but don't want to spend crazy money on this part.
Looks like 245/35-19 is the stock tire size? So, would I want 245/45-18 if I step down to 18" rims that fit? I say 18" because I'm under the impression that 18" rims are more plentiful than 19"? Also 18" tires cheaper than the 19"?
*By decent- how can you tell what amount of concave (or is it convex) you can run, so that there is a pleasing amount of bow to the rim spokes, yet they fit in the wheelwells? Is this the offset that everyone is talking about?
Thanks!
jasonrp7743 is offline   Reply With Quote
Old 02-13-2019, 12:09 PM   #220
quiksilver_dragon
Member#: 246479
2005 Impreza WRX STi
What tire size do you plan on running?
I got the same set and had them powder coated gold to go on my CWP 19 STi. I was probably going to run 265/35r18 on my autox setup.
Maybe I'll splurge on a set of TC105X 18x8.5 +50. But I'm doubtful on that for now.
quiksilver_dragon is offline   Reply With Quote
Old 02-13-2019, 12:13 PM   #221
quiksilver_dragon
Member#: 246479
Thanks!
245/40r18 would be the same OD for a tire compared to your 245/35r19 stockers.
All different wheels/models will have different concave/convex spokes. You just need to look at their size specs charts and it should be labeled what face design they have.
Old 02-14-2019, 07:07 PM   #222
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
255/35r18 Re71Rs. I got a deal for almost half price otherwise I would be running 265's.
Old 02-17-2019, 09:18 PM   #223
Vicious LSD
Member#: 103539
2015 STi Limited
Anyone know if 255/40/18 tires on 18x8 40 offset will fit on a 2015 sti with zero issues?
Vicious LSD is offline   Reply With Quote
Old 02-18-2019, 09:36 AM   #224
TifosiWA
Member#: 489993
2019 WRX STI LTD
Pure Red
Wrong post, please delete. Thank you.
TifosiWA is offline   Reply With Quote
Old 02-25-2019, 11:37 AM   #225
jrseda
Member#: 497894
2018 WRX STI Limited
WR Blue
Originally Posted by willimprez View Post
Running Bronze Work Emotion CR Kiwami in 19x9.5 +38 wrapped in the OEM 245/35-19 lowered on RCE Yellow springs. No roll and rubbing yet.
Running the same setup and love it in my summer setup!!
jrseda is offline   Reply With Quote
