Welcome to the North American Subaru Impreza Owners Club Monday March 25, 2019
Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Complete Car Part-Out
Old 09-13-2018, 11:13 AM   #1
Zmanwrx23
Member Sales Rating: (3)
Member#: 438620
2006 WRX Sedan
CGM
Default WRX & STi Parts UPDATED 3-12-2019
Some parts left over from my 6-speed swap on my 2006 WRX sedan, as well as some random stuff left over from building my motor. Flexible on all prices just no lowballs please. If you buy multiple things we can work a deal. Shipping not included unless otherwise stated.
Engine:
- (SOLD) Stock WRX/STi snorkel, connecting fender box, and connecting hose (air-box sold) - (SOLD)
- Brand New OEM ej25 head gaskets. I have a closed deck block so I didn't use these - $45 shipped
- STi TMIC shroud, comes with the shroud and rubber gasket thing - $40
- Red STi bare intake manifold - $70
- (SOLD) 2007 STi VF43 turbo, low mileage, no shaft play AT ALL, pristine example - (SOLD)
- (SOLD) PTP Lava turbo blanket - (SOLD)
- (SOLD) 2007 STi stock blue injectors - (SOLD)
- OEM coolant overflow tank, dirty but in great shape - $10
- OEM radiator - $30
- (SOLD) OEM oil cap - (SOLD)
- (SOLD) DW-65c fuel pump, used for 25k miles on 93oct only. Only selling to upgrade to a bigger pump - (SOLD)
- (SOLD) 3" aluminum MAF housing, AEM filter, silicon step-down (3" to stock inlet size), 2007 STi MAF included - (SOLD)
- (SOLD) Group-N motor mounts and pitch stop. 25k miles - (SOLD)
- Stock ej25 oil control tray/baffle (not the one from in the pan, this is the one that bolts to the bottle of the block) - $20
- Stock 2006 WRX TGVs. Fully functional when removed, would be great for returning to stock or getting PnP-ed for some added flow - $65
Driveline:
- New ACT pilot bearing for STi - $3
- New ACT throw out bearing for STi - $40
- (SOLD) Exedy Stage 1 clutch an pressure plate for 04+ STi, 10k miles, tons of life left - (SOLD)
Interior:
- Full 2006 WRX sedan interior (see pics below)
- OEM 05-07 6-speed trans shift boot. Leather is in great shape no tears - $35
- (SOLD) 2007 (V9) USDM STi gauge cluster. 109,221 miles. Mint condition - (SOLD)
- (SOLD) 2004/2005 (V8) USDM STi gauge cluster. 139,564 miles. Mint condition - $255 (SOLD)
- 2006 WRX gauge cluster. 157,613 miles. Good condition - $140
- 2008 WRX roll connector/clock spring (P/N 27546FG000) no cut wires - $80
- set of 2 rear gray OEM carpeted floors mats. $8
- misc. interior plastics (B pillar lower, lower c-pillar, rear kick sills, etc.) good for replacing scratched, broken, or missing pieces in your interior - Make offer
- (SOLD) OEM lamco boost gauge, come with mounting bracket (this was a factory option came on the plastic steering column cover, wires and air line were cut with about ~6in left on them. Easy to mount up and wire - (SOLD)
- OEM 2002-2003 driver airbag igniter - $??
- (SOLD) WRX rear interior deck and high mount 3rd brake light. Both in mint condition - $45 for both (SOLD)
Exterior:
- 2006/2007 OEM Fog lights with surrounds. All hardware and bulbs included. No cracks! Lost them because of my front mount - $200
- OEM front two hook. Can't use it as I don't have my bumper beam anymore - $5
- USDM Bugeye headlights. They are quite cloudy/yellowed however the housings are sealed and still good, includes bulbs. Would be a great set to restore or use cores for a retrofit - $60
- 1 rear tail light harness with bulbs. No cut wires, came out of a busted tail light. $3
- OEM Subaru hawkeye (06/07) front end bug deflector. Complete with all hardware and mounting screws. One small rock crack. This is a hard to find kit nowadays. - $50
- OEM WRX low spoiler in CGM. Was taken off the car brand new in 2006. It's in flawless shape - $90
- OEM hood prop, took it off because I have hood dampers. - $3
- (SOLD) Custom STi front plate delete - (SOLD)
- (SOLD) Shaved sedan trunk with STi limited lip spoiler: This trunk has had all the holes welded up, backed down then was primered, had 3 coats of Crystal Gray Metallic (CGM) base coat put on and 2 coats of clear. No badge holes no key hole. Inside was also rubber coated for some added sound deadening. Includes OEM STi limited (only available in 2007) lip spoiler (not drilled, so you can remove it if you want to go full wingless). Cleanest trunk you will find. Was painted summer of 2017 and was on my car for approximately 4 months. Asking $450 OBO (will include OEM cabin mounted third brake light and rear deck if you're an STi driver converting to wingless as you'll need a third brake light) (SOLD)
I can text pics whenever just text me and ask for whatever you wanna see. These parts are just sitting in my garage and basement so I would like to see someone get some use out of them. If you think my price(s) is too high simply shoot me an offer, worst I can say is no. PM or text 515-343-0660 with questions. Thanks for looking!
Zmanwrx23 is offline   Reply With Quote
Old 09-13-2018, 11:23 AM   #2
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
Old 09-13-2018, 11:32 AM   #3
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
Old 09-17-2018, 03:45 PM   #4
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
Old 09-20-2018, 03:21 PM   #5
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
Close-up of the wear on driver's outer bolster
Old 09-28-2018, 03:42 PM   #6
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
bumppppp
Old 09-29-2018, 04:20 PM   #7
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
LAMCO OEM boost gauge sold. Bump!!
Old 10-02-2018, 03:39 PM   #8
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
bump. I will ship anything here if the buyer and I can reach a mutually good deal
Old 10-05-2018, 03:36 PM   #9
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
bumppp
Old 10-07-2018, 05:07 PM   #10
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
All PMs replied bump!
Old 10-07-2018, 07:00 PM   #11
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
Plate delete sold
Old 10-12-2018, 03:11 PM   #12
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
MAF tube/clamps and bug deflector pending! BUMP
Old 10-14-2018, 02:30 PM   #13
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
Bump!!!
Old 10-17-2018, 03:47 PM   #14
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
rear deck pending bump. Lots of new parts coming this weekend. Will update!
Old 10-20-2018, 08:42 PM   #15
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
new parts added bump!!
Old 10-23-2018, 12:36 AM   #16
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
Bummppp
Old 10-24-2018, 03:34 PM   #17
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
PMs replied!
Old 10-27-2018, 05:33 PM   #18
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
vf43 sold bump!
Old 10-31-2018, 09:02 PM   #19
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
bumpity
Old 11-02-2018, 07:10 PM   #20
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
DW-65c fuel pump sollllld. OG post updated, added a few more pics
Old 11-05-2018, 10:19 PM   #21
danger1138
Member Sales Rating: (19)
Member#: 279525
06 Fxt
Can you send me a pic of the ptp turbo blanket. Thanks
danger1138 is offline   Reply With Quote
Old 11-05-2018, 11:41 PM   #22
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
I'll PM you in a second
Old 11-07-2018, 03:49 PM   #23
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
2007 STi injectors sold!
Old 11-08-2018, 12:52 PM   #24
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
PMs replied
Old 11-09-2018, 09:05 PM   #25
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
Oil cap and PTP turbo blanket sold bump!
