Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2019
Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Complete Car Part-Out
Old 11-29-2017, 11:13 AM   #1
BlobeyeSTi
Member Sales Rating: (40)
Member#: 187877
04 FXTi
OMGHi2U WV: 1999 & 2000 RS Coupe Part Out
Parts are from 1999 and 2000 RS coupes both 5 speeds.
Located in Fairmont WV & shipping isn't a problem just message me for a quote. If you want pictures of a certain part just ask.
*Links to albums of individual pictures of each part are located beside each group*
GC Parts
Engine & Drivetrain Pics: GC Engine & Drivetrain - Album on Imgur
• Intake manifold $50
• Rear subframe $40
• Front subrframe $80
• Rear differential carrier 'T' subframe $50
• Rear differential $75
• Transmission subframe $25
• RWD converted 5 speed transmission (welded center diff) $400
• Center differential (make above trans awd again) $200
• Transmission mount $20
• Purge valve solenoid $15
• Gas cap $10
• Fuel pump assembly with pump $20 (1 piece broken)
• Fuel lines $50
• Injectors $40 set
• Clutch master $30
• Slave cylinder $30
• Steering rack $75
• Throttle cable $10
• Alternator $40 (2 available)
• Power steering pump $70
• Power steering reservoir $15
• Power steering reservoir bracket $5
• Ignition coil $20
• Coil packs $40 set
• Throttle body $20
• Oil fill neck and cap $15
• Cam gears $10
• Axle with one busted joint $25
• Intake silencer $10
• Coolant overflow tank $10
Suspension & Brakes Pics: https://imgur.com/a/vaSJf0R
• Sway bars $40 each
• Lateral links $20 each
• Trailing arms $40 set
• Endlinks $20 set
• Control arms $25 each
• Brake booster and master $40
• WRX rear calipers $50
• ABS module $40
• Front ABS sensors $15
• Front brake caliper mount $5
Exterior Pics: https://imgur.com/a/l3wK1sO
• Glass driver side headlight $100
• Scoop $75
• Hood vents $40
• Driver Door $100
• Rear bumper $100 (2 available)
• Front bumper beam $75
• Black trunk with small wing (no dents needs repainted) $50
• Blue trunk with small wing (has few dents) $50
• Inner fenders $10
• Door windows $40 each
• Door handles blue $30
• Hood release cable $10
• Roof trim $40 each (Shipping is expensive due to size)
• Windshield trim $25 each
• Wiper cowl $40
• Wiper motor & linkage $40
• Sunroof $100
• Driver Taillight trim $20
• Quarter panel trim $10 each
• Hood prop $5
Interior Pics: https://imgur.com/a/zlSelwm
• Steering Wheel $20
• Driver airbag $40
• Dash bar $50 (2 available)
• Rear seats $50
• Hood release handle $5 (2 available)
• ECU cover $10
• Ebrake handle $20
• Door kick panels $10 each
• Wire covers for inside door kick panel $10 side
• Fuel pump cover $5
• Gas pedal $20
• Blower motor $50
• Dash cup holder $10
• Rear view mirror $20
• Interior lights $10 each
• Seatbelts $40 (no driver front or rear center but have the rest)
• Steering column $50
• Speaker brackets $5 set (2 available)
• Weatherstripping $5
• Tweeter cover $10 each
• Door handle trim and pocket $10 set
• Visor clips OEM $10
• Door panel bolt covers $5 set
• Door panel brackets $10 each
• Door mirror cover $5
• Gauge cluster trim $10
• Seat bolt covers $10 set of 4
• Passenger A pillar $15
• Rear heat vents $20 set (2 available)
Electronics Pics: https://imgur.com/a/3779vWz
• Knock sensor $10 (2 available)
• Sunroof harness $10 (2 available)
• Interior fuse box $20
• Engine bay fuse box $20
• Door ajar sensor $10
• Horn and cruise control steering wheel switch $20
• Cruise control dash switch $10
• Hazard switch $10
• Antenna with screws $25
• Wiper switch $20
• Airbag sensors $10 each
• Airbag harness $25
• Airbag control unit $25
• Alternator to battery cable $10 (2 available)
BlobeyeSTi is offline   Reply With Quote
Old 11-29-2017, 11:13 AM   #2
BlobeyeSTi
Member#: 187877
04 FXTi
Old 11-29-2017, 11:14 AM   #3
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 11-29-2017, 11:14 AM   #4
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 12-01-2017, 05:19 PM   #5
BlobeyeSTi
Member#: 187877
04 FXTi
bump!
Old 12-04-2017, 10:18 AM   #6
BlobeyeSTi
Member#: 187877
04 FXTi
OP Updated
Old 12-06-2017, 05:49 PM   #7
BlobeyeSTi
Member#: 187877
04 FXTi
bump!
Old 12-08-2017, 12:16 PM   #8
BlobeyeSTi
Member#: 187877
04 FXTi
OP updated with new parts
Old 12-11-2017, 12:39 PM   #9
BlobeyeSTi
Member#: 187877
04 FXTi
Bump!
Old 12-13-2017, 07:43 AM   #10
BlobeyeSTi
Member#: 187877
04 FXTi
bump...
Old 12-15-2017, 11:28 AM   #11
BlobeyeSTi
Member#: 187877
04 FXTi
Bump.
Old 12-16-2017, 09:14 PM   #12
BlobeyeSTi
Member#: 187877
04 FXTi
OP Updated
Old 12-18-2017, 10:25 AM   #13
BlobeyeSTi
Member#: 187877
04 FXTi
bump...
Old 12-19-2017, 11:37 AM   #14
BlobeyeSTi
Member#: 187877
04 FXTi
bump!
Old 12-20-2017, 12:38 PM   #15
BlobeyeSTi
Member#: 187877
04 FXTi
bump....
Old 12-21-2017, 03:39 PM   #16
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 12-22-2017, 11:20 AM   #17
BlobeyeSTi
Member#: 187877
04 FXTi
OP & Pictures Updated
Old 12-23-2017, 02:02 PM   #18
BlobeyeSTi
Member#: 187877
04 FXTi
bump...
Old 12-24-2017, 10:00 AM   #19
Foo_Blyat
Member Sales Rating: (110)
Member#: 93750
I’m pickng up a 99 Impreza on Tuesday and will need all the black interior dash parts from you
Foo_Blyat is offline   Reply With Quote
Old 12-24-2017, 12:27 PM   #20
BlobeyeSTi
Member#: 187877
04 FXTi
Cool deal just let me know what all pieces you want and your zip
Old 12-26-2017, 11:42 AM   #21
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 12-27-2017, 01:15 PM   #22
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 12-28-2017, 09:39 AM   #23
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 12-29-2017, 11:26 AM   #24
BlobeyeSTi
Member#: 187877
04 FXTi
Bump...
Old 12-30-2017, 02:05 PM   #25
BlobeyeSTi
Member#: 187877
04 FXTi
OP Updated
