Welcome to the North American Subaru Impreza Owners Club Saturday March 23, 2019
Old 02-28-2018, 10:48 PM   #1
Goldo4fxt
Member#: 478656
Default Trans cooler for 4eat
I did a search and found a coupe threads . Just curious if anything has changed with which cooler to use and does anyone know the best way to route it and mount it . It would be going on a 04 fxt vf43 sti tmic turboback exhaust and all supporting mods . Thanks in advance
Goldo4fxt is offline   Reply With Quote
Old 02-28-2018, 11:31 PM   #2
Drew's Rex
Member#: 151422
2005 Impreza T
Go with a B&M Transmission Cooler or any cooler as long as its stack plated. Routing is simple as there are only two lines. In and return lines.
Drew's Rex is offline   Reply With Quote
Old 03-05-2018, 07:10 AM   #3
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
B&M is what i run. one for engine oil, one for trans oil.
mount it anywhere you have air flow. or if u wanna buy a fan for it, mount it anywhere you like.
Titter is offline   Reply With Quote
Old 03-06-2018, 04:19 PM   #4
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
I just finished installing a Haydon 678 tranny cooler yesterday with the external mount kit. It works great.
https://www.amazon.com/Hayden-Automo.../dp/B000C3DDKO
Fierysun is offline   Reply With Quote
Old 03-21-2018, 10:06 PM   #5
Ikea_Wrx
Member#: 477215
2005 Saab 9-2X Aero
22G
pics??
Ikea_Wrx is offline   Reply With Quote
Old 02-13-2019, 12:26 AM   #6
CBDslappy
Member#: 491899
bump cause I can't find a write up for this
CBDslappy is offline   Reply With Quote
Old 02-13-2019, 09:08 PM   #7
Fierysun
Member#: 82745
2005 Subaru STI
It's pretty basic, just mount to the driver side in front of the radiator/ac condenser using the supplied brackets (which you'll need to trim to size) and pre-existing holes in front of the radiator support and side.
Old 02-15-2019, 10:24 AM   #8
WhiteOut13475
Member#: 496550
2006 WRX Limited
I've had mine attached to the front supports, sitting in front of the rad and ac. Holding on tight with a few zip ties baby! No issues. And, adding a trans cooler was pretty much the first thing I've ever done to a car. Simple and straight forward, just take your time.
WhiteOut13475 is offline   Reply With Quote
