Welcome to the North American Subaru Impreza Owners Club Tuesday July 23, 2019
Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC > NESIC Private Classifieds
Old 12-05-2018, 07:40 PM   #1
creature546
Member Sales Rating: (5)
Member#: 24585
2002 Subaru wrx
Green
Default Built 02 impreza Obs
-The car
2002 Subaru Impreza Outback Sport
5 Speed transmission
186k miles on body
10k on build (full drivetrain)
Here is what I have, it is a 2002 Subaru Impreza Outback sport, by VIN. The body of the car is the only thing that is still original. Everything else came from a 02 WRX.*
I built this car with the mind set of a fast, high reving, back roads beast, or to be able to take it to the track and have fun. The car is currently tuned for 93 pump gas and makes 410awhp and 380awtq. It is almost turned for e85 on which it made 460awhp and 430awtq. At this time the e85 tune still needs to be finished up.
Durning the build every little thing that was touch was clean, repaired, rebuilt, or replaced if needed, as time was free to me and I spent alot of it on this build! The shell of the car was originally from Florida and has ZERO rust through out the car. Durning the build i added rust preventing paint to common rust areas so that it would stay rust free. Never been driven in the snow or salt.
- MODS -
- suspension -
Bilstin pss9 coilovers
Whiteline rear swaybar 22mm
Whiteline front swaybar 24mm
Whiteline adjustable front endlinks
Sti rear lateral links
Whiteline trailing arm rear bushing
Whiteline trailing arm front bushing
Whiteline rear subframe lockdown kit
Whiteline out trigger bushings
Sti front control arms
Whiteline roll center kit
Perrin PSR kit
Whiteline control arm bushing front
TIC steering rack bushings
GTSpec rear strut tower bar
04 STI steering rack
STI steering knuckle
50mm extended wheel studs front
7mm front wheel spacer
5mm rear wheel spacer
Mutki lug nuts
- Brakes -
Stoptech SS brake lines
Cadillac ATS Brembo front calipers
Stoptech slotted front rotors
Stoptech street brake pads
2007 wrx rear knuckles
Subaru wrx 2 pot calipers
Stoptech slotted rear rotors
- Drivetrain -
Transmission rebuilt and sealed
2009 wrx gear set
Rear differential cleaned and resealed
Custom blast plates
6speed ACT lightweight flywheel
6speed ACT sprung 6 puck clutch
Cobb rear shifter stay bushing
Cobb front shifter bushing
Whiteline trans crossmember bushings
Group N transmission mount*
Kartboy pitch stop mount
Kartboy short shifter
Cobb shift knob
- Wheels -
Work emotion cr Kai 17x7 +47 offset
- Engine - 2.1L stroker motor
Ej20 block
Je 9.5:1 pistons 2.1 stroker 92.5mm bore #314450
Manely turbotuff ibeam rods
King rod bearings std size
King main bearings std size
Sti 2.5L crankshaft
Arp L19 head studs*
JE Proseal .039" headgaskets*
JDM 12mm oil pump
BC 272 cams
BC valve spring kit
Ported heads
Killer bee oil baffle
Killer bee oil pick up tube*
NGK bkr7eix spark plugs gapped .025
PML 1.5 scroll header
Ecs rotated turbo pedestal*
Percision 5858 ball bearing turbo
Custom 3" downpipe
Custom FMIC kit
4" intake
Tail Q 50mm BOV
Tial 44mm wastegate
Tgv deletes
Shaved intake manifold
Grimmspeed 8mm phenolic spacers
ID1300 injectors
IAG fuel rails /w fuel pulse dampers
8an fuel line from tank
6an fuel lines to rails
Radium FPR
Walbro 450 fuel pump
Fuel pump hard wire
Group N engine mounts
Aem 3.5 bar map sensor
GM intake air temp sensor*
Perrin light weight crank pulley*
Custom AOS setup
Canton racing oil sandwich plate
Cobb accessport V3
- Cooling -
Mishimoto radiator
-Evo X oil cooler /w -8an SS lines
-Exhaust -
Cobb catback exhaust*
- Interior -
Full wrx swapped interior
JDM Version 3 WRX front seats
04 wrx red momo steering wheel
05 SAAB 92x aero gauge cluster
Black sti floor mats
IAG floor mat holder
05+ black carpet
06-07 black hatch compartment*
Pioneer avh-p4000dvd
Oem premium sound
- Misc -
Grimmspeed hood struts
Grimmspeed battery tie down*
Blacked out headlights
Yellow fog lights
Rust trap painted :
Front lower frame
Front crossmember*
Front u-brace
Transmission crossmember
Rear differential*
Steering rack
Front knuckles
Rear knuckles
Driveshaft
Looking to get $13000 obo OR strongly consider trades for a FD rx7 ranging from running driving or roller +cash. Not in a rush to sell nor do I have to sell it.
have tons more pictures or can get whatever you want to see. Feel free to ask any question. Message me here or call/text me @ 413-320-8244
Thanks for looking
Seth
1st-2nd gear pull video
https://i.imgur.com/nFSprBq.mp4
creature546 is offline   Reply With Quote
Old 12-09-2018, 09:15 AM   #2
creature546
Member#: 24585
2002 Subaru wrx
Green
Bump.
Old 12-17-2018, 06:55 AM   #3
creature546
Member#: 24585
2002 Subaru wrx
Green
Bump.
Old 12-22-2018, 08:40 AM   #4
creature546
Member#: 24585
2002 Subaru wrx
Green
Bump.
Old 12-23-2018, 08:55 AM   #5
creature546
Member#: 24585
2002 Subaru wrx
Green
bump, edited the pictures so they could be seen easier
Old 01-05-2019, 08:29 AM   #6
creature546
Member#: 24585
2002 Subaru wrx
Green
Bump.
Old 01-10-2019, 05:57 PM   #7
creature546
Member#: 24585
2002 Subaru wrx
Green
Bump.
Old 01-10-2019, 06:57 PM   #8
GALBEROS
Member#: 446096
2018 MB- AMG GLC43
Prior-MB GLE/13WRX/06STI
Nice (detailed) build but your car is 17 years old and has seen 4 seasons in each of those years.
GALBEROS is offline   Reply With Quote
Old 01-11-2019, 08:29 AM   #9
creature546
Member#: 24585
2002 Subaru wrx
Green
Well yes no matter where you are there season change. The car being from the south means it was far less likely to have seen salted snow covered roads and at the small chance it did it was not for an entire season of it. Since I took ownership of the car it has been driven from about april to October (conditions dependent) and stored the rest of the time.
Old 01-11-2019, 08:57 AM   #10
Jack
Add Lightness
Member Sales Rating: (7)
Member#: 13699
not my president
(From General)
Really nice car, well done, as you documented. Also free bump since I know where Huntington is (I'm originally from Westfield).
Old 01-20-2019, 12:39 PM   #11
creature546
Member#: 24585
2002 Subaru wrx
Green
Bump.
Old 01-29-2019, 06:59 PM   #12
creature546
Member#: 24585
2002 Subaru wrx
Green
Bump.
Old 02-02-2019, 09:58 AM   #13
creature546
Member#: 24585
2002 Subaru wrx
Green
Price adjusted
Old 02-07-2019, 07:05 PM   #14
creature546
Member#: 24585
2002 Subaru wrx
Green
bump.
Old 04-23-2019, 08:20 AM   #15
creature546
Member#: 24585
2002 Subaru wrx
Green
Bump!
