Welcome to the North American Subaru Impreza Owners Club Wednesday March 20, 2019
Old 02-10-2019, 09:37 PM   #1
kenshapiro2002
Member#: 346708
Default Trans Noise Due to New Mount?
Just had a new clutch , pressure plate and flywheel installed (Ď05 Saabaru).The trans mount was toast and they installed a heavy duty, ďSTI typeĒ one. Now, when I go off throttle, thereís this noise at around 2,500-3,500 that sounds like rain being tossed up into the wheel well. The guru at my shop says itís gear lash... a normal noisy gear box thatís now amplified by a much more solid trans mount... the gear noise is now transmitted into the unibody. They even offered to install a stock type mount if I canít take the sound. Make sense to yaíll?
kenshapiro2002 is offline   Reply With Quote
Old 02-10-2019, 10:45 PM   #2
Anthony18WRX
Member#: 491570
2018 Subaru WRX
CBS
Yup. I just installed the Group N STI transmission mount not to long ago in my 18 WRX. It whines 1-3 gear the most between 2k-3k RPM. That's a normal sound to expect with a more solid mount.
Anthony18WRX is offline   Reply With Quote
Old 02-11-2019, 12:39 AM   #3
subarumod
Member#: 468745
06 wrx
black as your girls soul.
It goes away in time.
subarumod is offline   Reply With Quote
Old 02-11-2019, 09:30 AM   #4
kenshapiro2002
Member#: 346708
As will you and I
Old 02-17-2019, 06:53 PM   #5
Shik
Member#: 132
2006 GT Ltd 5spd sdn
'15 WRX 6spd CWP, '02 WRX
Maybe you get used to the sound, but it won't go away. At least, it never did in any of my Subarus, but I dig the sound so I don't mind.
Shik is offline   Reply With Quote
Old 02-17-2019, 07:05 PM   #6
kenshapiro2002
Member#: 346708
Itís also doing it at very low speeds... I donít want to go back to a stock trans mount because the shifting is so much more precise but I find myself staying on light throttle instead of full lift off to kill the noise. Not digging the sound yet at all. 😂
Old 02-17-2019, 09:24 PM   #7
SubRepairNPerform
Member#: 490702
Our transmissions are very loud. I work for Subaru. It is a very common issue with people having complaints of noises, all those cars had in common were aftermarket transmission mounts
SubRepairNPerform is offline   Reply With Quote
Old 02-17-2019, 09:42 PM   #8
kenshapiro2002
Member#: 346708
Mine is a 2005 Saab 9-2x Aero. My stock mount was toast. The garage (IAG) installed an OEM STI mount. I also have N-Group motor mounts.
